CurtisP
    259
Posts posted by CurtisP
  1. Sure thing, but it won't be tonight.
    It looks like either the STA commands need to occur 1 cycle sooner, or the score needs to be shifted left 3 color clocks. The odd thing was, the z26 and Stella emulators both showed the last digit "correctly," so apparently they aren't emulating the actual timing behavior correctly. I meant to do some further investigations to verify this, and then tinker with the score timing in batari Basic. In particular, I'm curious to see if using VDELxx has any bearing on this. (I'm wondering if there's a tiny delay of 1 cycle after GRP0 is updated, during which the "old" GRP1 register is being updated from the "new" GRP1 register.)
    I have not noticed this issue on my 4-switch, so it might be a heavy-sixer thing. If you can post the binary you used to test the timers, I will let you know if that binary has a distorted score. BTW, have you noticed any weirdness with the score on all bB 1.0 binaries, or just this one?
    Thanks for the info. It was a pain getting the cycles right, but I may have to work on it some more. I pulled out my heavy six so I can do some more testing.
    Looks like I'm going to have to buy some more 2600s, all I have are heavy-sixers.
  2. Looks great, and should be useful for things like debugging in the Stella debugger.
    Thanks bAtari. I will get those changes in. My main purpose for doing this was so that I made sure my minikernel didn't have any conflicts. It;s how I discovered that it will crash the multisprite kernel. But now I know how to fix it.
  3. Here is a Memory Map I created from the std_kernel.asm and multisprite_kernel.asm
    Location Standard Kernel								  Multisprite Kernel
     $80	player0x										 missile0x
     $81	player1x										 missile1x
     $82	missile0x	  player0colorstore				 ballx
     $83	missile1x										missile0y		 objecty
     $84	ballx											missile1y
     $85	player0y	   objecty						   bally
     $86	player1y										 SpriteIndex
     $87	missile1height player1color					  player0x
     $88	missile1y										player1x		  NewSpriteX
     $89	bally											player2x
     $8A	player0pointer player0pointerlo				  player3x
     $8B				   player0pointerhi				  player4x
     $8C	player1pointer player1pointerlo				  player5x
     $8D				   player1pointerhi				  player0y
     $8E	player0height									player1y		  NewSpriteY
     $8F	player1height  player0color					  player2y
     $90	missile0height currentpaddle					 player3y
     $91	missile0y	  paddle							player4y
     $92	ballheight									   player5y
     $93	score											_NUSIZ1		   NewNUSIZ
     $94													 NUSIZ2
     $95													 NUSIZ3
     $96	scorepointers									NUSIZ4
     $97													 NUSIZ5
     $98													 _COLUP1		   NewCOLUP1
     $99													 COLUP2
     $9A													 COLUP3
     $9B													 COLUP4
     $9C	temp1											COLUP5
     $9D	temp2											SpriteGfxIndex	P1display
     $9E	temp3
     $9F	temp4											RepoLine
     $A0	temp5											P0Top
     $A1	temp6											unused?
     $A2	rand											 player0pointerlo  player0pointer
     $A3	scorecolor									   player0pointerhi
     $A4	playfieldbase  var0							  P0Bottom
     $A5				   var1							  P1Bottom
     $A6				   var2							  player1pointerlo
     $A7				   var3							  player2pointerlo
     $A8				   var4							  player3pointerlo
     $A9				   var5							  player4pointerlo
     $AA				   var6							  player5pointerlo
     $AB				   var7							  player1pointerhi
     $AC				   var8							  player2pointerhi
     $AD				   var9							  player3pointerhi
     $AE				   var10							 player4pointerhi
     $AF				   var11							 player5pointerhi
     $B0				   var12							 player0height
     $B1				   var13							 player1height	 spriteheight
     $B2				   var14							 player2height
     $B3				   var15							 player3height
     $B4				   var16							 player4height
     $B5				   var17							 player5height
     $B6				   var18							 PF1temp1
     $B7				   var19							 PF1temp2
     $B8				   var20							 PF2temp1
     $B9				   var21							 PF2temp2
     $BA				   var22							 pfpixelheight
     $BB				   var23							 PF1pointer		playfield
     $BC				   var24
     $BD				   var25							 PF2pointer
     $BE				   var26
     $BF				   var27							 aux3			  statusbarlength
     $C0				   var28							 aux4			  pfscorecolor	 lifecolor
     $C1				   var29							 aux5			  pfscore1		 lifepointer
     $C2				   var30							 aux6			  pfscore2		 lives
     $C3				   var31							 playfieldpos
     $C4				   var32							 scorepointers
     $C5				   var33
     $C6				   var34
     $C7				   var35
     $C8				   var36
     $C9				   var37
     $CA				   var38							 temp1
     $CB				   var39							 temp2
     $CC				   var40							 temp3
     $CD				   var41							 temp4
     $CE				   var42							 temp5
     $CF				   var43							 temp6
     $D0				   var44							 temp7
     $D1				   var45							 score
     $D2				   var46
     $D3				   var47
     $D4	temp7											pfheight
     $D5	playfieldpos									 scorecolor
     $D6	A			  a								 rand
     $D7	B			  b								 A				 a
     $D8	C			  c								 B				 b
     $D9	D			  d								 C				 c
     $DA	E			  e								 D				 d
     $DB	F			  f								 E				 e
     $DC	G			  g								 F				 f
     $DD	H			  h								 G				 g
     $DE	I			  i								 H				 h
     $DF	J			  j								 I				 i
     $E0	K			  k								 J				 j
     $E1	L			  l								 K				 k
     $E2	M			  m								 L				 l
     $E3	N			  n								 M				 m
     $E4	O			  o								 N				 n
     $E5	P			  p								 O				 o
     $E6	Q			  q								 P				 p
     $E7	R			  r								 Q				 q
     $E8	S			  s								 R				 r
     $E9	T			  t								 S				 s
     $EA	U			  u								 T				 t
     $EB	V			  v								 U				 u
     $EC	W			  w								 V				 v
     $ED	X			  x								 W				 w
     $EE	Y			  y								 X				 x
     $EF	Z			  z								 Y				 y
     $F0	aux1		   pfcolortable	  pfheighttable   Z				 z
     $F1	aux2											 spritesort
     $F2	aux3		   pfscore1		  lifepointer	 spritesort2
     $F3	aux4		   pfscore2		  lives		   spritesort3
     $F4	aux5		   pfscorecolor	  lifecolor	   spritesort4
     $F5	aux6							 statusbarlength spritesort5
     $F6	stack1										   stack1
     $F7	stack2										   stack2
     $F8	stack3										   stack3
     $F9	stack4										   stack4
     $FA	stack										   stack
     $FB
     $FC
     $FD
     $FE
  4. I tried it last night with "const pfres = 32," but I couldn't get it to work. Basically, the playfield colors changed as desired, but the background color didn't change at all. However, it may be that I was doing something wrong, because it seems to me that it *ought* to work.
    Actually it really shouldn't work. I remember now what the deal with pfres is. The code references a specific offset from the value in the X register, which I found through trial and error. When using a pfres other than default, the offset varies by the pfres. I couldn't figure out the exact formula for figuring out the offset, so I just left it unimplemented for different playfield resolutions. It's entirely possible to make it work with different pfres, but I'll leave that to someone else.
    This is really just a proof of concept hack more than anything else. The right way to do this would be to include it in the pfheights+pfcolors routine as I mentioned before. Then the calculations are already done, and it's not using up any more space.
  5. How does this code work with a' const pfres = 32' or 'const pfres = 24' command?
    It was designed around the standard playfield resolution, so I have no idea what it will do. It might even crash. In any case. I'm pretty sure the background stripes will not match the foreground stripes.
  6. I'm actually running a little low on space now, there's only about 4.5K of space left out of the 32k now (spread out among the 8 banks). I think I'm just about done adding new features, I'm concentrating more on testing the game now.
    If you would like to send me a copy of the source code, I can see if there is anything that can be optimized. I may also be able to help with the music. There's already a machine language 2600 tracker out there that I have wanted to integrate into bAtari Basic, and I have a friend who might want to write some original music.
  7. The minikernel is complete and ready to use.
    Any chance you might be able to do a 4 player version (4 2-digit scores)? If so, I could really use it.
    Probably not 4 on one line, but two on a line stacked on top of each other would be doable. It would require that the 6-digit score be turned off, though.
  8. I see you've switched to the standard kernel, since the multisprite kernel doesn't support the paddles. Since you're flickering between three frames, the flickering is kind of bad. I wonder if you could flicker between just two frames somehow, such as by changing the pitstop to use the missiles and ball, or just drawing it differently... maybe like shown below?
    I agree. Television is actually interlaced: two 60th second frames make up a single 30th second frame. The phosphors last about a 30th of a second, so there should be very little flicker on an actual 2600.
  9. To figure this out. I compiled the program, then opened the file 2600basic_variable_redefs.h and looked at lines 47 and 49 as listed in the output window. These lines are
      currentpaddle = b
     paddle = a
    Looks like you tried to assign these variables in yoru program. However, they are already defined by bAtari Basic when the readpaddles kernel option is set, so you are actually attempting to redefine them, which the assembler doesn't like.
    I took out the lines
      dim paddle=a
     dim currentpaddle=b
    and it compiled succesfully.
  10. I've also found 12 cycles available if you aren't using readpaddles, playercolors, or pfcolors. Don't know what to put there, but at least I know it's available.
    Where are the 12 available cycles located?
    Line 217 of std_kernel.asm
  11. One thing that may be useful to have as an option would be to specify one of several coordinate systems using compiler directives, and then have bB do whatever is necessary to make them work (subject to limitations of what sprites can actually do). For example, have an option in any kernel to set 0,0 be the upper-left corner. Then bB could, if necessary, do something like:
      lda #84
     clc
     sbc player0y
     sta player0y
    before and after the drawscreen code. Even if a particular kernel favors some particular method of storing coordinates, changing them before and after invoking the kernel would cost comparatively little, and would make it easier to port games from one kernel to another.
    But then the variable's value would be different after the drawscreen than before, which would be bad in so many ways.
  12. In addition, it would be super awesome if it were added as the first (and only?) kernel option for multisprite in a bB 1.1 release, as not only would it allow people to more easily write 4 player racing games, but 4 player pong games with 2 balls (ball and missle), a warlords-like game (without the bricks, since there is no pfread or pfpixel in multisprite kernel), 4 player planetary defense, and you could build a new paddle-based turret controller and shoot at 6 sprites at once (by using a blinking ball and missle for the targets).
    A paddle is read by setting a bit in VSYNC, then counting down until the appropriate register is zero. It can take nearly a whole frame for this register to clear, so the register is checked by the kernel each time it draws a new scanline. It takes 10 cycles to check one hardcoded paddle and 18 cycles to check a paddle selected by the code. The largest empty space I could find is 7 cycles.
    So, no paddle for you!
