The Southsider
    81
    767
    136,842
Score Kernel Revisited!
Sign in to follow this
cd-w
It seems that nobody was impressed with my 16 character kernel last time - the main problem being the introduction of unnecessary flicker! I wasn't entirely happy with it myself, but I couldn't think of a better solution at the time. However, based on batari and Manuel's comments I decided to have another look at the no-flicker 13 char text demos. The 13+2 char demo uses a neat trick of rewriting NUSIZ during a scanline to squeeze in an extra two characters (in addition to using the ball and missile sprites to draw the 13th character). This trick provides exactly what I need for my high score table:
The first part of the kernel arranges the sprites like this (P0 is set to 3 copies medium and P1 is set to 3 copies close):
0--101-10
Using the NUSIZ trick it is possible to display another copy of P1 (by setting it to 3 copies medium after the third sprite is drawn). This gives the following sprite layout:
0--101-10--1
This layout provides the necessary four-part display (Position, Score, Initials, Wave) that I was after! The spacing between the columns isn't perfect, but I think it looks good enough in the screenshot.
The attached code demonstrates this technique. I haven't actually tested this on real hardware, so I hope the NUSIZ trick works in practise (it works fine in Stella and Z26)? Hopefully everyone will agree that this kernel looks much better than my previous attempt!
Chris
9 Comments
That's absolutely fantastic, definitely worth the extra time invested here! :lust:
And yes, it works flawless on my PAL system! :cool:
Share this comment
Thanks for your suggestion to look at the 13+2 char demo - I had completely forgotten about the NUSIZ trick. Also thanks for testing this on real hardware - it is definitely a big improvement over the old version.
Chris
Share this comment
This NUSIZ trick is interesting. I wonder if this would work:
Set NUSIZ0 to two copies wide and NUSIZ1 to two copies close. After the two copies of P1 are drawn, change NUSIZ1 to two copies wide, then after two copies of P0 are drawn, change to two copies close. In theory, would something like this be possible?
101-------010
I wonder, since it would be a great way to display two three-digit scores.
Share this comment
I think you can just shift the normal 6-char over the screen border so that it wraps around with 3 sprites on each side. IIRC I possibly did that in the Dog Patch demo I posted some time ago.
Share this comment
Thanks! That's so obvious now, I don't know why I never thought of it :cool:
Share this comment
101-------010
There are four positions, relative to the reset strobe, where a player or missile sprite can be triggered (at 16, 32, 64, or 160 pixels after the strobe). The last is always enabled; the other three are controlled by NUSIZx bits 0-2. To be precise: (bit 0 and not bit 2), (bit 1), (bit 2 and not bit 0).
Player 1 could behave something like what you're after, but player 0 wouldn't.
Share this comment
