Mord's Blog
    170
    93
    98,675
(Action RPG) Version 0.011
Sign in to follow this
Mord
As "punishment" for falling behind on my code, here is a zip containing binaries, screenshots, and source code for Version 0.011 of Action RPG as it stood prior to me adding in bankswitching. I'm aware of inefficient code and excessive - and not always correct - comments. ;) So anyone using the code for their own nefarious purposes keep in mind there are likely more efficient methods and don't always listen to the comments. Except with respect to the nop. It does in fact look darn purdy.
The Test Realm source is slightly more advanced than the regular rom, having the test realm's info added to it but also a slightly better recovery on collection detection for when you try to diagonally press against a wall while walking through a room exit. I'll still need to revisit that to get a real fix for the problem added. Got ideas for it so shouldn't be that difficult.
And now I'm stepping out for a sub.
