LS_Dracon
    1,002
Blog Comments posted by LS_Dracon
  1. Cool.
    Recently I finished a pong clone for Atari 2600.
    For the ball angles, my code is something like: (Ball Y pos) - (Player Y pos)
    If Ball is on the player range, the result (0 up to 15, player height) is divided by 2 (byte shift) because 15 is too much, resulting 7 positions plus 0 (no vertical move). Then I use the result to index a table.
    The table in this case is like -7,-6,-5,...0,1,2,...7. Positive to go down, negative to go up. So I can easily pick the vertical value for the ball. Note if ball hit the center of the player, the vertical value is 0, this why 0 is on center of the table.
    I had plans to make computer space too. Is there a screenshot of your game?
  2. Thanks.
    The light gray (white) in background is needed to use on skull, I can set black pixels to hide the white around the object but I'll lost the outline information I like to keep in my sprites.
    The sprite you like is the original, others 2 are modifications to fit the technique limitations (16 pixels wide for black pixels, 2 colors limit for each line + background white ).
  3. To keep using the big ship, collisions are made by software right? Is it possible to reduce the ship "hit area"? Then the cannon/mines need to hit the center of the ship in order to destroy it. Like ghosts in pac-man arcade, doesn't kill you just touching a single pixel.
    Edit:
    + regenerate if middle ring is empty (test arcade).
    Nope, desn't regenerate destoying all the middle ring sections.
  4.
    I'd like to add a vote for adding "hit sparks" when shooting the rings. I think it would probably be worth the flicker, since it would only need to be maybe 2 frames long. It's very, very short in the arcade game. I'll work up a sprite for it, and hopefully it can be included as a test.
    I think a not animated spark played by 3 frames, I mean, due flicker, frame 1 = spark, 2 = ship, 3 = spark, 4 = ship and 5 = spark.
    I'd like to revise the player's ship exploding. I've never been completely happy with it. That said - Thomas, can I make that explosion taller? I'd like more room for the debris to trail off (similar to Space Rocks).
    How about setting p0 as double wide (can be made outside of kernel) and using missiles and balls for debris? The kernel support up to 6 dots, just setting the mines as single pixel wide going down the player explosion and make the player shoot 3 missiles to up.
