    4,249
    2,525
    1,750,688
DVD Audio
atari2600land
I've read the Wikipedia page on DVD Audio and it says that the maximum it can hold 8.5 gigabytes of audio. How many minutes of music is that? The reason I'm asking is because I want to make a song longer than Robert Rich's "Somnium" album (google it. It's quite interesting, haven't heard it yet, but the story of it is interesting.) which is 7 hours long. I'm wondering how much sound I can fit onto a disc and still make it be read by some type of computer. For example, if I put a DVD audio into a DVD player, would it play just audio? Or would I have to get a special DVD Audio player? And I guess the second thing that I would have to consider is how to burn something like this. I'd have to get special software (per the Wikipedia page), but I don't know how much that would cost. Would the amount a disc can hold vary with audio quality? I'm using Audacity to make the very long music file. I don't know much about the audio file, except that it says it's 8000hz and 32-bit float. But if I reduced the number of hertz, it would play slower. So anyway, I'd like some help as to if I can even do this at all.
3 Comments
At uncompressed CD quality which is 44.1KHz/16-bit stereo, 8.5gb (which would be a dual-layer DVD) is about 14 hours of PCM audio. If you use DVD-Audio lossless compression you should be able to increase that by 40-50%. If you're able to use AC3 compression (standard DVD-Video compression) at a decent 192kbps, you can get upward of 90 hours on there, though I don't know if you have to include a dummy video track which would eat some space.
I don't think either DVD format, video or audio, will handle 32-bit float audio data or 8KHz audio. That's some high-resolution sampling for rather low-quality audio (highest frequency that can be represented is 4KHz). You'll probably have to convert to a different format before making a DVD, regardless of which codec you use.
If you're using Audacity, I assume you're working in stereo or mono and not, say, 5.1 surround sound, which would take much more space.
(I used to make CDs with 20 hours of heavily compressed FM-quality music for my car stereo all the time, so I've thought a lot about this stuff.)
Share this comment
Well, I don't know how to change the sampling rates with Audacity. So I could get about a 14-hour long song on one DVD? I'm using Audacity, and so far the song only has two tracks, both I think are mono but they could be stereo. One track is the main song and the other track is extra noises and stuff.
Share this comment
To change the sampling rate in Audacity you just choose Tracks, Resample from the menu, and enter a number. But don't do that unless it turns out you have to, because you'll lose quality if the new number is lower, or use more disk space for no better quality if it's higher.
Audacity will also convert mono to stereo (you can even add a little artificial separation to simulate real stereo) and overlay tracks. I can't say I've ever done a 14 hour project in it, so you may run into its limitations, whatever they may be, but I've done 2-3 hour projects with it and things were still smooth.
Share this comment
