Propeller: Atari style text driver.
Edit: No new screenies, but I've got the 128 char font table in the COG now. That means one can have a text display in only .5K of RAM. Actually less, if big chars are adequate.
The high bit now selects from either the COG font table (0), or the HUB one. The HUB one will be half-resolution, but 4 colors. Could be the same resolution, but that would impact screen memory access. Essentially, one would then have a non-linear memory mapped screen, with a line length that varies depending on the number of color chars specified. Ugh... At this very moment, it's just 4 colors total. Two for the COG chars, two for the HUB chars, for a total of 4 on screen.
Once this pass is complete, then it's back on the overlay project. I've learned a few things about timing that will probably sort the overlay matter out once and for all. If that happens, then sprites --or at the least a nice hardware like cursor becomes possible. That's really why I've left the color timing alone. Overlay is going to be easier with it being static. Gotta walk before running.
I've really been frustrated with the overlay effort. I *know* two of those Propeller video generators can be made to draw together, but I've just struggled with that a bit too much. So, I'm gonna punt and work on some other stuff I need / want to get done.
One of those things is a full on character mode driver, that uses RAM font tables, features variable text sizes and such. Here are a coupla screenies:
The multi-color one is what an Atari 8 bit text display would look like, if different color selections were permitted in the high resolution mode. The graphics code uses the same color and pixel timing as the 8bit computers do, but without the limitation on color selection. Some colors are really horrible, others are not bad. I'm eventually going to change that color timing, but not right now.
The font is lifted right from an Atari ROM, and is the 128 char international one.
Someday, when the overlay gets done, I'll be able to put the player / missile graphics right on top of that, for that A8 bit look. For now though, it's just nice to have a one byte per character, linear mapped screen to write to for debugging and other text kind of things. The memory footprint is already small, and is gonna get really small on the next revision. Ideally, the driver, font and screen memory will consume about 2K, which can be overwritten, once it's up and running on one of the 8 COGs.
(On the Prop, nothing executes from main memory. You put the stuff in main HUB ram, then fire up a COG to process it. That data gets copied to the COG, where it runs just fine, leaving the source data available for an overwrite. This is very different, but also very cool, once one gets their mind wrapped around the idea.)
That's small enough to power a second display, for debugging, while running other code on the primary one.
Today, I think I've got some time to move the font into the COG, and start work on the 4 color mode additions. It's very cool to have the Atari font on the screen. Spent a long time looking at it, and now it's back on some new hardware to tinker with!
Edit: Thought I would address why. Some have asked in the past, so here it is.
First and foremost, because it's there, it's under my control, it's new hardware at the beginning of what looks to be a long life cycle, and it's cheap. The kinds of limitations that make retro computing game art appealing are here on this chip. So, it's cool for me on that basis too. What I'm doing right now is learning, just the same way I did as a kid. Feeds the soul. So, pieces are getting put together, one by one, for greater efforts later on. My setup is portable too. Basically, I've got the chip running on a HYDRA (because that was just easy to get started with), connected to my laptop, through one of those USB capture devices. The whole works just goes into the bag, for tinkering on business travel, or when I have some time.
Modern computers are so powerful, the artistic elements exist in a plane well beyond what a single person, or perhaps a few, can leverage and enjoy. Micros, change that for the better, in terms of scale. Getting some extra colors, cramming a game into the RAM, twiddling bits, all are viable and relevant tasks that have meaning in the real world as well as in the retro / game / personal gratification one. I watch the real gurus here, and elsewhere, work their assembly magic and I fear it's going to become a lost art, leaving us with people able to leverage the tech, but never really grokking it at it's fundamental levels.
Maybe that's just me too. Either way, I'm having a good time and learning stuff I can apply lots of places. Makes for far more interesting and entertaining business travel as well.
4 Comments
