A new 7800 project... nothing major...
PCBs are designed, created, and already shipped headed my way as are a few components for me to populate the boards. I will go into more details once I have my PCBs and have been able to test and check out if my idea works the way I've planned or not. In the meantime, here is a pic of the PCB. If you are familiar with the UAV layout and install process needed for the 7800, then this should be obvious on what it is.
While what you see here is rather large, in reality it is only about the size of the UAV board so roughly 24mm tall and about 33mm wide. Pretty small.
- 2
