simonl's Blog
Sign in to follow this
  • entry
    0
    4,350
What is an XEF file?
simonl
Just in case anyone's interested, in my posting here, the attached program is capable of exporting compressed images. This is useful as a full screen VBXE standard resolution would be 80640 bytes if not compressed so it's a waste of disk/cartridge space. Currently, it uses deflate on 8kb blocks, although it will not compress a block if the compressed data comes out longer. This typically gives a 1/3 reduction in file size, but files from Amiga, C64 etc. give much better compression ratios due to the smaller palette count.
For instance, this 320x200 picture would be 62.5k uncompressed:
The PNG file is 30k, and the corresponding XEF file is 26.3k (I had to change the extension to .zip to upload):
dotc.zip
This format is currently in the less than useful position of not having an associated viewer on the Atari (although they can be previewed through the application, choose File | Open XeFlate...). I'm working on this at the moment, but if anyone would like to save me the trouble ;) or comment on the format I'm working on, here are the details.
The file is structured as follows:
* File Header *
Name              Length (Bytes)        Comment
Bits Per Pixel    1                     Either 4 or 8 depending on the mode
Graphics Mode     1                     Values:
                                         0x1F = VBXE standard
                                         0x2F = VBXE low resolution
                                         0x3F = VBXE high resolution
Image Width       2*                    Width in bytes
Image Height      2*                    Height in scan lines
Block Count       2*                    The number of blocks of data in the file
Palette Length    2*                    The number of palette entries in the file. If zero, the
                                       laoo.act palette can be assumed if the palette is not
                                       specified elsewhere.
Palette Entries   3 x [Palette Length]  The palette entries as (R, G, B) three byte tuples
* Low byte first
Then, there are [block Count] blocks, as follows:
* Block *
N.B. The data is currently compressed so that each block is <= 8kb in length when uncompresssed,
due to the 8k bank switching arrangement used by VBXE this seemed expecient!
Compression Type  1                     The compression method used:
                                         0x00 = None
                                         0x01 = Deflate
                                       Further methods will be added e.g. RLE
Compressed Length 2*                    The length of the block's data, in bytes,
                                       not including the 3 block header bytes.
Data              [Compressed Length]   The block's data
* Low byte first
The following C# snippet illustrates loading an XEF file into a Windows Bitmap:
     // Read the file header
     // Mode
     byte bitsPerPixel = r.ReadByte();
     byte graphicsMode = r.ReadByte();
     // Size
     ushort imageWidthBytes = (ushort)(r.ReadByte() | (r.ReadByte() << );
     ushort imageHeightScanLines = (ushort)(r.ReadByte() | (r.ReadByte() << );
     int width = imageWidthBytes * (8 / bitsPerPixel);
     int height = imageHeightScanLines;
     byte blockCount = r.ReadByte();
     // Palette (if specified - otherwise, assume the default VBXE palette)
     ushort paletteLength = (ushort)(r.ReadByte() | (r.ReadByte() << );
     Color[] palette = null;
     if (paletteLength > 0)
       palette = new Color[paletteLength];
       for (int color = 0; color < paletteLength; color++)
         byte red = r.ReadByte();
         byte green = r.ReadByte();
         byte blue = r.ReadByte();
         palette[color] = Color.FromArgb(red, green, blue);
     else
       // Otheriwse, use whatever colors we've currently got loaded
       palette = Atari.Colors.BrushColors;
     int x = 0;
     int y = 0;
     Bitmap result = new Bitmap(width, height, System.Drawing.Imaging.PixelFormat.Format24bppRgb);
     // Read the blocks
     for (int block = 0; block < blockCount; block++)
       // Get the compressed length
       byte blockCompressionType = r.ReadByte();
       ushort blockLength = (ushort)(r.ReadByte() | (r.ReadByte() << );
       System.Diagnostics.Debug.WriteLine(string.Format("Block {0} -> {1} bytes ({2})", block + 1, blockLength, Enum.ToObject(typeof(BlockCompressionType), blockCompressionType)));
       byte[] compressed = r.ReadBytes(blockLength);
       byte[] decompressed = null;
       int decompressedLength = 0;
       // On Atari - switch in the correct bank from VBXE memory and decompress to there
       switch (blockCompressionType)
         case 0x00:
           // Uncompressed - copy straight to VBXE bank
           decompressed = compressed;
           decompressedLength = blockLength;
           break;
         case 0x01:
           // Deflate - http://atariarea.krap.pl/x-asm/inflate.html
           decompressed = new byte[0x2000];
           using (MemoryStream ms = new MemoryStream(compressed))
             ms.Position = 0;
             using (DeflateStream ds = new DeflateStream(ms, CompressionMode.Decompress, true))
               decompressedLength = ds.Read(decompressed, 0, 0x2000);
               ds.Close();
           break;
       #region Plot the data on the bitmap (obviously redundant on Atari!)
       for (int i = 0; i < decompressedLength; i++)
         result.SetPixel(x, y, palette[decompressed[i]]);
         x++;
         if (x >= width)
           x = 0;
           y++;
       #endregion
     #region Set the pixel aspect ratio (or set the XDL on Atari!)
     switch (graphicsMode)
       case 0x1F:
         // Vbxe standard
         break;
       case 0x2F:
         #region Vbxe Low Resolution - rescale to 2 x width
         Bitmap scaledUpBitmap = new Bitmap(result.Width * 2, result.Height, result.PixelFormat);
         using (Graphics graphics = Graphics.FromImage(scaledUpBitmap))
           graphics.InterpolationMode = System.Drawing.Drawing2D.InterpolationMode.NearestNeighbor;
           graphics.CompositingMode = System.Drawing.Drawing2D.CompositingMode.SourceCopy;
           graphics.CompositingQuality = System.Drawing.Drawing2D.CompositingQuality.HighQuality;
           graphics.PixelOffsetMode = System.Drawing.Drawing2D.PixelOffsetMode.HighQuality;
           graphics.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighSpeed;
           graphics.DrawImage(result, 0, 0, scaledUpBitmap.Width, scaledUpBitmap.Height);
         result.Dispose();
         result = scaledUpBitmap;
         #endregion
         break;
       case 0x3F:
         #region VbxeHighResolution - rescale to 1/2 width (Windows doesn't like rectangular pixels)
         Bitmap scaledDownBitmap = new Bitmap(result.Width >> 1, result.Height, result.PixelFormat);
         using (Graphics graphics = Graphics.FromImage(scaledDownBitmap))
           graphics.InterpolationMode = System.Drawing.Drawing2D.InterpolationMode.HighQualityBicubic;
           graphics.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighQuality;
           graphics.DrawImage(result, 0, 0, scaledDownBitmap.Width, scaledDownBitmap.Height);
         result.Dispose();
         result = scaledDownBitmap;
         #endregion
         break;
     #endregion
     return result;
