    650
    2,609
    872,048
CollectMini source code
Here's the source code for CollectMini.
CollectMini.zip
It's a little different from the source available on my site as I've made some minor changes to the comments.
The presentation was received well; though going over the code, even simple as it is, caused me to run short on time. So I'll need to come up with a new plan of action for next time.
COLLECT TUTORIAL NAVIGATION
<PREVIOUS> <INDEX> <NEXT>
5 Comments
Good Morning!
sta.wx HMP0,X ; 5 19 -
(.wx)- Is this storing a 16 bit word into an 8 bit register? Is this indexing the accumulator?
Share this comment
If you check the opcode chart you'll see there's 7 different addressing modes for the STA command. Normally we let dasm decide the proper addressing mode and for:
 sta HMP0,x
it would pick Zero Page, X because HMP0 is a zero page address. Of crucial importance for 2600 coding, we know that'll take 4 cycles of processing time.
Dasm has a feature known as .FORCE (or Force Extension) which allows you to override the compiler and force a specific addressing mode. The code
 sta.wx HMP0,x
tells dasm to compile the instruction using the Absolute, X addressing mode, which takes 5 cycles of processing time.
It was done because the following command:
 sta RESP0,x
needed to finish at exactly cycle 23, but the routine was 1 cycle short on time. There's no version of NOP that takes only 1 cycle, so by forcing a different addressing mode we can make an instruction use an extra cycle.
That bit of code could also have been written like this to get the same results:
        sta HMP0,X     ; 4 18 - store fine tuning of X
        sta.wx RESP0,X ; 5 23 - set coarse X position of object
Share this comment
Ah... so .wx is forcing a 16 bit address, not a 16 bit word.. And in this case, the page will be zero, your just specifying it to waste time.. Thanks!
Share this comment
