Fort Apocalypse Posted September 6, 2007 Share Posted September 6, 2007 (edited) It would be really helpful if bB had a convention to address 4 bits (or even 2) as a number. While you can still accomplish the same with a lot of bitwise logic, it seems like it might be faster to develop if you could address 4 or 2 bits in a var at once as if it were a short and really short int. Not sure what the convention would look like to address these vars though, and I'd bet it would be extremely hard to implement. Edited September 6, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted September 6, 2007 Share Posted September 6, 2007 It would be really helpful if bB had a convention to address 4 bits (or even 2) as a number. While you can still accomplish the same with a lot of bitwise logic, it seems like it might be faster to develop if you could address 4 or 2 bits in a var at once as if it were a short and really short int. Not sure what the convention would look like to address these vars though, and I'd bet it would be extremely hard to implement. The problems I foresee might be (1) where do we start, which bit and how many?; and (2) where do we put the retrieved value, in an 8-bit user variable, temp variable, or just in A, X, or Y? I'd say, start by writing a bB user function with inline assembly, then if it's something really useful, it could be put into an include file. Michael Quote Link to comment Share on other sites More sharing options...
potatohead Posted September 6, 2007 Share Posted September 6, 2007 Can you post some pseudo code to show how you would use this? There are probably easy options... Quote Link to comment Share on other sites More sharing options...
+batari Posted September 6, 2007 Share Posted September 6, 2007 (edited) It would be really helpful if bB had a convention to address 4 bits (or even 2) as a number. While you can still accomplish the same with a lot of bitwise logic, it seems like it might be faster to develop if you could address 4 or 2 bits in a var at once as if it were a short and really short int. Not sure what the convention would look like to address these vars though, and I'd bet it would be extremely hard to implement. It may speed up development, but it would require a lot of work to get it fully integrated, if the fixed-point math routines are any indication of difficulty - it took me probably a year to get these working right. Bitwise stuff can be a pain, so here's some example code. I'll just focus on splitting a variable in two (lower 4 or upper 4 bits.) If you just want to deal with the upper 4 bits: add 1: myvar=myvar+16 add 2: myvar=myvar+32 subtract 4: myvar=myvar-64 add arbitrary value: myvar=myvar+value*16 Copy to normal variable: othervar=myvar/16 Copy normal variable to upper 4: myvar=(myvar&%00001111) | othervar*16 For the lower 4: Copy to normal var: othervar=myvar&15 Copy normal var to lower 4: myvar=(myvar & %11110000) | (othervar & %00001111) Add arbitrary value: myvar=(myvar & %11110000) | ((myvar + value) & %00001111) Subtract arbitrary value: myvar=(myvar & %11110000) | ((myvar - value) & %00001111) The longer ones would be better as functions if used a lot. Disclaimer: I have not tested the above code! EDIT: the %00 forum bug strikes again! Edited September 6, 2007 by batari Quote Link to comment Share on other sites More sharing options...
supercat Posted September 6, 2007 Share Posted September 6, 2007 For the lower 4: Copy normal var to lower 4: myvar=(myvar & %11110000) | (othervar & %00001111) If othervar doesn't have any excess bits set, you can skip the masking operation; that should thus yield: lda myvar and #$F0 ora othervar sta myvar If othervar does have other bits set, or if it is the result of a computation, then you should use: ; Put new data into accumulator somehow. Then eor myvar and #$0F ; Bit mask eor myvar sta myvar Probably written in bB as myvar = (((newvalue) ^ myvar) & 0xF0) ^ myvar This latter approach can be particularly handy if you are performing math upon part of myvar, since there's no need to store the result of calculation to a temp address before putting it into myvar. Quote Link to comment Share on other sites More sharing options...
+batari Posted September 6, 2007 Share Posted September 6, 2007 ; Put new data into accumulator somehow. Then eor myvar and #$0F; Bit mask eor myvar sta myvar Probably written in bB as myvar = (((newvalue) ^ myvar) & 0xF0) ^ myvar Makes sense. The bB code for the above would be myvar = ((newvalue ^ myvar) & $0F) ^ myvar, which bB compiles as: LDA newvalue EOR myvar AND #$0F EOR myvar STA myvar Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted November 8, 2007 Author Share Posted November 8, 2007 (edited) Hey... resurrecting this thread because I'm looking for the most efficient way of storing 4 2-bit "pseudovariables" in a single variable (byte) to hold velocity for the 4 cars in the indy game. I'll use the timer variable to delay incrementing/decrementing of each of the 4 velocities (so it can jump in speed like you're changing gears). So the plan is to have a carvelocitybits variable such that: tempcar0velocity = carvelocitybits & %11000000 tempcar1velocity = carvelocitybits & %00110000 tempcar2velocity = carvelocitybits & %00001100 tempcar3velocity = carvelocitybits & %00000011 so if I wanted to: add "1" to car0 velocity: if tempcar0velocity < 255 then carvelocitybits = carvelocitybits + 64 add "1" to car1 velocity: if tempcar1velocity < 64 then carvelocitybits = carvelocitybits + 16 add "1" to car2 velocity: if tempcar2velocity < 16 then carvelocitybits = carvelocitybits + 4 add "1" to car3 velocity: if tempcar3velocity < 4 then carvelocitybits = carvelocitybits + 1 subtract "1" from car0 velocity: if tempcar0velocity > 0 then carvelocitybits = carvelocitybits - 64 subtract "1" from car1 velocity: if tempcar1velocity > 0 then carvelocitybits = carvelocitybits - 16 subtract "1" from car2 velocity: if tempcar2velocity > 0 then carvelocitybits = carvelocitybits - 4 subtract "1" from car3 velocity: if tempcar3velocity > 0 then carvelocitybits = carvelocitybits - 1 and if I need to have 0-3 based numbers I use: tempcar0vel0to3 = (carvelocitybits & %11000000) / 64 tempcar1vel0to3 = (carvelocitybits & %00110000) / 16 tempcar2vel0to3 = (carvelocitybits & %00001100) / 8 tempcar3vel0to3 = carvelocitybits & %00000011 Is that the most efficient way (program space-wise) to do those things? Edited November 8, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted November 8, 2007 Share Posted November 8, 2007 Hey... resurrecting this thread because I'm looking for the most efficient way of storing 4 2-bit "pseudovariables" in a single variable (byte) [...] Is that the most efficient way (program space-wise) to do those things? If you're going to convert the numbers a lot in your program, then you might want to create some general user functions, so you don't have to keep repeating the same code over and over for different variables. Michael Quote Link to comment Share on other sites More sharing options...
