    21
    39
    19,892
[KM] Test Binary #1
Sign in to follow this
Hornpipe2
All the move and attack animations are in. I still have to do the "death" sprites and animate those, but everything that's rigged to the joystick is now working. Also, there's a little mountain background since I got sick of the old gradient rainbow. This will later become one of several different backgrounds that cycle every match.
As promised in the blog comments, I've attached a binary so players can try out the progress so far. You might want to enable Stella's "Use Phosphor" as it nicely cancels out the 30hz flicker. Try pushing the joystick in all directions, with and without the button. Enjoy, and PLEASE comment if you try it out.
EDIT: A couple of commenters have mentioned the flicker is too irritating, and SpiceWare kindly hacked my binary to make the default player colors less bright. If you get a chance, try out one or two of these alternate versions and let me know which one gives you the best tradeoff of good color vs. headache-free play. I personally like x8_x4...
EDIT2: Note to self - lowkick foot is 1 pixel short, plowkick3 needs kicking foot drawn in, and entire lowkick animation is moving players back 1 pixel.
6 Comments
Thanks for posting the binary. I just tried it out and it looks great - the animations of the characters are particularly impressive. I tested it out on a real 2600 using my Krok Cart and it works fine - the flicker is slightly annoying, but I don't think there is any way to avoid this and have such large sprites. It would be nice if the characters could move/animate a bit faster, but otherwise it is very nice. I'm looking forward to see how this develops.
Chris
Share this comment
Neat, though the flicker is pretty bad on the real thing.
I hacked the ROM and changed lum values in the color tables at FFB8 and FFC0 from xE and x8 to x8 and x4 as well as x4 and x2. For me the flicker was much more tolerable with the x4 and x2 values.
I'll PM the ROMs to you and you can post them if you'd like for feedback on the color.
Share this comment
You did nice sprites and animation. I'm big fan of fighting games.
Good luck with your project :cool:
Share this comment
Thanks! I added them to the main post. I am liking x8_x4 myself - still pretty bright, but much less irritating on the eyes.
Maybe the best solution is something like x6_x2. That's pretty mild but still has good contrast on the two gi colors.
Share this comment
I recall something else that helps to reduce the flicker - make the background have the same lum value. If you're using x8_x4 then make the background x6. That would mean changing the white outfit to another color.
Share this comment
Thanks for posting - looks and sounds great! :( The animation is much smoother than I anticipated! :cool:
Share this comment
