Scanline timing diagram
I don't know if this has been done before, but this diagram is the secret to my time-sensitive kernels. It shows every clock and every cycle of the scanline. No more adding up cycles. If you know what your kernel needs to do at a particular point, the code almost writes itself!I've attached a blank diagram, and an example filled out for the main part of Marble Jumper. I'll take suggestions for improvement, and if it seems useful to enough people, it could go in the MiniDig.stak.zip stak.zip
Sign in to follow this
Followers
0
5 Comments
