    650
    2,609
    872,048
Fixed the jitter
Sign in to follow this
Before the fix, when three AI players were alive, INTIM would have 1 +/- remaining at the end of VB when one fireball was in the air. When the second fireball was released there would often be insufficient time and the screen would jitter.
After the fix, with three AI players alive, INTIM has 7 +/- remaining when one fireball is in the air, 5 +/- when two are in the air and 3 +/- when three are in the air.
What's amazing is this was accomplished by commenting out a single line of source code!
Back in March, vdub_bobby suggested I use this routine to solve my object positioning problems:
PosObject
  sec
  sta WSYNC
DivideLoop
  sbc #15
  bcs DivideLoop;+4	4
  eor #7
  asl
  asl
  asl
  asl		  ;+10  14
  sta.wx HMP0,X;+5   19
  sta RESP0,X  ;+4   23
  sta WSYNC
;   sta HMOVE
  rts
I commented out the HMOVE because I positioned all 5 objects in a row like this:
		ldx #0
	lda Player1X,x
	jsr PosObject; position P0
	inx
	lda Player1X,x
	jsr PosObject; position P1
	inx
	ldy Player1X,x
	iny
	tya
	jsr PosObject; position M0
	inx
	ldy Player1X,x
	iny
	tya
	jsr PosObject; position M1
	inx
	ldy Player1X,x
	iny
	tya
	jsr PosObject; position BL
	sta WSYNC
	sta HMOVE
I commented out the 2nd WSYNC, like this
PosObject
  sec
  sta WSYNC
DivideLoop
  sbc #15
  bcs DivideLoop;+4	4
  eor #7
  asl
  asl
  asl
  asl		  ;+10  14
  sta.wx HMP0,X;+5   19
  sta RESP0,X  ;+4   23
;   sta WSYNC
;   sta HMOVE
  rts
which bought me back about 5 scan lines worth of CPU time.
12 Comments
What happens if objects are near the right edge of the screen? I don't think there's time after a near-right right RESP0 to RTS, bump X, load Y, increment it, JSR, and set carry, all before the next WSYNC deadline. I can't see how you'd avoid using two scan lines per object much of the time, nor how you would have been using more than that with the extra WSYNC in there.
My inclination would be to expand out the motion routine to eliminate the JSR/RTS and indexed operations. This should allow the WSYNC for the next horizontal loop to run without wasting a scan line first.
Share this comment
Hmm, good point. One object will always be on the left, but it's possible for the other 4 to be on the right edge at the same time. I'm running out of room to expand the code in the VB bank, so I've moved this code to the bank that handles "top castles". That'll let me remove the JSR/RTS and indexed ops.
Share this comment
You could also rewrite the positioning code like this (untested):
PosObjectSubroutine
  ldx #4
  sta WSYNC		;------begin line 1
  SLEEP 3
  sec			  ;+5	5
PosObjectLoop
  lda Player1X,X   ;+4	9
DivideLoop
  sbc #15
  bcs DivideLoop   ;+4   13
  sta TempRAM,X	;+4   17
  sec			  ;+2   19
  sta RESP0,X	  ;+4   23
  sta WSYNC		;+3   76	begin lines 2, 3, 4, 5, 6
  dex			  ;+2	2
  bpl PosObjectLoop;+3	5
				;	  4
  ldx #4		   ;+2	6
FinePosLoop
  ldy TempRAM,X
  lda HMOVETable,Y
  sta HMP0,X
  dex
  bpl FinePosLoop  ;+17  23, 40, 57, 74, 14 (of line 7)
  sta WSYNC		;------begin line 8
  sta HMOVE
  rts
Just a hair over 8 scanlines. Need a 15-byte table of HMOVE values.
Share this comment
Even works without a table:
 lda TempRAM,X
 eor #$07
 asl
 asl
 asl
 asl
 sta HMP0,X
Untested. :lol:
Share this comment
 lda TempRAM,X
 eor #$07
 asl
 asl
 asl
 asl
 sta HMP0,X
Untested. :lol:
Well sure, but then it takes *way* longer. :)
Share this comment
don't have my op code notes handy, though I suspect the ASL method would take an extra scan line.
Thomas - weren't you into the C= 64? Did you happen to watch the video I posted of my BBS software in action?
Share this comment
I think just an extra half a scanline.
Since the routine ends with WSYNC/HMOVE, unless you have something useful you want to stick before that WSYNC it's going to be a whole scan line.
Share this comment
Takes longer than the original normally takes; however, it doesn't take as long as the original's worse case scenerio. Also uses less ROM to boot!
Share this comment
A few extra cylces, yes.
BTW: Depending on the minimum and maximum possible positions, you may be able to set HMxx directly after the DivideLoop.
Nope, must have missed that. Link?
Share this comment
The HMxx can always be set for the left side player, but for the other 4 objects it depends on their screen location. The old routines tried to set it each line and the time remaining in INTIM would vary from $06-$0A when one fireball was active and there were 3 AI players. If the 2nd fireball came out the time remaing would run out if enough objects moved to the right. The new way isn't as fast as the fastest of the old routine, but it's not as slow as the worst case which is a plus.
The video's in the next blog entry
Share this comment
