    16
    28
    31,073
Hex to Ascii String
Omegamatrix
I saw a topic on 6502.org about converting byte to hex string. I remembered Lee Davison's code shorts about converting 0 to 15 to ascii 0 to 15 by using decimal mode. I know Lee passed along this year so RIP Lee, I didn't know you but you seemed like a genius to me. :)
Using his basic code I came up with this for converting a byte:
;HEX to ASCII;  A = entry value  sed        ;2  @2  tax        ;2  @4  and #$0F   ;2  @6  cmp #9+1   ;2  @8  adc #$30   ;2  @10  tay        ;2  @12  txa        ;2  @14  lsr        ;2  @16  lsr        ;2  @18  lsr        ;2  @20  lsr        ;2  @22  cmp #9+1   ;2  @24  adc #$30   ;2  @26  cld        ;2  @28;  A = MSN ASCII char;  Y = LSN ASCII char
I ran a short test program for all values and it passed. Twenty eight cycles is not too bad. It's kind of a cool way to convert a byte like this. This could make for a nice project for communicating out of the 2600 I/O port and displaying to a LCD panel in useless but fun way. Maybe you could have two 2600's with the LCD in between them to see the bytes fly by. ;)
Just need to make a conversion routine from ASCII back to hex.
Edit: Came up with this off the top of my head. Tested it for a few values and seems to work. It can only handle ASCII '0' to '9', and 'A' to 'F' (capitals).
;ASCII to HEX;  A = MSN ASCII char;  Y = LSN ASCII char    cmp #$39+1      ;2  @2  bcc .highNybble ;2³ @4/5  sbc #7          ;2  @6.highNybble:  asl             ;2  @8  asl             ;2  @10  asl             ;2  @12  asl             ;2  @14  sta temp        ;3  @17  tya             ;2  @19  cmp #$39+1      ;2  @21  bcc .LowNibble  ;2³ @23/24  sbc #7          ;2  @25.LowNibble:  and #$0F        ;2  @27  eor temp        ;3  @30 worse case, 28 best case
