simonsunnyboy
    190
Posts posted by simonsunnyboy
  1. Did I ever add myself to this list? ;)
    Can'T remember, but in case I forgot:
    Falcon 030 with 14MB+FPU, Netus-Bee, solidstate flash drive running TOS
    I mainly conect it to my TFT via VGA but from time to time I use SCART and occasionally RF as well.
    Located in Friedrichshafen, Germany
  2. Any one will do, in case it comes with TOS 1.0 or TOS 1.02, you can upgrade to TOS 1.04 with few hazzle.
    A STFM or STE model would be good - they have an RF output so you can hookup a TV with ease. Picture quality is not good ut then you can lways use a SCART lead too.
    STEs have the advantage that you can easily upgrade the memory + they have some additional features as hardware scroll, more colors and stereo sound.
    Take note that most games will still run on STF and STFM as well. Games for STE only are rare.
  3. I apologize for not using simple Americanstyle English.
    * Paradize games are available for FREE.
    * Visit out website and feel free to download anything you like.
    * I repeat: NO MONEY IS CHARGED!
    * If anyone charges you money for stuff by Paradize, you have been ripped off!
    If someone wants to make money with Atari ST software, go ahead. But do not include any Paradize productions then.
  4. As a developer of what you call "homebrew" games I just want to say:
    Do what you please but take note: I do it for free (and surely it is for my fun), and I will tell anyone who is paying for a game released by Paradize that he should have spend his money on something else.
    And indeed, ggn is and was very helpful. Ofcourse such help between coders naturally doesn't have to happen in public...
    Just my 2 Euro cents :)
  5. Ok..then I'll have to buy a 60Hz capable TV set ;)
    Does this also imply that I can play NTSC cartridges on my PAL console as long as the TV copes with it?
    I made a photo of the two Missile Command cartridges, to the left the one not working on a 50hz only TV.
    (The topside label has been copied from another photo below the large one)
    Now I have spotted the P on the top label of the right, working, one. As the label is damaged on the left one, I didn't miss it.
    Maybe I should take care for this in the future...
    The Galaxians cartridge has no P markings..some of my other cartridges have small "p" stickers on the backside attached.
    Thanks for making clear :)
  6. On STs without modulators, you can create a COMPOSITE VIDEO signal with the following scheme:
    This should give you a black & white signal but it is better than no picture at all, probably fully ok to check if an ST is working at all ;)
    In case you have no COMPOSITE SYNC on pin 2, use the right scheme to create it...
    I have never tested those, being based in Good Old Europe, I can simply use SCART :D
  7. I wonder..is the 2600 sensitive to the TV set you use?
    I have two PAL consoles according to the bottom sticker (2600jr), and I have two cartridges in my possession which depend on the TV set if they display a proper picture.
    On the large end 90s TV set of my sister they work fine, this set also supports 60Hz PAL with my ST(e). On my older early 90s vintage TV set, they display some sort of rolling picture, e.q. 3 frames in one, compressed. It doesn't do 60Hz on my ST(e).
    The cartridges are "Galaxians" and "Missile Command". Oddly I have another "Missile Command" cartridge which works fine on my TV, however I can't spot a real difference on the cartridges.
    Is there a chance to tell whether a cartridge is PAL or NTSC?
  8. Have any ST games been hacked to support Jaguar controllers?
    No, it wouldn't be worth the effort. But basically you could connect the Jagpad to any DB9 joystick connector and let it act as your standard joystick.
    A schematic for this can be found in the "Extended Joystick Ports FAQ", EJP on the net or in the Atari-FOrum wiki: http://www.atari-forum.com/wiki/index.php/...stick_Ports_FAQ
    This would also have the benefit that you could use the Jagpad on other retro machines aswell, e.q. C64 and Atari 800.
