    650
    2,609
    872,048
Line Drawing in place
Sign in to follow this
I changed all the wall and door routines to use the new DrawLine function. I also updated the Frenzy routines to do the full maze instead of just 1 1/2 columns. At that point the ARM code had shrunk from 3180 to 2508 bytes. Nice savings and cleaner code.
I then added difficulty switch settings that will eventually be replaced by menu options:
  1. Left Difficulty
  2. Flicker Reflective walls
  3. Animate Reflective walls
  1. Right Difficulty
  2. Frenzy maze layout
  3. Bezerk maze layout
The Right Difficulty is only checked when entering a room, so toggling it will not change the current room's appearance.
NTSC (ROMS require a Harmony Cartridge, or the custom build of Stella)
f20110509_NTSC.bin
PAL
f20110509_PAL.bin
Source (includes ROMS)
Frantic20110509.zip
3 Comments
I don't think so, with the issue I'm having... it's actually Maria time I have the issue with. I'm 'reusing' 6 robots (up to) 4 times. That seems to be taking a toll on poor little Maria ;)
I may go back to it, though. Wish the 7800 had hardware collision detection. That was where I started having problems.
Bob
Share this comment
