The Poor Man's 1400XL (or Adding a rear-mounted PBI to a 1200XL and making it run off a 5v PSU)
In light of all the excitement surrounding the recent 1400XL and 1450XLD developments and the speculative $1000 price tag for repro models, I decided my 1200XL offered me a better stab at a bit of Atari luxury. It had lain in the cupboard for most of the time since I received it (as a very generous donation from a Canadian forum member) a year or so back, and the crappy video output, the fact that my 1084S won't sync to the NTSC luma, and the lack of a PBI made the machine seem more of a decorative piece than day-to-day machine.
However, those pictures of the 1400XL with the rear-mounted PBI fired my imagination. A parallel interface opens up all kind of possibilities and makes the 1200XL a genuinely useful machine for my needs. In addition, Ultimate 1MB is on its way, and I have a VBXE board which still hasn't found a permanent home (well - it has, but it's gonna move house anyway). The last piece of the puzzle was realizing the huge heatsink at the back of the 1200XL's case was there to cool the bridge rectifier, and if I removed that and fitted a direct 5v supply, the heatsink could also go, opening up a perfect spot for the 50 way female centronics connector which would form the PBI.
So, everything having aligned perfectly, it was time to start the job. I used the hottest iron I could find to remove the rectifier, regulators, the huge capacitor (C39), and the old power connector (bascially everything between the power switch and the 5v outputs of the two regulators).
Above, we see the cleared rectifier bridge area. The larger components were hard to remove, but patience is the name of the game.
The RF modulator has also been removed to make way for a 13-pin DIN connector for the VBXE's RGB output, and the old power connector will be replaced by a "traditional" 7-pin DIN arrangement. I cleaned up the desoldering with acetone when I was done.
Here's the board, looking rather sparse it must be said. I now have a non-working 1200XL, so this isn't the time to falter. In the next instalment, I'll be drilling holes for the new power connector, soldering it in, and wiring it up to the power switch.
4 Comments
