The Southsider
    81
    767
    136,842
16 Char Text
Sign in to follow this
cd-w
I have written another text kernel which displays 16 characters. This may seem pointless, given my earlier 24-char and 28-char kernels, but it has several nice features:
  1. Uses less ZP memory (46 bytes total).
  2. Shows more lines on screen (14).
  3. Text width is a power of 2 (for easy calculations).
  4. Kernel has loads of free cycles (around 40 per scanline), e.g. could have a PF image underneath.
The main reason for writing this kernel is to allow the Juno First score table to be displayed nicely on a single line, rather than split across lines. I'm planning to integrate this, together with SaveKey support, in the next release. Note that I haven't included the level number as there is no room to store this in a single page on the SaveKey.
Chris
9 Comments
I suggest dropping the slash in the zero - it's very hard to read.
(3 initials + 3 bytes for score) X top 10 = 60 - so I gather a page is 64 bytes?
Converting the score to a 2 byte value would give you 1 byte to store the level.
Another option would be to use the top 2 bits of each initial, though that would limit you to 32 levels. If the score's last digit is always 0 then you have another 4 bits available in the last nybble.
Share this comment
You could also pack the three initials into two bytes by storing the letters as 5 bits, which allows for upper-case letters, space, and dot, and maybe a few extra.
Share this comment
It looks like positions 1-9 would fit in 13 chars, and possible even 10 if you slide the 1 and the . over.
Given this, I'm wondering if a flickering 16-char routine is really that much better than a flicker-free 13-char routine? I don't know the details of the 13-char routine but I have seen a demo of it.
Share this comment
"10 CDW 123456"
Yup, fits into 13! :cool:
Share this comment
Thanks for the suggestions. Having thought about it some more, it wouldn't actually be necessary to use a 13 char routine as the kernel for the scores could be done with sprites like this:
0--101-10  or
0---01-101
However, I think I will go the 16 character route and pack in the wave number. If each initial is restricted to 32 chars (alphabet + punctuation), then I can pack three initials into two bytes and use the remaining byte for the wave number. This would then be displayed as 10-CDW-99-000000 using the full 16 char width. I'm only planning to have 32 or 64 waves in the game so this would work nicely, and the flicker isn't a big issue given the main game :cool:
Chris
Share this comment
How about using 13 characters but dropping the rank? If you display 10 scores, in order from highest to lowest, do you really need to label them 1-10?
Share this comment
But if you do that, you don't get the satisfaction of seeing your name next to #1. :cool:
How about using the Playfield and Ball to draw a nice big digit behind the score table showing the player's rank from the last game (if applicable)? A 7-segment-style digit could be done without requiring any CPU cycles during the score-digit-display kernel.
Share this comment
