Four Fast Paddles
Reading a paddle on the 2600 is a pain. Reading all four paddles on the 2600 is an even bigger pain. I think I've come up with an approach that will mitigate things somewhat. This technique requires knowing the magic index value for the current scan line; these values go "0 1 0 2 0 1 0 3 0 1 0 2 0 1 0 4" etc. corresponding to what bit in a gray code should be flipped. If the magic index value for a scan line is known, reading all four paddles takes 26 cycles; if it's not known, it takes 32 cycles.If the magic index value is known:
; Assume the magic index value for this line is 2. ldx #127 ; Any value 64-127 will work; if X already contains such a value, save 2 cycles (and avoid trashing X!) lda INPT0 cpx INPT1 ror cpx INPT2 ror cpx INPT3 ror eor pscratch+2; Magic index value sta pscratch+2
26 cyclesIf the magic index value is not known (assume scan line counter in Y)
ldx #127 ; Any value 64-127 will work; if X already contains such a value, save 2 cycles lda INPT0 cpx INPT1 ror cpx INPT2 ror cpx INPT3 ror ldx PADDLEOFS,y; Get magic index value eor pscratch,x sta pscratch,x
32 cyclesNot a humongous gain over other polling methods, but it may be helpful nonetheless. Note that the pscratch will not hold 'directly usable' values; they must be converted to useful form outside the kernel. Assuming 7-bit values, the code for that is something like:
lda #16 eor pscratch+6 sta pscratch+6 eor pscratch+5 sta pscratch+5 eor pscratch+4 sta pscratch+4 eor pscratch+3 sta pscratch+3 eor pscratch+2 sta pscratch+2 eor pscratch+1 sta pscratch+1 eor pscratch sta pscratch ; Now convert paddle positions to values ldx #3pqlp: asl ; Clear LSB asl pscratch+6 rol asl pscratch+5 rol asl pscratch+4 rol asl pscratch+3 rol asl pscratch+2 rol asl pscratch+1 rol asl pscratch rol sta paddles,x dex bpl pqlp lda #0 sta pscratch sta pscratch+1 sta pscratch+2 sta pscratch+3 sta pscratch+4 sta pscratch+5 sta pscratch+6
A bit bulky, but not unreasonable. And the extra cycles in the kernel may make it worthwhile.
