BIG EARL Posted March 29, 2002 Share Posted March 29, 2002 I just bought a NES system and it doesn't seem to be working. When I turn it on the screen just flashes and the light on the fron to the console flashes also. The screen just flashes a blue color.... Is this a easy problem to fix or is the system dead? Any info would be great. Also, is there a good NES site out there that would be better equiped to help? Thanks, Sam the Collectomaniac Quote Link to comment Share on other sites More sharing options...
Paul Slocum Posted March 29, 2002 Share Posted March 29, 2002 Try cleaning the contacts on the cartridge with a q-tip and rubbing alcohol. -Paul Quote Link to comment Share on other sites More sharing options...
liveinabin Posted March 29, 2002 Share Posted March 29, 2002 I recommend you go to Classicgaming.com and have a look at their NES repair guide - it's really good. Quote Link to comment Share on other sites More sharing options...
fmctm1sw Posted March 29, 2002 Share Posted March 29, 2002 Someone told me the only way to fix that was with a new connector. You can pick them up on ebay. NONE of my unlicensed games (except for the wisdom tree games) work on my NES. Quote Link to comment Share on other sites More sharing options...
liveinabin Posted March 29, 2002 Share Posted March 29, 2002 No, all you need to do is bend the connector pins back into place, they just get pushed out of joint over the years and, consequently, don't make proper contact with the metal strips on the cartridge. I did this to mine and it went from rubbish to 100% reliable in about 5 minutes. Quote Link to comment Share on other sites More sharing options...
fmctm1sw Posted March 29, 2002 Share Posted March 29, 2002 hmmm, just bend them? Just poke them with a screwdriver or something? Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted March 29, 2002 Share Posted March 29, 2002 Yeap...get a jeweler's small flat tip screwdriver and on the top of the connector you will see little square holes above each connector. If you push these in just a little you can reform the contracts towards the center of the connector and hence improve the contact between the connector pins and the cart contacts. However, caution must be used...as if you apply too much force..you can actually bend the pins too far and when you insert a cart...it will actually bend the pins totally to the back of the connector. If that happens...you pretty much have to get a new connector. I actually go to a shop in town that buys the replacement connectors and take the ones they remove to keep mine going strong...hehe.. Quote Link to comment Share on other sites More sharing options...
BIG EARL Posted March 30, 2002 Author Share Posted March 30, 2002 hi again, Thanks for all the help. I cleaned the carts and that didn't help so I messed with the connector and now the carts won't go back in , 1 of the pins got pushed to hard I guess. Oh well, I ordered a new connector off of ebay, I'll see if this helps. Let you all know in a week or so... Thanks again Quote Link to comment Share on other sites More sharing options...
BIG EARL Posted April 4, 2002 Author Share Posted April 4, 2002 Well, I got the new 72 pin connector in the mail today. I hooked it up and the system works GREAT! It cost as much as I payed for the system itself but I think it was worth it. I played Duck Hunt for over an hour! I sure do love that game. Thanks to all who replyed to my call for help! Quote Link to comment Share on other sites More sharing options...
1090 Posted April 7, 2002 Share Posted April 7, 2002 Just blow in it really hard... heh. Quote Link to comment Share on other sites More sharing options...
Stroxalarb Posted April 15, 2002 Share Posted April 15, 2002 Ok I have exactly the same problem with my NES I just bought........what is the connector? Is it part of the cart or the console or what? Can someone please explain it to me as if I don't understand English? I want to play my games Quote Link to comment Share on other sites More sharing options...
Noble Kale Posted April 15, 2002 Share Posted April 15, 2002 the connector is basically where the cart slots into (on front loaders, you push the cart into the nes, and then into the connector/cart slot to make contact. Basically look into the guts of the nes, and it will be the row of contacts down there. Quote Link to comment Share on other sites More sharing options...
StanJr Posted April 15, 2002 Share Posted April 15, 2002 I'm currently playing doctor with my NES as well. The connector is a large black plastic rectangular box mounted on the circuit board (I am assuming you have a front loader). If you remove the casing, remove the steel shield, and remove the cart carriage, it will be the only thing sticking up (other than a small steel support post). I'm still a bit confused about which little holes you guys are referring to, though. Are they on the face of the connector about the contacts, or are they on top of the connector toward the back? Tinkering Stan Quote Link to comment Share on other sites More sharing options...
Atari Master Posted April 15, 2002 Share Posted April 15, 2002 Yep, it's right in the back, just slip the little sucker off. Quote Link to comment Share on other sites More sharing options...
Stroxalarb Posted April 16, 2002 Share Posted April 16, 2002 Ok, so you take all those parts off the outside, then you get something and poke it in the holes? I don't have one of those jeweller's thingies.....and how far in do you poke it? I don't want to permanently mangle something.... Quote Link to comment Share on other sites More sharing options...
Noble Kale Posted April 16, 2002 Share Posted April 16, 2002 you realise it's much easier just to get a new nes, don't you Savers has them all the time. In fact, I'm going to brunswick & greensborough tomorrow... Quote Link to comment Share on other sites More sharing options...
ubersaurus Posted April 16, 2002 Share Posted April 16, 2002 But the supply of NESs is finite, and hence why repairing them is a good idea, so as to allow them to last as long as possible. Quote Link to comment Share on other sites More sharing options...
BIG EARL Posted April 17, 2002 Author Share Posted April 17, 2002 If you want to try and get rid of the flashing screen without buying a new 72-pin connector try getting a NES cleaning kit or Disassemble it like you are going to replace the connect and then Get an old toothbrush, did it in rubbing alcohol, stick into the slots where the cartridge is inserted and carefully scrub. Just make sure that the unit is unplugged and try not to let too much run onto the main board and let it dry completely before plugging it back in. I just did this on another Nintendo I just bought and it works now. I found a site with some good NES info, it is NES Player and as far as Savers goes, I have seen 3 Nintendos at our local Savers and all 3 did the same thing, nothing but a flashing screen. I haven't seen any of the new style NES anywhere. I plan on visiting a Funcoland to see what kind of stuff they have this weekend. Quote Link to comment Share on other sites More sharing options...
Stroxalarb Posted April 17, 2002 Share Posted April 17, 2002 Noble Kale: Savers in Frankston is where I got the NES from......it's my first one......I haven't had a chance to try any of these solutions yet.... Quote Link to comment Share on other sites More sharing options...
KAZ Posted April 21, 2002 Share Posted April 21, 2002 Not sure if this might cause damage to cartridges or the console, but this is what I do.... Say you have a blinking screen after you stick in a cartridge and press power..... I just leave the cartridge in, and gently push it to the right or the left while it is still inside the console... Press reset, and the game has a good chance of working. I'm sure mine has connector problems too, and probably need cleaning too. This has worked for me for so long, it kinda became a habit I guess Quote Link to comment Share on other sites More sharing options...
Uncle Duke Posted April 21, 2002 Share Posted April 21, 2002 Hey everyone, I tried fixing mine by the whole pin thing, I found the classic gaming article on doing this, very vague, I dont know about anyone else. I currently (had) have two NES systems, I first tried it on one. I think I bent it way to far. Then the second I just slightly bent it and now my NES works, "Better" but I still have to blow in the games. The thing I worry about it if I was even bending the right thing. Now I see these little mettalic loop things at the front top of the connecter. I got a screwdriver and they are kind of a U shape well more of a square U. I lifted the top end of U up and kind of puffed them up. I saw little square holes above the pins, Im not sure what else to do to get it to work. Quote Link to comment Share on other sites More sharing options...
Stroxalarb Posted April 26, 2002 Share Posted April 26, 2002 I bought two more NES's yesterday (aswell as two Sega MD's) each for AU$4. I hope at least one of them works........otherwise I'll have to hack em all up and find out what's wrong....... (BTW: I also bought a brand new Pal SNES mint in it's box if anyone is interested....otherwise I'll chuck it on ebay.) Quote Link to comment Share on other sites More sharing options...
Noble Kale Posted April 26, 2002 Share Posted April 26, 2002 heh. well, I bought my nes from dandenong. the reason: they have little 'parts' packages. Mine included: the nes, the switchbox, the power cords, two controllers, a zapper & 2 games. all for $5 (I bought it on one of their many 50% off days...) Quote Link to comment Share on other sites More sharing options...
Stroxalarb Posted April 29, 2002 Share Posted April 29, 2002 Noble Kale: Have you been to the Brunswick Savers lately?? Someone got there before me and cleared everything out (not a single game of any type), and only some NES and MD hardware......*sniffle* Quote Link to comment Share on other sites More sharing options...
Stroxalarb Posted April 29, 2002 Share Posted April 29, 2002 I also buy lots of stuff from Dandenong too.....I like those packages......though I can never find the time to travel the 120km to get to Dandenong (it was a lot easier when I lived there ) on a day when they were having a sale....... Quote Link to comment Share on other sites More sharing options...
