Gunstar
    12,077
    12
Posts posted by Gunstar
  1. 44 minutes ago, NISMOPC said:
    I am using a USB 5v 3A Motorola PSU for the 130XE as well as a generic 5v 3A for the Fujinet - I actually haven't thought about that. I'll try a stock PSU as well on the 130XE w/o USB power to Fujinet to see if any difference. I have several of the nice big PSU's, so I can try them out as well.
    3A should be plenty though, I thought you might be running on even half that. But, yeah, it wouldn't hurt to try stock PSU's if they output more amps.
  2. This is fantastic news! I love this game, but have only been able to play against the computer so far. I'm already a member of the game server, but was originally hoping for a Dragon Cart or PBI device to play. It was my hope that it would be converted for Fujinet. I assume we can download the new version at the 8-bit Slicks site? (I haven't watched the video yet if it says)
    I definitely see some lag in the game watching the video, it's especially obvious to me since there is none, and it's perfectly smooth playing off-line. But maybe that can be improved? Or is it dependent on your internet service speed?
    Ugg! those awful colors on that Atari! Someone needs a video upgrade!
    20210123_130442.thumb.jpg.277ed20bf47ca175d87a4012b0632da0.jpg20210123_130512_HDR.thumb.jpg.00affdbcd3ad0ae88177be85b089205b.jpg
  3. On 8/24/2019 at 2:30 PM, Faicuai said:
    ...the final fish / materials of the outer shell of these machines should NEVER. EVER be painted.
    Yeah, I realize this post was made well over a year ago, but I must have missed it then, and since this thread was just resurrected I needed to tell my opinion/perspective on the matter.
    While I'd rather try sun-brightening a case first, there are instances where paint may be required to really make it look right, like when repairing broken cases and cracks and other repairs are obvious, as well as when doing new I/O ports, like my transplanting the PBI part of a 600Xl (that was really almost beyond recovery so I save it by using it for salvage on other Atari's) PCB and case on my 1200XL. But then, if you are already modifying the case, then it's original value or resale value are out the window anyway. And THAT is the only reason I see in your having this opinion, but if one intends to keep their machine "forever" or likes to do mods anyway, then "NEVER, EVER" is "Never Say Never."
  4. Another good idea by @_The Doctor__! I've reduced from Divisor 0 to 6 because I'm now using the Weather.atr on a daily basis and even multiple times a day, but so far, which isn't much I grant you, Divisor 0 on Fujinet has worked fine otherwise and it would be great if the program was adjusted to work at divisor 0, but I would like to use 0 and then change it to whatever is needed on the fly because I'm sure this won't be the last program loaded over Fujinet that behaves this way, and probably isn't the first, except to me.
  5. On 1/21/2021 at 11:28 AM, _The Doctor__ said:
    the metal pins are too short...they only need to be a fraction longer. if that can't be then the socket floor where the pins come through could be printed thinner.
    Who produced that particular Fujinet? I got mine from The Brewing Academy, it seems like it has the same issue, though luckily I don't have to use the pass-thru SIO usually, since I recently installed a second SIO to my 800. Or maybe everyone is using the same 3D printer .stl so all are the same?
  6. 17 hours ago, NISMOPC said:
    Interesting observation with my modified 130XE and SIO power vs. USB power on Fujinet 1.0.
    I've added 512K SRAM, DUAL Pokey and 4in1 OS switch and am using a S-Video cable to LCD.
    If I power the Fujinet from SIO, I get minor vertical lines in display and the display has a slight dimness to it.
    If I power the Fujinet from USB, vertical lines completely disappear and the display is nice and crisp.
    I know the 130XE has poor shielding, but any thoughts why powering the Fujinet off USB would resolve that?
    I'm using my Fujinet on an Incognito 800, which can work fine without additional power, in the sense that the BIOS load screen gives the Fujinet time to get ready, were stock 400/800 and 1200XL's boot too fast. But just to be on the safe side, with all the upgrades I have installed (beyond the Incognito) I thought it better not to put additional amperage drain on the 800 and have been using the USB power from the start. Of course I use the Atari "universal" PSU, the version with 31VA (3.4 amps), so I think it could handle the extra amperage load. How many amps is your PSU rated for, @NISMOPC? I haven't even tried it without the USB PSU, except when I had to plug it into a PC to flash the latest firmware.
  7. Very cool! And the thread is from 2008! So @Urchlay decided to call it 'Fujichat' long before (over a decade!) Fujinet was even a thought! What a coincidence!:o Is there a newer version out there than 0.3? I would have thought it would be updated to a newer version in the last decade+. Is @Urchlay still around? Is it a dead project and this is all we can hope for from it? Of course I didn't read the whole thread yet, so maybe an update was mentioned later in the thread? I'll go check...
    The link for download on the first post doesn't work anymore, where can it be downloaded from, if anywhere anymore?
    Edit, Ok, went through the thread and the last posts by Urchlay were in 2019 and it looks like the latest versions are either 0.4 or 0.5pre3. there are a couple places in the thread to download directly from AA, but none of Urchlay's links work at all.
    Here is what appears to be the latest versions in this .zip I just pulled from that thread, just so you don't have to go to it if you don't want too.
    FujiChat.zip
  8. I just figured out the problem. I had set my HSIO on Incognito and on Fujinet to divisor 0. I just changed my Incognito BIOS back to standard SIO speed and now weather.atr works fine. I hadn't thought about that until now. So I'll do some further testing as different divisors and see when it stops working right.
  9. @bocianuI updated to the latest firmware as of yesterday, unless it's changed again since then. I only got my Fujinet a few days ago. It was working fine yesterday too. I'll check it out again though...I just tried again and it still hangs at the "checking forecast" screen, sometimes when it does it show a "c" down in the corner. And for the heck of it I changed cities, I tried London,UK, and it also gave me the current weather, but when I tried to load the forecast it hung again, but has a "ca" down in the corner sometimes, sometimes nothing.
    I can hit ESC and it will go back to current weather and all the other options work like changing the graphics and units and refresh. etc. If I let it sit on "checking forcast" for a while, the screen sometimes changes to light blue, showing my city, state and country at the bottom, and if I hit the space bar the "next", "back", and "quit" options show up, but "next" does noting and back will load the current forecast screen back up. sometimes this doesn't happen, but I can go back with ESC. And sometimes the entire program just freezes and I have to do a cold start.
  10. It turns out, thankfully, it's not an issue with my 800 at all. Luckily before I started taking her apart again I check my sound system and a wire came loose from the speaker that puts out the original POKEY sound, so I was only getting sound out of it from the 2nd Pokey. Now I hear S.A.M!
  11. Ok, thanks for the info there, but I think the problem is on my end; I just loaded up a stereo sound file to play and I'm only getting partial sound, so something probably happened when I had the 800 apart a few days ago to install a Sophia 2 board. I hadn't been using any programs with sound since then, and Incognito BIOS shows "Stereo: Present"  and I just didn't notice/know my computer wasn't working right in the sound department. Now I know...time to open her up again and see what went awry. Thanks!
  12. 10 minutes ago, tschak909 said:
    Sorry, I must not have been clear. I was able to reproduce speech just fine.
    Can you load the #FujiNet flasher and see if you get similar results when doing speech output? This would help isolate if there's an incompatibility somewhere, or if there is a hardware fault (for example, the Audio IN line not connected)
    -Thom
    You were probably clear enough for most, I'm not a programmer (yet, learning BASIC and Assembly now, but still a noob) so your debug list above was Greek to me. Are you referring to the flasher program on the PC to update the Fujinet firmware? Again, a noob with Fujinet, so I'm not aware if there's a flasher I can load onto the Atari yet, if you mean something other than the firmware flasher on the PC. I can tell you that when I updated the firmware yesterday I got no speech output if there was supposed to be some. I should also probably point out that my Incognito 800 has a Pokeymax Quad+Covox installed. It could be an issue with it I'm having.
  13. 2 minutes ago, tschak909 said:
    Are you testing with a 400/800 machine? those don't have access to P4:
    -Thom
    I'm testing with an Incognito 800 in XL/XE mode...does that not make a difference?
  14. I decided to continue this thread instead of starting another, since it was already here.
    I was trying to test S.A.M out. I loaded up the SAM-Test.atr and it loaded and set up the ramdisk and went into BASIC and gave me the READY prompt. I was expecting more. So I went to the Fujinet wiki and into the S.A.M instructions and I used the OPEN #1,8,0,"P4:" command, then tried the PRINT #1;"HELLO" but nothing happens, no voice. I saw the Fujinet activity light for a brief moment only then back to READY.
    So I reloaded the SAM-Test.atr and just got the READY prompt again, I typed LIST and see there is the four line program there, but it does nothing when run, just like me entering the commands in direct mode.
  15. On 1/18/2021 at 8:52 PM, Kyle22 said:
    I want an 800 card.
    That would be cool, definitely. But I could use a PBI version on both my 1200XL and 800 now, so I don't have to worry about if someone ever uses the 800 internal slots for anything or not!:cool: It would definitely make things neater than a chain of PBI devices out the back though...but then I'm going to make my own PBI device box for multiple PBI devices in the near future.:music:
  16. Has anyone been having issue getting the forecast with Weather.xex/atr today? Yesterday everything worked great for me, but today I can only get current conditions and when I go to forecast it hangs at "checking forecast" and sometimes it freezes and I have to reboot and other times I can get back to the current conditions. Everything else seems to be working right though. If you have looked at the weather on your fujinet today can you tell me if the forecaster is working for you or not? I want to figure out if it's an issue on my end or with the service maybe?
  17. While I am awaiting a non-functioning Sophia 2 to return to Simius to diagnose and a new one sent out, I have been checking out terminal programs with my Fujinet, and here is what Flickerterm looks like through my S-video to VGA converter (sorry about the glare):
