+atari2600land Posted June 22, 2006 Share Posted June 22, 2006 Could you convert the code on www.alienbill.com/2600/basic/music to having line numbers? I tried and this is as far as I got: 10001 b=$FF 10002 c=0 10003 dim tempaudv=t 10005 AUDV0=0 10006 AUDC0=6 10009 if c=0 then goto 10012 10010 c=c-1 10011 goto 10009 10012 b=b+1 10013 AUDF0 = musicData[b] 10014 t=8 10015 if musicData[b] = $FF then t = 0 10016 AUDV0 = t 10017 b = b + 1 10018 c = musicData[c] 10019 if b > 31 then b = 16-1 10020 return 10025 data musicData 4,30,5,30,6,30.7,30,8,30,9,30,10,30,11,30 end And I got a whole bunch of error messages when I compiled it. I had to change the dim musicTimer, etc. to letters because I got even more error messages when I compiled it. All I want is 7 notes played in AUDC=6. I don't care which ones, I can change them later. Quote Link to comment Share on other sites More sharing options...
+batari Posted June 23, 2006 Share Posted June 23, 2006 10025 data musicData 4,30,5,30,6,30.7,30,8,30,9,30,10,30,11,30 end [/code] The only error I see is in the above line, where there is a dot (30.7) when I think there should be a comma (30,7). Quote Link to comment Share on other sites More sharing options...
MausBoy Posted June 23, 2006 Share Posted June 23, 2006 The b and c variables make no sense to me - b = 16 - 1 ? What's that supposed to do that b = 15 won't? I can't follow this code at all... Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted June 23, 2006 Author Share Posted June 23, 2006 10025 data musicData 4,30,5,30,6,30.7,30,8,30,9,30,10,30,11,30 end [/code] The only error I see is in the above line, where there is a dot (30.7) when I think there should be a comma (30,7). I changed it to a comma, and I got one repeating noise going da-da-da-da-da-da really fast. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted June 23, 2006 Share Posted June 23, 2006 The b and c variables make no sense to me - b = 16 - 1 ? What's that supposed to do that b = 15 won't? I can't follow this code at all... Although I don't understand what it does, the original code has a '#-1'. Comparing atari2600land's code to the original, it looks like that's the line that was changed. Original code from http://www.alienbill.com/2600/basic/music: dim musicPointer=a dim musicTimer=b dim tempaudv=t rem VOLUME DOWN AND SET CHANNELS AUDV0=0 AUDC0=DISTORTION rem INITIALIZE POINTERS AND TIMERS musicPointer=$FF musicTimer=0 startLoop rem TIME TO UPDATE NOTE? if musicTimer = 0 then gosub changeMusicNote musicTimer = musicTimer - 1 drawscreen goto startLoop changeMusicNote musicPointer = musicPointer + 1 AUDF0 = musicData[musicPointer] tempaudv = 8 if musicData[musicPointer] = $FF then tempaudv = 0 AUDV0 = tempaudv musicPointer = musicPointer + 1 musicTimer = musicData[musicPointer] rem value is (2 * #_OF_NOTES) - 1 if musicPointer > (2 * #_OF_NOTES) - 1 then musicPointer = #-1 return data musicData LIST OF FREQUENCY, LENGTH Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted June 23, 2006 Author Share Posted June 23, 2006 So do I put a # in the code, or does it represent a number? Quote Link to comment Share on other sites More sharing options...
