Sign in to follow this
    14
    2,851
S.O.P. Track 10 - Brandenburg Concerto No. 3 In G Major-1st Movement
k-Pack
A major rewrite of the Arduino/Atari communication software was accomplished.  It seems the Cassette Motor Control pin causes a spike when it switched.  (You can hear it in some of the previous tracks.)  BIT 7 of PORTA has been configured for output.  Joystick 2 trigger can be used as BIT 7 if its ever needed.
It took a couple of weeks of software trouble shooting to figure out that the hardware was the problem.  The output power from the CMC was enough to trigger the optocoupler but the power from the joystick port was not.  A resister was changed and the software seemed to be working the way it should.
There still seems to be a click but is a little less noticeable.
Sorry, I wasn't going to get technical.
Brandenburg no3 First Movement.mp3
NOTES:
Music File origin:    BRAND.MUS - thanks to unknown person
                                  TRACK10.MUS - Recorded
Control Computer: 130XE
      Sequencer Software:  MIDI Music System by Lee Actor
                 Voice 1 - PAT5
                 Voice 2 - PAT6
                 Voice 3 - PAT7
                 Voice 4 - PAT8
      MIDI out: MIDIMAX
Sound Source:
       Atari 130XE (#2)
           MIDI in: Arduino Software:  MONOSYN_1-Byte_Data_rC.ino
           Monitor output to mixer
           Software: ADSR0D.M65  (recompiled for voice settings)
                                                        (.Included READMIDC.M65) -
                                PAT5.OBJ
                                PAT6.OBJ
                                PAT7.OBJ
                                PAT8.OBJ
                              Loaded from ATARIMAX Cart.
Mixer:  Behringer Xenyx 1202 FX
              Mic One input - Atari  monitor port
              FX :  #3  MID HALL 1
Recorder:  PC - Audacity 2.1.2
                           File: Brandenburg no3 First Movement.aup
                           - Sync tracks and trim
TRACK10.atrTRACK10.atr
