Atari Video Music
Ze_ro
oh .. i could need a manual copy too ;)
Major necro-bump, but I see you are still active on the forums. I have the manual for mine, but I think it is a bit larger than my scanner. I will try to get a decent scan done this evening, but if I have to stitch images it may take a while.
P.S.
Took me 8 years to find a decent unit. I got one in the original box complete with Styrofoam inserts and even the desiccant package a few years ago for around $250.
think my unit is defective.. from the (very poor) diagrams of the AVM on the web i can see the CPU has alot of inputs, from controls etc., and some clear outputs to the modulator. I'm not seeing anything like what i should see on those outputs in any sort of repeatable or predictable fashion. Sometimes i can get something that makes sense, but the lack of consistency is making it hard to make a call on what's the right or wrong thing to do. i think tying all the lines to the modulator together via pots to make composite would be the way to go for a quick test, only as i said, i think my unit is flaky at best. I'll try this next time i have free, then if i still get nothing, it's mothballs for the unit which is in suspiciously perfect cosmetic condition.. (You all know what that means!!)
i did build another longhorn engineer modboard, the newer design, but it's not alot of use in this case - going to put that in my light sixer to replace the ugly old one i did years back..
Oh, i do see residue on the web of a circuit-bent AVM with composite out that went for sale a while back - it looks lovely in fairness, and after being inside this thing, it's VERY easy to bend, and quite safe too. if i ever get this displaying, it will be modded for sure.
  • 3 weeks later...
I was about to post a thread about this in the classic gaming forum,but good thing I checked here.
I was watching one of my all-time favorite movies the other day called Over the Edge(1979) and there's several scenes where the characters are looking at a tv screen with the AVM turned on and in full effect. Like in this scene...
I had no idea what it was until a good friend of mine pointed it out to me just last night.
http://en.wikipedia.org/wiki/Atari_Video_Music
Really interesting. I really love the history behind that.
How many of these were produced exactly?
So you just connect it to your tv and stereo and the sounds influence the shapes on the screen?
It seems like Atari used this same concept with the Atari Jaguar CD later on. Isn't there a feature in the Jaguar CD that's similar? Like when you play a music CD it makes some psychedelic patterns on the screen.
Yes to both.
1st - you just connect audio-in to the Atari Video Music, and then connect it to your TV. Bob Brown (creator of the home Pong) invented this in 1976. It was pre-2600 era. It is the oldest audio-reactive light-synth device that I know of.
Jeff Minter started working on similar concepts in 1981 with Psychedelia on the Vic-20. This has continued up until present day work on the PC (post X-Box 360). Yes - if you insert any audio CD into the Atari Jaguar (and later Nuon DVD players, and then X-Box 360s), you get a very cool light synthesizer.
  • 2 months later...
Hi there.
Just recovered my good old AVM from the basement for a Festival about circuit bending , music and the the likes, over here in Germany. Have been searching the web for a decent scan of the manual, but only found lousy low res scans. Does anyone got those documents and can scan them for the rest of us? ;) I will do my best and rework the scans to make decent PDF out of it so they can be reprinted.
Thanks a million.
cheers,
dan
  • 7 months later...
Yes to both.
Minter's inspiration was the AVM and it was brought up often during his work in creating the VLM for the JagCD. I know he designed the version for the XBox 360 so I'm sure he also created the version for the ill-fated Nuon.
  • 1 year later...
Ok .. I found US patent #4081829 .. March 28, 1978 which documents the Atari Video Music. It shows the IC has outputs 21 (Chroma) and 23 (Lumina) as well as Sync going to the RF Modulator. So this would be an easy pick-up .. Maybe for fun...
Rob Mitchell, Atlanta, GA
Did anyone ever adapt the 2600 composite/svideo mod to the AVM?
Has anyone done the Composite or s-video out mod on an AVM here? Looking at the diagrams is not alot of help since they are poor resolution, it's hard
to pick out some things due to blurring, but it does seem like an awful lot of the pins on the CPU are joined together after a resistor ladder on the output side -
i guess this is how they are deriving the composite to feed the modulator?
going to try building the same mod as would be used on a 2600, see if it works out..
Not sure but i have been wondering if this is possible ever sine i picked one up last year. Would definitely be cool to see a sharper picture (and not have to lug around an R/F capable CRT in order to use it)! :-D
  • 3 weeks later...
Hi,
is there any chance of a 2600 "ATARI Video Cartridge" with audio line-in and video-output through the game console?
Button functions could be replaced by controllers like for SynthCart… or buttons added to the cart.
I saw an AVM in the recent ATARI exhibition in Germany and was taken with it. The Make project mentioned above supposedly only speaks NTSC, not PAL. http://makeprojects....usic 3000/606/1
(Obviously I'm not an engineer.)
Never knew the AVM existed until reading this thread. Having used the iTunes visualizer circa 2001 on a Quicksilver G4 Mac Pro (the new visualizer on later versions of iTunes are not as good to me) I could really get into the AVM. Upon several sessions in a dark room with headphones under the right mindfulness have yielded profound insights to music and really is useful as a mind expansion tool.
  • 5 months later...
  • 1 month later...
yeah, i had already tried that (well thru a DVD recorder)
but there was more interference than display.
managed to replace the RF lead with an "Atari 800XL RF lead" - the ones with the small oblong box
- and hey! presto! - lovely picture.
nice bit of kit that looks great on a nice big widescreen TV
it's been throwing out some nice stuff in response to "Kashmir" "Hotel California" and I started to think that the frenetic impulses created from "Hocus Pocus" would make it explode
Edited by Guest
