Starfield returns, new station cores
Starfield's back. New station cores are in place, they look awesome!
As a reminder, this is what they looked like in the DPC+ version:
Due to TIA limitations, the station cores may not always be drawn in red when 2+ are shown in the same horizontal zone. In this screenshot taken with phosphor mode on:
you can see how flicker logic causes the rightmost station's core to change colors because on some frames it must be drawn using a missile instead of the ball.
Also note that there's some slight hiccups I still need to track down, such as the cores become misaligned as they scroll off the top of the screen:
Left Difficult A shows time-remaining in Vertical blank and Overscan:
For Harmony on a 2600*
draconian20170523.bin
* we discovered an issue with Fast Jump that required an update to the Harmony/Melody driver as well as Stella's implementation of it. As such, you'll need Stella 5.0.0-pre8 or newer, which isn't available yet. For those of you using OS X, I previously posted a pre_pre8 build that'll work with Draconian
5 Comments
