3,086 -
Posts posted by Roydea6
The good thing is that it seems that we will be able to later order smaller runs (10-20 pcs) again.
Best regards, Peter.
Extra paid by Paypal and hope later smaller runs will continue.
Well everything seems to be working, maybe. I got a pack of DOS 2.5 diskettes, and they do boot, but the 810 can't write or format them. I'm assuming that's because DOS 2.5 was designed for the 1050. I was wondering if there was a cassette DOS I could use instead? I've tried TT-DOS, but I don't think it'll run on an Atari 400; it crashes both on real hardware and in emulators. Someone on this site actually ported Atari DOS to cassette... but it's DOS 2.5 so that doesn't really help! If worse comes to worse I could just wait for SIO2USB to get here, but I'm sure that'll take at least a month
Dos 2,5 has a format at single density H option to copy dos files to diskette and you can then boot it with an 810 Drive.
I'm trying to load OSS Basic XE onto my Flash cart, but keep getting an error. I run the .atr image from my computer, which is connected to my XE GS via the SIO2PC cable. It starts the loading process, but once it gets to bank 10, I get a Disk Error on the XEGS. This happens every time. Does anyone have any suggestions?
Goto this web site for a basic xe but you need to have the MyIDE 2 cartridge and put it in the FAT32 area and load with the fatload that comes with the cartridge. Drive D1 should have you dos disk with extentions..
https://www.atarimax.com/flashcart/forum/viewtopic.php?p=8349#p8349
I would refrain from changing your diskettes if you really want to consolidate game files then use new disks with a dos like the new MyDos 4.55 version. And if you need a game loader menu use Picodos by Hiassoft ..
Good Luck..
Turn off the computer then You need to pull the jumper off and then rerun ant.exe has now gone to version 1.4. Turn on the computer and Reset menu items ... reboot then turn off computer and reinstall the jumper on the pins.
Also read the original thread about the upgrade.
This Tramiels.xex will not be part of my rasterview picture collection.. Now at over 500 files in a folder on SpartaDos X Side CF partition ..
Has PCLINK.SYS always been putting out all caps filenames. I noticed this and checked the setting and no check mark for lower case like there is in the H: device setting.. I don't remember pclink.sys putting out all caps before 3.10 beta.
Yes, if there is extended memory, 2.5 will configure the RAM disk memory. It will give you a message to that affect.
But only if the ramdisk file is in the directory.. Not all Dos 2.5 diskettes or ATR's have a ramdisk file..
Tribute to MATT.
Christmas of 1982 I got my KoalaPad and never did any decent picture files. But later the Kids came along and they did a lot of drawing (mostly scribbling)
But now I really like the Koala pad pictures. So I am constantly looking for more Picutre.ATR's
I also recently found the Manual..
In gif picture format..
LS A*.XEX >>ALLA.BAT LS B*.XEX >>ALLB.BAT LS C*.XEX >>ALLC.BAT LS D*.XEX >>ALLD.BAT LS E*.XEX >>ALLE.BAT LS F*.XEX >>ALLF.BAT LS G*.XEX >>ALLG.BAT LS H*.XEX >>ALLH.BAT LS I*.XEX >>ALLI.BAT LS J*.XEX >>ALLJ.BAT LS K*.XEX >>ALLK.BAT LS L*.XEX >>ALLL.BAT LS M*.XEX >>ALLM.BAT LS N*.XEX >>ALLN.BAT LS O*.XEX >>ALLO.BAT LS P*.XEX >>ALLP.BAT LS R*.XEX >>ALLR.BAT LS S*.XEX >>ALLS.BAT LS T*.XEX >>ALLT.BAT LS U*.XEX >>ALLU.BAT LS V*.XEX >>ALLV.BAT LS W*.XEX >>ALLW.BAT LS X*.XEX >>ALLX.BAT LS Y*.XEX >>ALLY.BAT LS Z*.XEX >>ALLZ.BAT ECHO End dobat..
For SpartaDos x 4.44x.
All this needs now is a clear screen and return to Dos on exit..
Sound is good to my ear... @ 73 years.
Bah. Maybe so. I purchased SIO2PC cable and APE something like 15 years ago and still have the cable (serial) -- but I see APE is $100. Not going to re-pay that with the SIO2SD en route from Europe, but it would've been nice to play with some games on this NTSC unit while I wait. Is there any other program that can use an SIO2PC cable to run anything, even if crudely?
Also -- is it definitely the case that if I were to pay the $100, signed drivers that will run under Windows 10 Pro 64 exist? (I would need to install the Keyspan USB to serial adapter I have and drivers to interface to APE with this serial SIO2PC cable.)
Also --- other suggestions for PAL Atari 8-bits (more than just the board)?
Thanks.
If you have an APE serial cable.. If you bought it from the AtariMax website you should email Steve Tucker for the latest version 3.0.13 that has a software mode that will except the USB to Serial adapter..
No, these patche not included yet, But I'll do it for sure.
About casettes - I hope yes - ARM at 48MHz has enough power to realize it.
Just wondering if you are still looking at cassette support. And 16mb atrs. I am looking for a fun Christmas present and an upgrade to Sdrive-arm would qualify ..
I wish these conversions were further along than they are but if I wait until I'm completely satisfied I might not have any picture before Christmas, truthfully.
ATR with MyPicoDOS v4.06 menu
ZIP with executables and customized palette
These are good pictures and good colors.
But still crash on exit with return or START key requiring a power off and power on to see the next picture.
I wish you would re-download the RasterView converter and replace the original version.
The keyclick repeat rate is better in this fixed version and I am using it with both 800 and 800xl, 130xe.
Although My 800 does have an Incognito installed. I should test it Colleen mode to be sure.
1 - ACTris! 2.1
2 - Dye
3 - Dimo's Dungeon
4 - AtariBlast!
5 - Blowsub
6 - Jim Slide XL
7 - Fairlight
8 - Cyctriks
9 - 5 Dots
10 - At Arion Line: Mission Zero-
Larry,
this thread has an sio2sd fix by phaeron.. And seems to work with my sio2sd..
http://atariage.com/forums/topic/237177-sio2sdxex-on-an-800/?p=3219659
100 FOR I=0 TO 72:READ A 110 POKE 1536+I,A:NEXT I 120 PRINT CHR$(125) 130 PRINT "DRIVE #";:INPUT DRIVE 140 POKE 1610,DRIVE 150 X=USR(1536) 160 A=PEEK(1611):B=PEEK(1612) 170 MINUTES=(256*B+A)/3000 180 RPM=INT(100/MINUTES+0.5) 190 ? :? "RPM'S= ";RPM 200 END 1000 DATA 104,169,1,141,10,3,169,0 1010 DATA 141,11,3,141,4,3,169,5 1020 DATA 141,5,3,173,74,6,141,1 1030 DATA 3,169,82,141,2,3,169,5 1040 DATA 141,73,6,32,83,228,206,73 1050 DATA 6,208,248,169,100,141,73,6 1060 DATA 169,0,133,19,133,20,32,83 1070 DATA 228,206,73,6,208,248,165,20 1080 DATA 164,19,141,75,6,140,76,6,96
This is the only disk RPM checker I could find in basic .... Never used it I prefer the Binary RPM.
New (alt) BIOS for Ultimate 1MB/Incognito
Bump--to remind you that a few days is over.
