1,270 -
Posts posted by unhuman
Ok - I've used the Harmony cart software (v1.1) to upload ROMs directly to the harmony cart. I tried Combat, Space Invaders, and Asteroids. I pointed the "arm" dir to the "arm" subdirectory off where the Harmony software is installed. It appears to detect the correct bankswitching format (chose 8k for Asteroids and 4k for Space Invaders). It uploads the ROMs to the cartridge. I take the cartridge and put it into my Atari and get nothing. Black screen. Tried both my Flashback 2 and my 7800.
I presume for this, there is no need to have an SD card installed into the Harmony cart, right?
This mean anything? If there is a simple thing I can check by opening up my cart, I'd be willing to do that, but if it's something else, I'd certainly prefer you do it.
-Howie
Got mine today... I'd've preferered a cable just to give me more flexibility with a hack. God, I'd love to get this and a speech synthesizer embedded in my TI.
Ah, nice to see he's using a right angle header on the board now. I accomplished the same effect on mine with a very small F/M IDE cable and a rubber band.
Sure, I'm willing to try anything. My friend said he couldn't find his console
Will try this tonite. Good to understand how your process is though - I rarely get insight into how stuff is made.-Howie
Thanks for all the tips!
I used Isopropyl alcohol with a Q-tip.
I do know what I'm doing
I'll try the single game using the dev tab tonight. Got a friend coming over tonight and hopefully he found his 2600 buried in his basement... We'll try that too if he did. I don't have access to a 2600 otherwise (at my parents house, 60mi away).
Are the carts all tested before shipment? I would assume so given the small nature of the operation. I'm just wondering when I should flip the "I've gotta be crazy" switch to "Yeah, it's busted." But again, I'll try more tonight.
The carts are tested 4 times at various stages of construction. I assemble the main board and program a single game in the Melody programmer to it and assure it works. I assemble the daughterboard and ensure it is detected by Windows, and program the USB chip before attaching to the main board. I attach the boards, install Harmony BIOS and test the bare board in the console. Then I put it in a cart shell, label, and one more test before packaging and shipping.
The reason I want you to load a single image is to see if the problem is the EEPROM chip. Not the chip itself but a solder joint on it. If one is bad, you could get the issues you see but single images will work perfectly. If this is the case, of course you'll get a replacement cart.
Yes. I did a video mod.
For old solder - I needed to use a 30W iron as my 15W and 20W wouldn't melt the old solder on my CV... So, I dug out my 30W and it was fine.
-H
Does CV mean Coleco Vision?
Thanks!
-H
Try loading a single game to the Harmony using the development tab.
Also, when you cleaned the edge connector, how did you do it? There is a chance that soldering flux got on it during assembly and this could cause the problems you have. Isopropyl alcohol applied with a Q-tip to the contacts should clean it off.
I've done this multiple times - each time I've swapped to a different memory card.
And, as Dauber suggested, I have the drivers for the harmony cart serial port interface - else it wouldn't detect the cart at all. Everything gets "green" and copied over. I put the cart on USB port (w/o memory card in it) and the memory card into a distinct card reader. Copy it all over. Doesn't work.
The Firmware I am using is: eeloader_104e_NTSC.bin (13.7 KB (14,072 bytes))
The BIOS I am using is: hbios_104e_NTSC.bin (93.0 KB (95,232 bytes)) - which gets copied to root of SD card.
And, I'm using v1.1 of the harmony software to do the uploads to the cart.
Thanks,
-H
I would download the eeloader to the cart again. Make sure you are using the 1.04 eeloader that came with the 1.04 BIOS or it will not work.
As I said in my edit, I tried an SD card - PQi 2GB - formatted fat32. Didn't work. Has the same issues. I will try another. Don't have high hopes at this point.
Edit: Trying another SD card... I'll update again when it's tested.
Edit: Kingston 512MB SD card - same problems. For this one I have hbios and some roms in the root, in addition to various folders, etc... Still nada. This one formatted as FAT, identifies as "Texas Instruments PCMCIA Secure Digital Controller"
Edit: Reformatted above card as FAT32. Has hbios.bin (from Harmony tool) and SI.bin (Space invaders) and that's it. Nothing else. Still same results.
-H
Harmony does not support MMC cards, and since your card comes up as "MultiMediaCard" this is clearly the problem. You need to use a genuine SD card.I just got my harmony cart and updated it's firmware to 1.04 bofore first use. Doesn't work. All my other carts work fine on 2 consoles (Atari 7800 and Hacked Flashback). Tried my harmony on both with no response. A few times I was able to get a spinny-wheel (once on each console) but it was very, very touchy - and never came back. I cleaned the contacts on the edge connector of the cart (they were very dirty, even though brand new). Still nada. I've been unable to get it to work again.
The memory card I am using is a 16MB Canon Memory card (Windows things it's a "Texas Instruments PCMCIA MultiMediaCard Controller"). It's amazing how many carts can fit on that thing.
Regarding the card. I formatted it, and then copied the file during the firmware upgrade process. I then copied all my cartridge directories in place.
Do I have a bad cart? I'm going to try a different SD Card as well, but the fact that the cartridge generally doesn't work at all (can't get spinny wheel anymore), I am doubtful that's the problem.
Thank you!
-Howie
Thank you!
-Howie
Edit - few more notes:
1. My 16MB card is formatted as FAT (dunno if FAT12 or FAT16 - Windows doesn't say).
2. Just tried 2GB card (FAT32) - same issues - both consoles.
3. Tried a diff 9V adapter for Flashback (one it comes with is 200ma, I found one in house that's 300ma). Same issues. My Atari 7800 comes with a 1000ma (1A) adapter. Don't have another due to funny connector.
Where are these manufactured? China or USA?
I just organized mine by Manufacturer... And "unknown" and "homebrew" - I started with AtariMania.... If someone would package up all the homebrews - that'd be nice.
If nobody does, it might be me.I used a regex-based file renamer to make "quick" work of alot of the renames required... Quick really is just "less long". Probably took me about 2 hours to whittle the list down, de-dupe, etc... I still haven't actually used it yet. This weekend!
-H
Think you just voided *TWO* Warranties.
Not quite atari, but I have this Playstation2 -> Wiimote adapter
http://www.dealextreme.com/details.dx/sku.23206
It rocks and it is wireless. Gamecube controllers require wires.
-H
He's listed a few more and I got one
eBay Auction -- Item Number: 200439167063
and
eBay Auction -- Item Number: 200439170235
They're slightly different than the other ones listed - and slightly different from each other.
-H
Yeah, recover quickly. I think you shipped mine but I'm still waiting for mail delivery after all the snow. Had hoped to get it before the storms, but oh well....
-H
Oh - what a great explanation. I should take a look at the switch from my CV that won't power up then...
I don't play mine often enough to warrant the time & effort since there's good emulation on the Wii these days
-H
His directions for the video mod were great. Probably too much detail sometimes
But... for those of us who can hold a soldering iron, but can't build a circuit, these are perfect. Not really sure I get the advantage of swapping memory, so perhaps some "marketing" on the cost / benefit would be nice.-H
The original memory runs off of 3 voltages: +5, +12, and -5. The Colecovision has a very finicky power supply switch that doesn't make good contact when it gets dirty. This causes the system to power up in states where it won't run. The power supply is also a common point of failure and the tri-voltage chips run hot.
By putting +5v only DRAM in the system you are removing the power on complexity of the tri-voltage DRAM. This reduces current draw on the +12 and -5v sections of the power supply and they run cooler. The system will power up more reliably without the need for flicking the problem prone power switch back and forth to get it to boot properly.
RJ
Sounds cool please make instructions as detailed as possible with lots of step by step pics if you can.
Not that I ever noticed, but who the hell made it blue? Damn that looks good!
This hack was done 8 years ago, you know, when you where 4 years old.People born after 1965 are interlopers. They must be dealt with swiftly and harshly.
1965? Move that to 1975 and I am in agreement
Storm looming. Maybe the postman will make it today... Hoping!
I've just received your mod. Thanks a lot!
F.
Yeah, this CV emulator is WAY better than the other one. Better UI getting to the game and way better gameplay - at least this one plays my (incomplete) game.
ordered mine today
This is the original one - have all the materials and it has Stella Gets a New Brain CD with it. I think it's still sealed (as I had one from the original Stella get a new brain series - didn't need to open it). If I ever used it, it was a long time ago, but I can check it out before selling.
I don't know what it's worth, directly, so feel free to make an offer or provide guidance. They don't come up very often.
Thanks - Howie
Highly recommended!
Just got a note from my supplier... the parts I had on backorder have shipped and I should have another batch of kits done this weekend.
Still waiting for mine. Maybe takes longer b/c preassembled? Or maybe my mailman is slow.
Harmony Cart Problems
in Harmony Cartridge
Posted · Edited by unhuman
Oh... It just played space invaders... But then I powered off and powered back on and same problem. Repeatedly.
I found a post from long ago (last year) talking about how the cart needs some time to initialize and doesn't work a small percentage of the time... Could I be running into that? Of course for me, it's the inverse. A vast majority of the time it doesn't work.
Edit: More info... Switched to asteroids. That worked (unreliably) so switched back to the harmony software. Without the card installed, still unreliable, but tells me no SD card.... When it works. Seems to be working more frequently than before... but not reliable. My other carts all work first time. This definitely is hit-or-miss. And mostly miss.
Edit: Switched back to Asteroids - can't get it to work. Switched to Space Invaders - can't get it to work.
Thanks - Howie
