    106
    796
    139,544
Do-It-Yourself Speech
Sign in to follow this
vdub_bobby
YOU, TOO, CAN MAKE your Atari talk!
Nathan wanted a ROM that he could modify/play around with that would make the AtariVox speak, so I jumped at the chance to get coding again. Here it is:
SpeechTester20070802.bin
SpeechTesterSource.zip
The ROM currently supports up to 4 different speech strings, though only one has anything in it right now: the "go fish" from the game of the same name. :)
Switch between speech strings with SELECT, start/restart a speech string with the trigger, and reset everything with RESET.
Hmmm. Just realized I should allow using the joystick to switch speech strings. Maybe I'll change that.
3 Comments
Thanks for this - it helped me do some easy validation of my text-to-speech program. I tried using a phrase made up of dictionary words in one table and one with the same text-to-speech words in another (by purposely renaming Phrasealator.Dic.) The text-to-speech version was almost as good.
On a related subject, I took relevant parts of your source (thanks again for this) and grafted it to Supercat's 16-character demo so one could enter speech (in hex) on a 2600 to play around with sounds. I spent several hours on it last night, and the speech works but unfortunately Supercat's demo doesn't work properly on my 4-switch. Since I can't post pics, to see the screenshot (taken with a cell phone; sorry about the poor quality) you'll have to follow the link below:
http://www.atariage.com/forums/index.php?a...ry&id=82313
Of course I won't give out the binary, working or not, without John's permission. If I can get it all working, I'll modify my text-to-speech program to output the codes in hex so they could be entered without needing to convert each number.
Share this comment
If you like I'll revisit that code; it behaves differently in emulation from on a real 2600. If you ask really nicely I'll even let you have source code for it.
Share this comment
Pretty please? :)
But yeah, I've always liked this demo. I'd love to see it working on real hardware.
Share this comment
