carmel_andrews Posted April 26, 2005 Share Posted April 26, 2005 I have made/created atari .exe files using a mod'd version of atari 800 win+'s built in MLM/Machine lang. monitor (vers.3.1)- it also allows you to add run/init addresses to the file my problem is, is that although i can load these .exe's into atari 800 win+, either by dragging/dropping the file into atari 800win's display or by selecting the file from the 'load executables' tab I cant get to see the file through atari dos (or compatible) or any of the binary packer utilities (cruncher 5/magnus or superpacker/bewesoft) Is there a pc packer/packing utility available that allows me to pack atari .exe files created using atari 800 win+'s built in mlm any help would be appreicated Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 26, 2005 Share Posted April 26, 2005 could simply because segments have to be specified by $ff,$ff,start adr lo, start adr hi, end adr-1 lo, end adr-1 hi. maybe the $ff,$ff dos header is missing... Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted April 27, 2005 Author Share Posted April 27, 2005 could simply because segments have to be specified by $ff,$ff,start adr lo, start adr hi, end adr-1 lo, end adr-1 hi. maybe the $ff,$ff dos header is missing... 844303[/snapback] No... it's all there, otherwise i wouldn't be able to load it with atari800 win+'s load executables option Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 27, 2005 Share Posted April 27, 2005 If you're using windows then there's the MakeATR program. You can transfer files in and out of an ATR image that's been formatted with DOS. Quote Link to comment Share on other sites More sharing options...
classics Posted April 27, 2005 Share Posted April 27, 2005 I think his problem is that his segments cover all of ram (800 - Bfff) and he is overwriting DOS. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 28, 2005 Share Posted April 28, 2005 Not the impression I got, but 'I cant get to see the file through atari dos' isn't too clear Carmel, can you post the related, binaries/atrs you are using and exact steps of what you are doing and what you expect to see but are not? All: Would it be worth trying to convert the PC util Exomizer for the C64 to produce A8 files? Regards, Mark Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted April 29, 2005 Author Share Posted April 29, 2005 Not the impression I got, but 'I cant get to see the file through atari dos' isn't too clear Carmel, can you post the related, binaries/atrs you are using and exact steps of what you are doing and what you expect to see but are not? All: Would it be worth trying to convert the PC util Exomizer for the C64 to produce A8 files? Regards, Mark 845483[/snapback] Unfortunately, this board/forum doersn't allow uploading of my .exe files (perhaps they are accusing me of spreading viruses etc... which clearly is not the case) If you wish to see my .exe files created using atari800win+'s mod'd mlm you will have to send me an email with your address and i will send you the files at attachments Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted April 29, 2005 Share Posted April 29, 2005 ehmmm... just zip it? Quote Link to comment Share on other sites More sharing options...
