    650
    2,609
    872,098
visible thrust
Sign in to follow this
  • thrust exhaust now visible
  • asteroid speed slowed down a little bit. It was originally 3->9 (in steps of .4) and was changed to 5->11. After watching keilbaca play, I decided to split the difference and it's now 4->10.
  • sound effects are now quieter in demo mode
  • UFO now targets asteroids when it's not targeting a player
  • respawn no longer occurs when UFO is onscreen
  • asteroids now start at edges of the screen
Thrust exhaust
ROMs for Harmony or Stella 3.7.1 or later
spacerocks20120701_NTSC.bin
spacerocks20120701_PAL.bin
Source
spacerocks20120701.zip
5 Comments
Lookin' good. Now that Stella can support these kinds of roms, the fixed debiug colors reveal that individual sprites can alternate betwen P0 and P1. That's a sign of a sophisticated sprite drawing algorithm.
Share this comment
Thanks! The sprites are handled the same way in Frantic. I'm able to support more sprites in Space Rocks(51) than in Frantic(24) because the collision routines are only called for the ships, saucer and shots.
The collision routines scan all the other objects to see if the specific object being tested has collided with any of the others (using pixel perfect testing). With 6 shots, 2 players and enemy saucer there could be 9 * (MAX_SPRITES-1) = 9*50 = 450 checks done in Space Rocks.
In Frantic, anything can collide with anything, including the playfield as well as the 6 shots (and shots even collide with each other). So that's 30 * (MAX_SPRITES+MAX_SHOTS-1+PLAYFIELD) = 30*30 = 900 checks.
If you care to look in the source, the C function DisplaySprites() is what drives the filling of the DPC+ datastreams that the kernel uses. It's located in /custom/main.c
Share this comment
crap - don't know what I did, but my latest build is doing odd things such as getting a score of FF0910 and showing things where they shouldn't be (such as an explosion occurring behind the ship when the saucer isn't on-screen).
As such, I'm going to have to roll back to a prior build and what's in the blog posts are my roll-back points. As mentioned in busy busy, I don't have much time to test at the moment, so I'd appreciate it if anybody with some time over the next few days could play this build (July 1st) for an hour or so and see if it works as expected. If it's fine, great, if not then we'll need to play test the prior versions until we find one that doesn't screw up the score.
Thanks in advance.
Share this comment
<testing><testing><is this thing on?>
hmm, been over a week and I haven't seen any feedback on whether or not this build has the bugs I mentioned. I'll be returning to work on Space Rocks next week and would like to know which build I need to roll back to.
Share this comment
