Pacman help please
9 replies to this topic
#1 BornOfFire OFFLINE
BornOfFire
    Combat Commando
  • 2 posts
Posted Thu Nov 2, 2006 3:17 PM
I recently installed a sit down Ms Pacman machine in my store and heard there was a code book that would allow the game to play in turbo, play as regular Mr. Pacman, extra lives, and more. Been searching the internet and just can't find it. I have read thread about people talking about a secert manual with all this stuff in it, but can't find it. Could someone please help. Thank you
#2 Brian R. OFFLINE
Brian R.
  • 2,573 posts
Posted Thu Nov 2, 2006 3:53 PM
You might want to ask in the arcade coin-ops forum. May be a better chance of finding someone there who can answer this.
And welcome! :)
#3 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,897 posts
Posted Sat Nov 4, 2006 3:47 PM
No code book...but the game's DIP switch settings allow you to change the speed and number of reserve lives. Of course, you'd need to be the machine owner to access these toggle switches. Playing M.A.M.E. at home allows you to change them (as well as a plethora of other cheating options).
#4 BornOfFire OFFLINE
BornOfFire
    Combat Commando
  • 2 posts
Posted Sat Nov 4, 2006 3:53 PM
I heard from the guy who gave me the machine that there is a manual that has codes to play the orginal pacman on the ms pacman machine and also play in turbo mode and others. I thought if i search the internet i could find it. All I found was this http://www.toolprice.../product/7787XX which says this "FREE- I will include a "secret" service manual that contains "cheat" codes for free lives, extra games, and hidden settings (like "super speed") in Ms Pac-Man (a $39.95 value FREE)" Someone at my shop said they saw someone playing the machine in turbo a couple of days so I know its out there.
#5 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,897 posts
Posted Thu Nov 9, 2006 4:55 PM
News to me. But I still think it's complete bunk. Dav?
#6 jbanes OFFLINE
jbanes
  • 3,080 posts
  • Coming soon to a natural satellite near you...
Posted Thu Nov 9, 2006 5:00 PM
FREE- I will upgrade the video card to a super VGA (a $300 value FREE)
Sounds like either a MAME reproduction cabinet, or a scam. If it's the former, then the "codebook" would simply tell you how to mess with MAME.
#7 Dav OFFLINE
Dav
    Moonsweeper
  • 353 posts
Posted Wed Feb 7, 2007 11:11 AM
If he has the ms pac/galaga aniversary edition then yes there is a joystick code to play regular pacman and the speed is adjustable in the dip menu.
If you have the original ms pacman you can play pacman by removing the ribbon cable that goes from the 40 pin cpu socket to the ms pac daughterboard. Remove the cpu from the daughterboard and place in the main boards now empty cpu socket. The graphics will be a little off but you'll be playing pacman :)
To change the speed on the original one you will need a replacement rom called a speedup chip. The difficulty setting will speedup gameplay also if it's too easy for you. In mame it lists it as a dip switch but on an actual board it's actually a solder pad you'll have to solder.
I don't usually read this forum any more ;) I'll try to check it more often.
#8 awace OFFLINE
awace
    Dragonstomper
  • 551 posts
Posted Sat Jul 14, 2007 6:00 PM
REMOVED LAME POST
Edited by awace, Sat Sep 6, 2008 10:56 AM.
#9 awace OFFLINE
awace
    Dragonstomper
  • 551 posts
removed lame post again.
I think once you enter up up down code and get into pacman you can enter dip switch mode once in pacman to set pacmans dip settings...? I dont know i dont have a reunion pcb.
Edited by awace, Thu May 28, 2009 2:58 AM.
#10 awace OFFLINE
awace
    Dragonstomper
  • 551 posts
Posted Sat Sep 6, 2008 10:54 AM
1981 with Namco! If game is on coin play, insert a coin(s) to add a credit.
Press any start button. The "start" screen will display, allowing you to choose Ms. Pac-Man or Galaga.
Make the following moves with the joystick:
UP, UP, UP
DOWN, DOWN, DOWN
LEFT, RIGHT, LEFT, RIGHT, LEFT
P1 (START!!!!!!!!!!!!!)
If you did it right, you'll START PLAYING PACMAN
UP, UP, UP
DOWN, DOWN, DOWN
If you did it right, you'll see Blinky- the red "ghost"- turn from red to pink ("Pinky"), and hear a corresponding series of tones from the game ("extra life" tone). @ THIS POINT THEN ENTER THE SETTINGS MENU W DIP OR BUTTON!
THEN REBOOT THEN LEAVE IN MSPACMAN/GALAGA MODE THEN RE ENTER DIP MODE CAUSE ITS NOT THE SAME AS PACMAN.
GOOD LUCK!
Press either 1 player or 2 player Ms. Pac-Man button to play regular Pac-Man. The regular Pac-Man game will display and play on the screen.
Edited by awace, Thu May 28, 2009 2:57 AM.
