retroclouds
+AtariAge Subscriber
    2,123
Posts posted by retroclouds
  1. Just a FYI,
    You might want to consider adding EXTERNALS. Now, nobody really ever did anything with My-Word with Externals for the Geneve, however Petter Hoddie wrote out a good specification. It gave one the ability to add features to the program without modifying the program itself.
    My penny's worth...…….
    Beery
    Sounds interesting. Did a quick search but could not find the spec. Interesting to see he was the mastermind behind the Apple Quicktime player.
    Do you know where the spec can be found?
  2. Even though I didn't code this week progress has been good so far. Scrolling works and now one of the next steps is to get insert/delete lines working and really should start getting code in for loading files.
    The thing is that it is kinda of hard to try out scrolling, etc. if each time you reset you start with an empty editor buffer. As I wrote before, TiVi will work with both SAMS and plain 32K memory expansion.
    Then this got me thinking, looking at the finalgrom cartridge specs it supports up to 512K of bankswitched RAM (4K pages).
    Am seriously thinking adding support for that, as it would make it very interesting if you are running a stock TI-99/4A without PEB and SAMS, e.g. TiPi, nanopeb and the like.
    At this stage it is a lot experimenting and of course the feature list gets longer all the time, so will have to get my priorities straight.
    But hey, that is part of the fun right.
    • Like 5
  3. I use the F'WEB 80-col editors. With 192K of VRAM in my AVPC card, and cut and paste facility, I cab do just about anything I want with either text or A/L programming.
    I want to try out some more editors to see how they behave on the TI-99/4a.
    Does Funnelweb work with 32k as well? Would it be possible to do a short video. Interested in seeing how responsive it is with the 192k vram. thx.
  4. Update: I will supported the 9938 as well. At least up to a certain extent. F18a is primary focus though.
    Progress is good. I have most of the memory structures in place and they are working as expected.
    • fb - Frame buffer. This basically matches a rectangular window as part of the physical screen. This is basically where the text resides until enter is pressed or key up/down is used.
    • idx - The index. It's the link between the line numbers and editor buffer.
    • edb - The editor buffer. This is where the text resides after the line is "crunched" (packed). Currently it's a copy-on-write without compression, but might be going for RLE compression.
    For each of these structures I have a support module. Here's ane extract:
    * Frame buffer structure @ >2000
    * Frame buffer itself    @ >3000 - >3fff
    fb.top.ptr      equ  >2000          ; Pointer to frame buffer
    fb.current      equ  fb.top.ptr+2   ; Pointer to current position in frame buffer
    fb.topline      equ  fb.top.ptr+4   ; Top line in frame buffer (matching line X in editor buffer)
    fb.row          equ  fb.top.ptr+6   ; Current line in frame buffer (offset 0 .. @fb.screenrows)
    fb.row.length   equ  fb.top.ptr+8   ; Length of current row in frame buffer
    fb.row.dirty    equ  fb.top.ptr+10  ; Current row dirty flag in frame buffer
    fb.column       equ  fb.top.ptr+12  ; Current column in frame buffer
    fb.colsline     equ  fb.top.ptr+14  ; Columns per row in frame buffer
    fb.curshape     equ  fb.top.ptr+16  ; Cursor shape & colour
    fb.curtoggle    equ  fb.top.ptr+18  ; Cursor shape toggle
    fb.yxsave       equ  fb.top.ptr+20  ; Copy of WYX
    fb.dirty        equ  fb.top.ptr+22  ; Frame buffer dirty flag
    fb.screenrows   equ  fb.top.ptr+24  ; Number of rows on physical screen
    fb.top          equ  >3000          ; Frame buffer low memory 2400 bytes (80x30)
    ;                    >200c-20ff     ; ** FREE **
    * Editor buffer structure @ >2100
    edb.top.ptr     equ  >2100          ; Pointer to editor buffer
    edb.index.ptr   equ  >2102          ; Pointer to index
    edb.lines       equ  >2104          ; Total lines in editor buffer
    edb.dirty       equ  >2108          ; Editor buffer dirty flag (Text changed!)
    edb.next_free   equ  >210a          ; Pointer to next free line
    edb.top         equ  >a000          ; Editor buffer high memory 24576 bytes
    ;                    >2102-21ff     ; ** FREE **
    * Index @ >2200 - >2fff
    idx.top        equ  >2200           ; Top of index
    And here's how on of the routines in the edb support module looks like. I'm using xas99 which allows a lot of flexibility in using labels. That helps a lot. :)
    * edb.line.pack
    * Pack current line in framebuffer
    *  bl   @edb.line.pack
    * INPUT
    * @fb.top       = Address of top row in frame buffer
    * @fb.row       = Current row in frame buffer
    * @fb.column    = Current column in frame buffer
    * @fb.colsline  = Columns per line in frame buffer
    * OUTPUT
    * Register usage
    * tmp0,tmp1,tmp2
    * Memory usage
    * rambuf   = Saved @fb.column
    * rambuf+2 = Saved beginning of row
    * rambuf+4 = Saved length of row
    edb.line.pack:
            dect  stack
            mov   r11,*stack            ; Save return address
            ; Get values
            mov   @fb.column,@rambuf    ; Save @fb.column
            clr   @fb.column
            bl    @fb.calc_pointer      ; Beginning of row
            ; Prepare scan
            clr   tmp0                  ; Counter
            mov   @fb.current,tmp1      ; Get position
            mov   tmp1,@rambuf+2        ; Save beginning of row
            ; Scan line for >00 byte termination
    edb.line.pack.scan:
            movb  *tmp1+,tmp2           ; Get char
            srl   tmp2,8                ; Right justify
            jeq   edb.line.pack.idx     ; Stop scan if >00 found
            inc   tmp0                  ; Increase string length
            jmp   edb.line.pack.scan    ; Next character
            ; Update index entry
    edb.line.pack.idx:
            mov   tmp0,@rambuf+4        ; Save length of line
            mov   @fb.row,@parm1        ; Current row in Framebuffer
            ; Store line inline in index if length <= 2 characters
            ci    tmp0,2
            jgt   edb.line.pack.idx.normal
            mov   @rambuf+2,tmp1        ; Retrieve beginning of line
            mov   *tmp1,@parm2          ; Store word inline
            mov   tmp0,@parm3           ; Length of line
            bl    @idx.entry.update     ; Update index entry
            jmp   edb.line.pack.$$      ; Exit
            ; Update index and store line in editor buffer
    edb.line.pack.idx.normal:
            mov   @edb.next_free,@parm2 ; Block where packed string will reside
            mov   @rambuf+4,tmp2        ; Number of bytes to copy
            mov   tmp0,@parm3           ; Set length of line
            ; Pack line from framebuffer to editor buffer
            mov   @rambuf,tmp0          ; Source for memory copy
            mov   @edb.next_free,tmp1   ; Destination for memory copy
            bl    @xpym2m               ; Copy memory block
            ; Update pointer to next free block
            a     @rambuf+4,@edb.next_free
            ; Exit
    edb.line.pack.$$:
            mov   @rambuf,@fb.column    ; Retrieve @fb.column
            b     @poprt                ; Return to caller
  5. Think that the TI-99/4a with todays extensions such as FGROM, F18A, nanopeb and the like has a lot more potential compared to the TI-99/8. And with ralphs SD99 coming...
    That being said, really would love a TI-99/8. It is such a pretty machine.
  6. I'm looking to buy a beige TI-99/4a console.
    If you are located in Europe and wanting to sell a beige TI-99/4a then please contact me.
    Sorry, reason I'm only interested in a console from Europe is because I somehow got on a "black list" at customs.
    Everything I order from outside Europe I have to go pick up in person at a customs office, "requesting" me to open the parcel so
    they can verify what's inside and charge taxes accordingly.
    That really bothers me. The last time I bought an original packaged p-code card I had to open it, otherwise I could not take it home.
    Kinda ruined it for me.
    Anyway, long story short if you are located in Europe and want to get rid of a beige TI-99/4a, I'd be interested. ;-)
  7. Is there a proper way to fully reset the F18a after coming out of 80 columns/30 rows mode?
    In the following demo I run the F18a in 80 columns, 30 rows mode and then exit to the title screen by doing a blwp @0 after having done the below steps:
    1. Turn bit >40 in VR49 off
    2. Lock the F18a
    NOTE: At the end of video I wrote 30 columns mode, that is wrong ofcourse, it's 30 rows mode.
    Recorded with js99er. The behaviour is consistent on the real deal and js99er.
    I have to turn the TI-99/4a to reset the F18a.
    Even swapping modules and going to TI-Extended Basic for example shows the same behaviour, so I presume the F18a is still stuck in 30 rows mode?
    Unfortunately I can't test it on classic99 as this mode is not (yet) supported.
  8. I will be using this thread to document the development of a new programmer editor for the TI-99/4a called "Stevie".
    Download the cartridge image in the official release thread.
    As you might expect from its name, the editor is somewhat inspired by the unix editor "vi" and will also take elements of "tmux".
    So what do I have in mind:
    • Designed from the ground up for 80 columns mode, specifically using the F18A but 9938 will be supported as well.
    • Designed from the ground up for using SAMS card, albeit 32K memory expansion should work as well.
    • Will support FinalGROM 512K bankswitched RAM in addition to SAMS and 32K memory expansion, useful for those without SAMS and PEB.
    • Programming language of choice is TMS9900 assembly language
    • The editor itself will run from cartridge space (multi-bank cartridge).
    • Uses my spectra2 library as foundation (been doing major changes in the last couple of months, not related to games)
    • Will have some "API" so that I can integrate with external programs and go back and forth between programs.
    • Would like to add some kind of mouse support. This will not be a GUI in the traditional sense.
      If you used tmux with a mouse before you know what I mean.
    • Possibility to have multiple editor panes open at once.
    • Should handle files with up to 65536 lines when using SAMS or FinalGROM 512K bankswitched RAM.
    • Undo functionality, well up to a certain extent that is.
    • Language awareness, e.g. behave differently based upon language (e.g. assembly, C, Basic, ...)
    • Internal text representation will be decoupled from what actually will be rendered on screen. Should make the editor more responsive when dealing with large files, allow split panes, etc.
    • Reconfigurable keymaps, possibility to swap between keymap with single key combination. Not everyone is into VI ;-)
    This is the start of a large project and I don't expect to have a truely useful version anytime soon.
    I expect this project to take multiple years, but you gotta start somewhere.
    Now I've taken my mouth full, I will use this thread to keep myself motivated 🙂
    There aren't too many resources out there discussing the architecture of a text editor, so cross-linking here.
    Threads on Atariage discussing topics -somewhat- related to TiVi:
    Others:
    Cartridge ROMs
    • 2021/02/06 - Stevie 1.0 released
      • Atariage handle added in "About" dialog
    • 2021/01/30 - Stevie 1.0 BETA 2
      • Polished about dialog (show all key mappings)
      • Polished color schemes
      • Bugfix: Properly initialize all SAMS index banks  (fixes potential crash issue for files >2048 lines)
      • Bugfix: Show code block filename instead of editor buffer filename when IO error during block save
      • Bugfix: Show updated counters when saving file
      • Bugfix: Added memory full error during file load
      • Bugfix: Don't crash editor when reaching bottom of file after delete operation
      • Bugfix: Properly refresh frame buffer when at end of editor buffer
      • Bugfix: Refresh screen early when starting file load operation
    • 2021/01/22 - Stevie 1.0 BETA 1
      • F18A + SAMS required, TIPI and HRD4000B optional
      • Tested with emulation on http://js99er.net
      • Tested on a TI-99-4a having F18a, 1MB SAMS, TIPI PEB and HRD4000B
    Key mapping
    Movement keys:
        Fctn-S        Move cursor left
        Fctn-d        Move cursor right
        Fctn-e        Move cursor up
        Fctn-x        Move cursor down
        Fctn-h        Move cursor to 1st column on line
        Fctn-j        Move cursor to previous word on line
        Fctn-k        Move cursor to next word on line
        Fctn-l        Move cursor to last character on line
        Ctrl-e (^e)   Move page up
        Ctrl-x (^x)   Move page down
        Ctrl-t (^t)   Move to top of file
        Ctrl-b (^b)   Move to end of file
    Modifier keys:
        Fctn-1        Delete character
        Fctn-2        Insert character
        Fctn-3        Delete line
        Fctn-4        Delete until end of line
        Fctn-5        Insert line
        Fctn-.        Toggle between inser/overwrite mode
    Action keys:
        Fctn-7        Help, shortcuts, about
        Fctn-+        Quit editor
        Ctrl-o (^o)   Open/Load DV80 file into Editor
        Ctrl-s (^s)   Save editor buffer to DV80 file
        Ctrl-v (^v)   Set M1/M2 marker for block operation
        Ctrl-r (^r)   Reset M1/M2 markers
        Ctrl-z (^z)   Cycle color schemes
        Ctrl-, (^,)   Load previous file
        Ctrl-. (^.)   Load next file
    When block selected (M1 + M2 set):
        Ctrl-d (^d)   Deleted marked block
        Ctrl-c (^c)   Copy marked block to current line
        Ctrl-g (^g)   Goto M1 marker in editor buffer
        Ctrl-m (^m)   Move marked block to current line
        Ctrl-s (^s)   Save marked block to DV80 file
    • Like 13
  9. I used this document to get started with the pcode system on the TI, with supplemental reading from the manuals as needed. It's a tutorial by Ron Williams from the Boston Computer Society TI 99/4A User Group.
    Introduction to UCSD Pascal System.pdf
    I would like to add the document to the development resources thread. Could someone who is a lot more UCSD Pascal savvy as I am check the devres thread and tell me what is missing in terms of pascal documents, disk images and the like. Planning on doing a thread update by the end of the year. Would be cool if we could get a UCSD Pascal starter bundle. Thanks
  10. Not sure if this is a bug in js99er. If you open the debugger and set a view address (e.g. CPU memory >8300) then afterwards the keyboard doesn't work anymore in the emulator.
    You can test it with Pitfall. Even if you press the "Reset" button they keyboard still seems to be disabled.
    Either way, that's a fantastic emulator you have there. Very impressive! :thumbsup: :thumbsup: :thumbsup: :thumbsup:
