Insecticide work for 2/6/12
Since my computer almost died on me (which it has done several times before, but eventually started back up), I thought it would behoove me to back up all the necessary included h files. So I did that. I also worked on changing the font. So now the font has changed. It looks like the way I wanted it to. It looks as though I'll have to make both fighters use the same palette, though, which is probably OK. If not I can just change the backgrounds and foregrounds around until it looks like the way it used to so that's no big deal. So, yesterday I sped up the fighters so now it doesn't take forever for them to cross the screen. There apparently is a bug (no pun intended) when you use Reality Boy, but I've been using Mednafen and it doesn't show up in that. I'll look into whether it shows up in real hardware, and if it doesn't then I'll just forget about it. So, I've spent the last couple of hours working on this game and I've updated the official Insecticide website with the results and updated zip file so you can play it on an emulator (or FlashBoy if you're lucky enough to have one!) http://www.atari2600land.com/aegis/ic.html
