The 19x19 board
About 2 1/2 years ago, AA member Atari Rescure Group asked in the forums whether Pente was possible for the 2600. At the same time I had been starting to think about how to port Go. The board I proposed back then was a monochrome 80 pixel wide sprite using flickering.I've learned a lot about VCS programming since then, but a board without flickering had still eluded me until this weekend. I knew I could set up 19 pieces with the PF, but there was no way to change the colors every 8 pixels (it takes 9). I finally came up with the solution this weekend: PF P0 PF P1 P0 PF P1 PF P0...Here then is a screenshot of a 19x1 kernel and a mockup of the full board.
EDIT: Added a screenshot of 19x1 kernel with three different colored pieces, made possible thanks to a suggestion by supercat. Colors are tentative.![]()
10 Comments
