    4,249
    2,525
    1,750,685
Super Giuseppe!
Sign in to follow this
atari2600land
At first it was an attempt to get something like Super Mario Bros. on an Odyssey2 (in the same vein as Sprybug's work). But now I think it has grown into a full fledged game I'm working on. I don't know how to stop, but at the same time, I don't know how to program a game bigger than 2k on an Odyssey2. I bet it's the same, but with special coding instructions to tell the computer the game 4k instead of 2k. The problem is, I don't know those instructions! And I'm going to worry about it soon because I'm almost out of room and want to add a level 3. Right now the game is 1,817 bytes. 2k is 2,048 bytes. So I only have 231 bytes to make changes to the blocks to make level 2 bigger. But all I have to do is change the block's x position. Everything else is handled, except for the animation, which should be fairly simple, of Giuseppe falling down to the bottom of the screen. I spent about 8 hours yesterday coding the game, most of which was undoing stuff I had already done because I broke the code earlier. But I fixed it. What I did that was new was add enemy movement and make enemy deadly in level 2. I still need to add a death sound for when Giuseppe hits an enemy in level 2, but that should be fairly simple too since calling sounds to play only takes up 2 lines of code. So hopefully I can achieve a full level two without needing 4k, but if I want to add more levels (and I do,) I need to find out how to do so.
