    36
    18
    33,679
Starfield - Attempt #1
tschak909
Evening fellas,
I took my first crack at a starfield tonight, it still needs a _CRAPLOAD_ of work, the stars flicker, but I do know my technique will work with the proper timing. I will try to tie VCOUNT in and see if I can carefully time the stars to appear on the correct scan lines without flicker, I'm going to try to keep stars down to one per line..maybe I can make something look good... if worse comes to worse, I will try to use two missiles for this, but I don't want to waste precious sprite space at this point.
-Thom
tapper.zip
