oracle_jedi
    743
Posts posted by oracle_jedi
  1. You're right. With respect to original era commercial games, pretty much anything that was popular on the ST was ported to the Amiga with more or less the same graphics and often much improved music and sound effect.
    There were exceptions, such as Oids, but they were few.
    Beyond that, there are public domain/homebrew titles from then and now. Last years Pole Position is an amazing example of what the STE can do.
    Still, I imagine the number of titles you would find that were not ported to the Amiga, or simply better on the ST, would be a short list.
  2. Does anyone know if you can use a self contained USB 3 100 GIG hard drive with the GOTEK emulator or does it just take flash drives ???? I have a few 32 GB flash drives that I can use just in case the hard drive will not work................. Russ Campbell
    USB3 specification is up to 4.5W of power per jack. Your USB hard disks are probably drawing just under 3W.
    I expect the Gotek is specified to USB1 which delivers 0.75W per jack, so no, unless you have an additional power supply, it almost certainly wont even spin up.
    Even if you overcome the power issue, from memory Gotek expects FAT32. FAT32's largest drive support of 32GB.
    USB sticks are cheap. The Gotek even supports a USB Card Reader so you can plug in CF and SD cards. I wouldn't bother with the drama of what you're suggesting, but if you do try it, let us all know how it goes.
  3. I've never owned a Mega ST, so some of this is from memory of things read in the past and from talking with friends who do.
    The Mega ST was the same as the regular ST for the most part except that it came in a pizza-box configuration with the keyboard plugged in separately, similar to the style that was increasingly popular in the late 80s. It does include a cartridge port, which is important here as the NetUSB device Fletch mentioned requires it.
    As mentioned above, there was also a later STE variation, also available in "Mega" form, for which they used the Atari TT case plastics albeit in a slightly different color. Again the keyboard plugged in separately. The Mega STE has space for an internal hard disk which is handy, and an expansion bus that pretty much no one uses.
    MegaSTEs seem very rare, especially in North America, and so be willing to pay a premium if you really want one.
    Note: There is no single ST that will run every software title without some issues.
    Problems occur with different TOS versions - from V1.0 to V2.04. TOS 1.62 seems the most compatible with everything.
    Also video modes. A lot of games require 50Hz "PAL" mode, although the latter STs can easily switch to this with a simple program in the AUTO folder.
    Hard disk drivers can interfere with some picky games.
    The STe/Mega STe had extra hardware for audio and visual. Few games every used it but there might be some games that simply won't run on a stock ST or Mega ST.
    If you are adamant that you want the Mega version, look out for:
    Is the keyboard included and does it look to be in okay condition?
    Demand pictures of the battery bay. Many Mega's suffered from leaking batteries when their owners boxed them up and forgot to remove the AAs. Battery leakage can destroy a motherboard. Non Mega Atari STs did not have battery backed clocks.
    And for all STs:
    Look for proof the unit boots up to a desktop - not just a power LED. Fixing STs is a rare and special skill so unless you are good with scopes and soldering irons...
    Is the unit from your country? STs were much more popular in Europe than North America, leading to many enthusiasts later importing Europrean units to the U.S. - that's fine but the composite signal is going to be PAL, not NTSC, and the power supply will be 220V.
    Look for pictures from all angles. Many ST owners hacked their cases to accommodate Gotek drives, or turbo switches, or whatever, and most of them were not very skilled with a dremel.
    Is the mouse included? The ST mouse is unlike the Amiga or PC, so you can't just swap them over, although they are still plentiful on Ebay.
    Does it include a video cable? The Atari video plug is unique so you will need to buy or make a special cable for the Atari's 13-pin DIN video port.
    To move files from your Mac to any ST:
    NetUSB has already been mentioned, and is a good method - but you will also need somewhere for the transferred files to land. The Mega STE can house an internal hard disk but other STs, including the original Mega ST, could not. Look up the Ultra Satan as a SD-card based hard disk alternative that plugs into the ASCI port. The SD card can be removed and read on an OS that can handle FAT file systems, which I believe the Mac can. Then you can drag and drop your files.
    ParCP is another option. Plug the adapter into the ST's parallel port and run a USB to your Mac. I can't remember if the software supports MacOS or not so you might end up having to run Windows or Linux in a VM. Then you can transfer files to the ST over the USB cable.
    Overall I'd agree with Fletch. If you are just looking to get into some games consider a 1040STE. Easy to upgrade, can run most applications with little fuss and besides the daft mouse/joystick port location under the keyboard they are easy to live with.
    HTH
    Graham
  4. I know this has come up before, but I wanted to bring it up again.
    With the slew of new releases from AtariAge and Piko, plus re-releases from Orion, for our Jags it seems to me the cartridge ports will be getting more use. The imminent release of the JagSD card will only add to this wear and tear, since I am guessing the JagSD won't be able to emulate a Skunk, nor will we be seeing Another World, Rebooteroids, Xenon 2 nor any of the other more recent releases being made available for it.
    Recently I crushed a pin on my Jag's connector. This happened when inserting a Rev 2 Skunk. I am surprised and disappointed by this, not only for the inconvenience, but my Jag was a NOS unit purchased in late 2014, and has really not be used that much. I am also very careful with all my retro equipment. Yet I still managed to damage the connector with nothing more than a typical cartridge insert operation.
    I've read about beveled and non-beveled edge connectors. Looking at the Llamatron release, and Alice's Mom's Rescue, they don't look to be beveled, at least not to the same extent that original Atari carts were.
    Replacing the cartridge connector is not trivial. Not only is the challenge to de-solder the dozens of tiny pins, but also to do so without damaging the pads on the Jag mobo.
    As retro prices continue to skyrocket, the opportunities to acquire cheap bone-yard units from yard sales or thrift stores to practice on are rapidly vanishing.
    So my question is two fold.
    1. Is there any interest - beyond me - for a Jag cartridge port riser to move the wear and tear to an easily replaced part.
    2. How hard would it be to design and manufacture such a unit? I am guessing the Jag's cartridge port connector is not a stock item, and only Best Electronics has any left in stock.
    In my ideal world such a riser would include a 3D printed case to hold it firmly in place and prevent wobble. The cartridge port connector itself and the pads to which they are soldered should be designed to be tolerant to future desoldering for when the port wears out again, unless Al would commit to keep new Jag risers in stock at the AtariAge store.
    The riser could be designed so that carts are inserted horizontally, thus reducing the total height of the unit with a game inserted. The JagCD obviously might have some issues with such a design, but if the JagSD renders the CD unit obsolete would we care?
    In case it isn't obvious, I have no clue about what it takes to design and make something like this, but that's where my head is at.
    Now I have to contact Brad and organize shipping my unit back to him for repair, which he tells me includes a 10 week turnaround time.
  5. I have downloaded Blood Money and am trying to get a score good enough to verify the fix, but seeing that you have your name at the top of the high score list I am assuming you already did this :)
    I also tested Rainbow Islands. I remember having problems with this title in the past, but possibly with a different dump. I noted that Rainbow Islands hangs on a 60Hz machine. If I manually switch to 50Hz mode before starting the game it seems to run fine. I don't know if thats the sort of thing you are looking for here or not.
  6. Okay thanks for the guidance.
    For any other Amiga newbie struggling with this, what I found was that the HDToolBox that came on the Workbench install disks was pretty much useless.
    You can find MaxTransfer under "Partition Drive, Advanced Options, Change", but no matter how many times I set the value to 0x1FE00 it refused to stick.
    I tried deleting the partition and managed to delete the primary partition too. So that was a fun day rebuilding everything....
    A better option I found was The HDInst tools from Aminet. This tool made it simple to set the transfer rate and the changes stuck first time.
    WHDLoad is now working as expected, so this is awesome.
    Thanks again and Happy New Year.
  7. The dark brown keys/light brown function keys were originally used on the VIC20.
    When the 64 was first released, I saw pictures of early machines with the silver label and this style of keyboard.
    Later the darker coloured function keys and the rainbow logo became standard, and then I guess as a cost-cutting measure, the darker function keys showed up on later VIC20s.
  8. So I am trying to use the form at http://atari.8bitchip.info/atricl.php to register a bug with Blood Money.
    And no matter what I try I get the same error: "Submitting... Error!"
    The problem with the game is that if you make the high score, the game crashes. I am playing on a U.S. spec 4MB STE with TOS 1.62 loading off a Satan disk.
    I also note that now the webpage http://atari.8bitchip.info/fromhd.phpdemands I acknowledge the request to help test and debug games. That's cool. But if you then try to sort the list of games into alphabetical order you are taken back to the same acknowledgement page, and the list is re-displayed but isn't sorted any differently.
  9. I am trying to experiment with some WHDLoad images on an Amiga 1200.
    Loading from the external CF card plugged in through the PCMCIA port they work ok, but if I copy the files to the internal HD (which is really a 2GB CF card), they mostly fail with various errors.
    Games installed on the internal drive from floppy disk work ok.
    A suggestion is that the Maxtransfer setting for the internal drive is wrong, and to use HDToolBox to change it. I can't see where in HDToolBox that setting is exposed? Can I set the maxtransfer rate from HDToolBox and if so how? Is there a way to do this for an existing drive/partition without having to reformat?
    KS3.0/WB3.0 if that makes any difference.
    Thanks
  10. Is there any news on the status of this release..?
    The code was finished a few years back. You can play it at PRGE in October 2018, and again in 2019, and again in 2020....
    The developers have now moved onto the most difficult and time consuming part of any Jaguar release - getting the cartridge case design and retail packaging right.
    :P
    • Like 4
  11.
    But you have to remember that the ST, in the first few years was far more affordable than the Amiga. The Amiga was technically superior but at a price which made it too expensive as "16-bit family" home computer for most. Only after the Amiga 500 was released about two years later, the price came down to a level that made it compete as family home computer.
    The original price differential is a good point that is often overlooked, or simply ignored.
    I read with some exasperation, a piece in The Guardian, by technical writer Keith Stuart about the Amiga where he claimed:
    In 1985 my family made a terrible mistake – a mistake that would have far-reaching consequences; a mistake that would blight my life for several painful years. I still look back at it with a sense of sadness and, yes, if I’m honest, fury. What happened was this – and if you’re a gamer of a certain age, you may want to sit down: my family bought an Atari ST instead of a Commodore Amiga.
    Right Keith, so back in 1985, your family chose to buy something affordable over something insanely expensive. That's like saying your family made the mistake of buying a Ford Sierra and not the Jaguar XJ6, as if that was a common alternative purchase option at the time. My dad chose a second hand Volvo 245DL, and it blighted me for many years that he didn't buy the new Mercedes that I really needed to compete with the cool kids at school. I feel your pain man, I really do.
    Indeed Mr. Stuart's claims are even more ridiculous given that the Commodore Amiga wasn't even launched in the UK until May 1986 at a suggested price of £1500 for the basic 256K version without a monitor. By comparison the Atari 520ST was selling for under £350. A double sided disk drive would have cost you about £150. In a launch review for Your Computer in May 1986, reviewer Geof Wheelwright called the Amiga a "dream machine" but a "nightmare price".
    See Your Computer May 1986 page 80.
  12. @OP
    I've downloaded a number of the games from your site and I appreciate the work that goes into making them available.
    I only got back into the ST about a year ago so I have not had alot of time to experiment with a lot of games.
    We talked a while back about Prince of Persia - the problem with the health not being restored. I know you fixed that in a subsequent release. Thank you.
    I agree its impossible to test every game to its fullest extent. Between bad cracks, missed protection routines, incompatibilities between TOS releases, PAL/NTSC timing issues and even undiscovered bugs in the original code, its impossible to know if any release is going to work as expected in all possible scenrarios.
    Please keep up the great work, and I should let you know that Blood Money crashes if you achieve a high score.
    Thanks
    Graham
  13. Bumping an old thread and hoping someone can shed some light on this for me.
    I have HDDRIVER 8.43, a 2GB CF Card and a Falcon.
    I tried partitioning the card as 4 partitions with Compatibility set to "Windows" and the "TOS & Windows Combined" box checked. Byte Swapping was also checked.
    After partitioning and reboot I installed the driver.
    The card shows up in Windows XP and I can move files to it, but the Falcon does not see it on power up and boots the floppy instead. If the floppy has the HDDRIVER.SYS files on it then the desktop shows the four partitions, but if the floppy does not, the driver isn't loaded and the CF card is inaccessible.
    If I partition the CF with Compatibility set to TOS, then the Falcon boots up fine, loading the HDDRIVER.SYS from the primary partition as one would expect, but the card is unreadable by Windows XP, making file transfers a bear.
    Can I set this up such that TOS can boot from a primary partition, but one or more of the partitions are also mountable by Windows XP. Yes I know about Windows only seeing one partition on a removable device and I have the alternative Windows driver to allow for that.
    Would appreciate any insights.
    Happy Thanksgiving!
    Graham
  14.
    I would say that the Jaguar and Falcon were commercial failures (disaster is a bit strong) but the Amiga sold quite well outside of North America.
    You're comparing a platform (Amiga) to specific products (Atari Falcon and Atari Jaguar).
    The Falcon was part of the Atari ST platform, along with the 520ST, 1040STF etc. The Atari Jaguar was the only product in the Jaguar platform as the Duo Jag never saw the light of day.
    The Atari ST platform, like the Amiga platform, was successful for a time in the late 80s, notably in the UK and Germany. Then struggled through the early 90s and ultimately they both became obsolete in the face of improving PC/Windows machines which increasingly monopolized the productivity market, and the 16/32bit game consoles that replaced the Amiga/Atari ST platforms as the preferred choice of gamers.
    The Falcon was not successful. Too little too late. Estimates are 12,000 sold.
    The products of the Amiga platform of that era were not much more successful. The CD32 and A4000, if published numbers are to be believed, saw weaker sales than the Jaguar and Falcon respectively. The A1200 was, as you said back in post #16 "relatively successful", but with total worldwide sales at 144,000 in FY92 and FY93 it was successful relative to what? The Falcon? Sure.
    But 144,000 over 24 months is about the same as the number of Jaguars that Atari sold world wide in FY94 and FY95, or if you prefer, about half the world wide sales of the Commodore 16/116, which was the entry level product of the Commodore 264 platform.
    I suppose the Commodore 264 platform was "relatively successful" if you are talking about the Hungarian home computer market in the late 80s. However, most I would guess would not describe the Commodore 16 as "relatively successful".
    The Atari ST platform "failed" in the face of competition from PCs and consoles, albeit giving Atari management just enough breathing room to realize the inevitability of the situation, retire the platform and switch to games consoles (which also failed). Commodore's management rode the Amiga platform's failure directly into bankruptcy.
  15.
    Then what, to you, is a commercial success? A company that is still going to this day? Is that how you personally define it?
    Nowhere did I claim that the vendor must still be operational today to deserve the moniker of success for a specific product or platform.
    I did suggest that it is a stretch to claim a platform was an unqualified success when the manufacturer who's entire revenue stream and GTM strategy was built around said platform became insolvent.
  16.
    How exactly did the Amiga fail commercially? Last I heard it sold millions in Europe. Jay's team designed the custom chipset that was revolutionary for its time, it doesn't matter what the units they went in were, they still all performed and SOLD very well, especially in Europe and outside North America. Any problems with the Amiga sales can be put down to the idiotic, incompetent management at Commodore, the hardware was not to blame.
    The C64 was only 8-bit and had a questionable colour palette, Commodore wanted an upgraded computer at 16-bit, and they got it in Amiga.
    Commodore went bankrupt. At a time when the only products in the line-up were Amiga derived. That is a standard definition of a commercial failure.
    BLMC sold millions of cars. Some of them very technically advanced and well designed. A commercial failure is a commercial failure, no matter how much I loved my mum's Austin 1300.
