Mord's Blog
    170
    93
    98,669
Display Code Yet Again.
Sign in to follow this
Mord
I've been trying to build up the scanline pairs for the first stage, the rest of it after that is generally an issue of copy/paste with a few modifications. I was topping out in cycles again so looked for ways to remove things from the kernel without removing anything from the kernel. I think I managed to do that although it cost a couple bytes of ram. By doing this it also freed up a lot of color selection choices for the playfield alterations.
As a result, hopefully I'll have version 0.009 written and if nothing else in the debug stage this weekend. :)
*update*
Now started on writing the display code proper. Got a long weekend, so in amongst cleaning out the game collection to see what works and what doesn't. (I'm not quite as Pro Quality as my apartment tells me I should be :ponder: ) I may take the Model II genesis down to the local pawn shop if I can confirm it works and I have enough spare connectors for my Model I genesis and the like. A few other odds and ends that might get traded in as well. I noticed they had a "Heavy Sixer" for sale down there, but after getting a closer look at it, it looked to be a CX2600 instead. Not too surprised I guess. I may just trade those things in for some more 7800 and/or 5200 carts depending on what they have at the time. I'm already up to 8 games for the 7800. I don't see them very often.
As for the mentioned saved cycles above, I was altering the playfield color slightly in the hopes that it'd stand out a little more in the room. So we'd have 2 colors altering instead of just one for the entire screen. Is it really necessary? Not really. But darnit I wanna see it. ;)
 lda PFColor
 eor #00001100
 sta PFColor
This is what I was doing every scanline. This format would keep the two altering colors the same hue but just vary their lum values slightly by toggling the same bits back and forth. I had bit 1 kept at 0 to make sure I could set it as a 1 and then use that for enabling missiles and the ball. That restriction saved the need of setting up the register since I always enabled the missiles or ball immediately after setting the playfield color. (Can't vdel the missiles after all.)
By adding a second byte of ram, I could define PFColor_Even and PFColor_Odd instead of just PFColor. I could then set those two colors when I load the room and simply do a lda PFColor_Even or lda PFColor_Odd based on which of the two scanlines I'm in for the 2-scanline kernel now being used. from 8 cycles to 3. :ponder:
I know later on I'm going to end up with ram issues. Luckily in this game most items and monsters aren't going to be as ever-present like they are in certain other games. ;)
