Sign in to follow this
  • comment
    3,267
A Setup change
Zsuttle
blog-0188185001434737283.jpgAfter looking around for quite some time i found that shelves did not exist for a console setup that I wanted. The wall is shaped like so:
C
B **
A **
For the past week I have designed shelves that will work and fit to individual consoles
Section A will hold 12 of the smaller consoles.
B will contain the switch boxes for the consoles
C will have room for 24 larger consoles.
This is the list of consoles and av best outputs without modding.(correct me if i'm wrong)
On the far right side are the consoles i currently own and do not
Gray=not compatible
Green=best output
yellow=other outputs
red=no av output
I believe the largest is the Atari 5200(again,correct me if i'm wrong)
1 Comment
SNES and Genesis and Turbo have RGB output without modding. Turbo requires some custom cable and pin headers for A/V, in addition to amplification circuits for RGB though, and cannot output RGB with the CD attached.
Share this comment
