    39
    57
    123,390
Ball Horizontal Control Part 2
Sign in to follow this
DanBoris
As supercat observed in my last entry, I totally missed this part the first time around. Better late then never...
_pesco_pacman_v8.zip
For anyone who has played Pong, you may remember that the more times you volley the ball back and forth, the faster the ball will move. This counter counts those volleys. Each time the ball is hit by either player the counter will increment until it reaches a count of 12, at which point it will be disabled by NAND gate E1. The counter is reset by the RST SPEED signal which we will discuss at a later date
There are three counter states that are decoded by the logic gates B1, E1 and H1.:
Counter   H1(11)		H1(3)
0-3		  0			0
4-11		 0			1
12-15		1			1
At the beginning of each video frame these outputs are gated through two more NAND gates (H1) by the VRESET signal where they are applied to the clear inputs on J/K flip-flops H2. The flip-flips are clocked by the /256H at the start or each horizontal line. When the counter is in the range of 0-3, the MOVE signal will be high for one horizontal line, in the range 4-11, it will be high for two horizontal lines, and in the range of 12-15, three horizontal lines. The more lines the MOVE signal stays high for, the faster the ball will move.
Let’s take a look at how this works for the 12-15 counter state. Initially after VRESET the Q output of both flip-flops will be low (due to the clear) which will result in MOVE being high. At the start of the next horizontal line when /256H goes high, since the J and K inputs of the first flip/flip are high, it will toggle setting it’s Q output high. The J and K inputs of the second flip/flop are both low so its state will not change. After the first clock pulse MOVE is still high. On the second clock pulse, the first flip-flip will toggle again, but since the J input of the second one is high, its output will go high. After the second clock pulse MOVE is still high. On the third clock pulse the first flip-flop will toggle again, settings its Q output high, and the second flip-flop will remain unchanged. Both inputs of NAND H4 are now high so its output goes low. The MOVE signal will now stay low until the next VRESET.
7 Comments
Seems a bit overcomplicated. If the volley counter bits are VC1 and VC2, how about computing "move" as
temp1 = /V2 or VC1 ; High is good (could use V2 nand /VC1)
temp2 = /V4 or VC2 ; High is good (could use V4 nand /VC2)
Move = temp1 and temp2 and V256 and /V1
I don't remember whether /V1, /V2, and /V3 are available. If so, MOVE takes half of a quad-2-input-OR and half of a dual-4-input-AND, eliminating six NANDs, two NORs, and two JK flipflops. If they're not available, add half a hex invertor.
This should cause a move pulse to be generated on line 256 all the time, on line 258 if VC0 is set, and on line 260 if VC1 is set.
If three velocities were desired instead of two:
temp1 = V1 nor V2 nor VC1 ; Low is good
temp2 =/V2 nor VC2
Move = temp1 nor temp2 nor /VSync
This would generate move pulses during VSync. During line 0 of VSYNC, pulses would be controlled by temp1. During line 1, they'd be on always. During lines 2-3, they'd be controlled by temp2.
Share this comment
What is the effective horizontal speed for each of the settings? If I recall, there was 455 clocks horizontally. (I don't know but I'm guessing that 320 would be visible). How many clocks/frame or pixels/frame for the horizontal movements.
I understand that MOVE stays high for one, two or three horizontal lines. Does that translate into one, two or three pixels per frame?
Share this comment
djmips,
Yes, the number of horizontal lines when MOVE is high corresponds to the number of pixels the ball will move each frame.
supercat,
It's an interesting idea, although I haven't studied it carefully, I don't think it will work because it appears you will end up with MOVE being high for to many lines. Also you still can't get rid of the NOR and 3 NANDs right after the counter since you need these to decode the number of hits that correspond to each speed range.
With that said, I do recall reading an interview with Al Alcorn at one point that said if he had to do the design again, he could probably do the same game with even fewer logic chips then the original design.
Dan
Share this comment
Well V256 is active for six scan lines, and VSYNC is active for four, so I think I have the decodes right.
As for decoding the number of hits, I think I took care of that. If 0-3 hits, then only hit on line 256. If 4-7, hit on lines 256 and 258. If 8-11, hit on lines 256 and 260 (still two hits). If 12, hit on lines 256, 258, and 260.
No doubt. But it's still neat to see what was done. I'd also be curious to see Breakout.
Share this comment
In this, what exatly are VC1 and VC2?
temp2 =/V2 nor VC2
Dan
Share this comment
Sorry, I was unclear. VC1 and VC2 are the two bits of the volley counter used for determining speed; they didn't have net labels, so I assigned them arbitrarily ("If the volley counter bits are VC1 and VC2...") Perhaps I should have called them VC4 and VC8 to keep with the other naming conventions. Does that clarify things?
BTW, I was just pondering the score circuitry. Seems pretty complex. I was thinking it would have been interesting to use a '164 (shift register) to hold the two scores, feeding it four pulses near the middle of the screen and four pulses near horizontal sync (flipping the upper and lower nybbles). There would a a latch for an inverted carry signal; on each step the data into the '164 would be the xnor of that the QH output and the latch; the latch itself would receive the nand of itself and the QH output. If the latch had an async reset (very common), that could be hit once to cause one of the scores to be incremented.
The biggest annoyance I could see with this method of score counting would be that it would be necessary to either decode a number 0-F into decimal or else use something other than a 7-segment driver chip. I don't see either of those issues as presenting particular problems, though.
Incidentally, a few other thoughts:
-1- Did Computer Space multiplex any circuitry the way PONG does with the score digits?
-2- The first home video game system was based entirely on analog circuitry; nearly all later ones were entirely digital. The first arcade systems were entirely digital, but many later ones used a fair bit of analog circuitry. Interesting, eh?
Share this comment
