The Battle of Midway v0.21
This is the first release of the game that is minimally playable. You can actually sink the ships now.
Mission Accomplished
New Features:
tbom18.asm 8/3/08
- Removed HMOVE artifact from title screen using cycle 73 HMOVE.
- Time-based high-res physics engine for Zero.
- AI to control Zero flight patterns. (preliminary)
- Crash animation and sound Fx for Zero.
- Multiple vectors for AA fire.
- Detects a hole in the ship, and when the ship has been sunk.
- Added preliminary sound Fx for sinking ship.
tbom19a.asm 8/6/08
- Kernel cleanup. Changed the main kernel from a 2LK to a 1LK that makes proper use of VDEL0.
tbom19b.asm 8/7/08
- Kernel Cleanup. Changed the main kernel to use quick load masks instead of skipdraw.
tbom20.asm 8/15/08
- Preliminary ship sinking effect.
- Unwrapped the ship display kernel loop to open up 15 cycles.
- Added WaterLevel variable to display water transition in ship kernel.
- Added random changes to water level to simulate waves. (3 levels)
tbom21.asm 8/18/08
- Prevent AA fire when capital ship is sinking.
- Flashing background while ship is sinking.
- After ship sinks, new ship is displayed.
- Levels implemented. Odd levels have the Yamato Battleship. Even levels have the Akagi aircraft carrier. If you sink both capital ships, you start back at the Yamato, but you will have to bomb two holes all the way to the water to sink the ship. This pattern continues. For every two ships you sink, the next two will require that you bomb one more hole to sink it.
To Do:
- Proper physics engine for player plane, to allow for engine stalling.
- AI targeting for AA fire and Zero fire.
- Better transition between ship sunk and new ship.
- Better end of game sequence.
- Display the game level somehow. Probably in between ships.
- Squadron attacks with alert klaxon. (triple sprite enemy planes.)
- Improve sound channel multiplexing.
Known Issues:
- If you collide with the Zero, after your planes crash your new plane will be hit as soon as it appears. This should be an easy fix. I'm missing a collision register reset somewhere.
- If a bomb is falling and you press reset, the falling whistle will continue to play during the title screen.
Development Notes:
An early version of the instruction manual is included with this release. It's recommended reading if you download the binary.
The game now has levels. Here's the description of the levels from the manual.
<> Progressive Difficulty Each time you sink a capital ship, you will advance to the next level. The level determines the type of capital ship you must sink, and the number of holes required to sink it. Level Ship Holes to sink 1 Yamato 1 2 Akagi 1 3 Yamato 2 4 Akagi 2 5 Yamato 3 6 Akagi 3 7 Yamato 4 8 Akagi 4
There are still several features that need to be added. The game will get a lot more challenging. There will be at least two phases to the game. In the first phase, you will defend your own capital ship from enemy bombers. You will have to shoot the bombers down before they can drop their bombs on your ship. In the second phase, you will attack the enemy ship, which will be similar to the current demo.
4 Comments
