266 -
Posts posted by fox
Is the PAL 800 palette the same as the PAL 2600 palette?AFAIK, yes or at least very similar.
Probably "most of the time" rather than "at all".Could you give some examples, please?
One example would be "Muad Dib Demo" which is crypted using
XL/XE OS contents - it needs the original ("old" version) OS to run.
I'm sure there are many programs which use unofficial addresses
in OS, not only for routines, but also lookup tables
(e.g. $80,$40,$20,$10,$08,$04,$02,$01).
Another class of programs is these which copy the original ROM
contents to RAM and then patch it.
I also doubt if Atari++'s OS emulation is 100% compatible
with the original OS (including details like C flag set when returning
from SIO - some programs really rely on this).
Where have you been for the last ten years?
Basically, HIP is 160x239x30 shades and TIP is 160x119x256 colors.
A few years ago I have posted English description of TIP to Heaven
and Raster. Heaven, do you have it somewhere?
Thomas then replied that he wrote every piece of code for the Atari++ emulator from scratch.Maybe 95%, but surely not 100%. There were same typos in "his" code
as in Atari800, would you believe he hasn't copied it?
Anyway, the war between Atari800 team and Thomas is now history
and I wish Atari++ well.
Noteworthy: Thomas also implemented an OS-emulation, i.e., there is no need to use copy protected Atari-ROMs any longer.Probably "most of the time" rather than "at all".
Atari800 has "emuos" that is enough for running some games.
Perl rules!
For those Windows users who don't want to download
and install megabytes of ActivePerl:
http://www.mhuffman.com/resource/perl/
Actually, for many scripts perl.exe+perl58.dll are enough.
And please s/PERL/Perl/ !
There's a Perl script in cc65 that pretty prints 6502 code (and ca65 directives) in HTML. I don't know if it can change formatting or just adds HTML markup.
found reference to the Stelladaptor but it doesn't say anything about supporting the trak ball.It will work.
Will it work OK on the PC as my main input device for everyday PC applications?Not without special drivers.
Try Atari800.
I don't know if the MacOSX port correctly supports the 5200
- if not, ask the author for it, it is easy.
I tried an ATR of SSI's "The Cosmic Balance" with the latest version of Atari800win. Seems to boot and load DOS but the screen blanks and nothing happens. I played with all the settings, but no luck.The game enables a POKEY timer interrupt at a very high frequency.
The emulation of POKEY timer interrupts is inaccurate in Atari800 (Win).
A workaround is: press F8 and type:
c 10 40 cont
What surprised me was... MESS had no trouble with it! I don't know who coded the a800 driver, but it's fairly primitive compared to Atari800win.I guess MESS doesn't emulate POKEY timer interrupts at all.
In your atari800 win+ (final) are you going to have a secondary rom option for alternative drive roms (like happy, lazer etc etc)Atari800 does not emulate drive's CPU or ROM.
What are these?
We hope there will be BASIC loader in final version.I implemented the BASIC loader in the development version of Atari800.
RE: Fox - yes I did get back, hopefully OK now.Ok, thanks.
The above formula is for NTSC. For PAL, replace 60 with 50, or even better 49.86074561.
Or maybe you want the R-Time 8 cartridge: it has a battery-powered real time clock with real date and time.
The comment is misleading, the problems are because the special values are not negative: (input_win.h)...
I think they should be changed to some negative values.
I agree the comment is misleading - especially as a group of bits are used to indicate a special value.
In terms of a 16 bit integer, they are negative as the high bit is set.
But these aren't 16-bit integers.
And I don't see a reason for AKEY_HELP to be ORed with SPECIAL_HANDLER_MASK. So the above code from input_win.c should be completely removed.IIRC, this does make sense as on the XL the help key also produces a '?' keypress.
No. Help has its own keycode.
The 3 cases are required as you cannot mask out the 'AKEY_HELP' pattern within the switch.I meant SPECIAL_HANDLER_MASK shouldn't be set for AKEY_HELP.
YES... i want "numbers changing"...Live preview of $d20a would be entertaining, right?
... Fox...remember when we coded our GBA stuff years ago...havent you used a nice GBA emulator with all this features i want to have? or No$GBA?
IIRC, I used VisualBoyAdvance. But it had GUI-based monitor too, I think.
Monitors are for coders/hackers, so command-line driven interface is good. It's faster for me to type "d 8000" than to precisely drag scrollbar of disassembly window.
And on Win 2k/XP the console window has history, so you can see the output of previous commands. Can you do that with GUI?
I personally hate that I can't change fonts in GUI-based monitors. This is easy for console windows. And Alt+Enter rules. And you can copy/paste from the console window.
/* There are some key values below zero, handle them here */ if( _IsFlagSet( g_Input.Key.nNewKey, SPECIAL_HANDLER_MASK ) ) { switch( g_Input.Key.nNewKey ) { case (AKEY_HELP | SPECIAL_HANDLER_MASK): case (AKEY_HELP | AKEY_CTRL | SPECIAL_HANDLER_MASK): case (AKEY_HELP | AKEY_SHFT | SPECIAL_HANDLER_MASK): if( MACHINE_XLXE == machine_type ) g_Input.Key.nNewKey &= ~SPECIAL_HANDLER_MASK; else g_Input.Key.nNewKey = AKEY_NONE; break; default: g_Input.Key.nNewKey = AKEY_NONE; } }The comment is misleading, the problems are because the special values are not negative: (input_win.h)
#define SPECIAL_HANDLER_MASK 0xf000 /* codes in atari.h file */ #define AKEY_OPTIONDWN 0xffe1 #define AKEY_SELECTDWN 0xffe2 #define AKEY_STARTDWN 0xffe3 #define AKEY_OPTIONUP 0xffe7 #define AKEY_SELECTUP 0xffe8 #define AKEY_STARTUP 0xffe9 #define AKEY_MONITOR 0xffea
Fox, are you helping Jaskier in terms of development the emulator?Actually I'm working on Atari800 (for about 5 years or so).
- register windowshow
- window with the actual disassembling which is going to be updated while running (in debug mode)d addr
- VRAM visible (player/missles/fonts/DLI indicators)But you see them, don't you?
- custom chip register visible (antic/gtia/pokey/porta/portb)antic/gtia/pokey/pia
- display listdlist
all of course dynamic and updated in runtime...that would be really cool... i personally like the new debug features but i hate that the debug window stops the mulation so no realtime changes possible... (a monitor should "monitor"
uh-oh. You just want lots of numbers changing at high speed, that you can't read at all?
this is my wishlist and not to forget: real pokey emulation as accurate as possibleit's already quite good, I think
and real PAL/NTSC support like on Wice.What?
Maybe except for ASCII 0-31, 128-255 and the comma (which is commonly used to separate the two filenames for the rename command).Right, I forgot about the comma...
And also '?' and '*'.
Who said it can't be? I'll think about it. I'll probably reuse "Load executable". BASIC files can be easily identified (they start with two zeros).Thinking of something else... Call me crazy but do you believe we could have this for programs written in other languages?
No.
Anyway, using the tape recorder option is absolutely PERFECT for what we want to do. Thanks again for suggesting that
Well, it's good but not PERFECT. I'm going to implement direct BASIC loading anyway.
That would be a great compromise if a true BASIC loader can't be implemented.Who said it can't be? I'll think about it. I'll probably reuse "Load executable". BASIC files can be easily identified (they start with two zeros).
Actually, everything Windows allows
There's an alternative for using H: to load BASIC files. Insert the file as a tape image and type:
CLOAD
(you'll probably need to press a key after that)
and
RUN
Or simply:
RUN"C"
This will work for filenames with spaces.
Where's the 8-character limit?For example, only RUN"H:PACMAN is valid, not RUN"H:PAC-MAN, RUN"H:PAC MAN or RUN"H:PAC-MAN - FOX
This isn't an 8-character limit. It is that H: emulation accepts only some characters in filenames. This is to make it compatible with Atari software. You can't use spaces in filenames on Atari - space denotes end of filename. As for the hyphen, it should be probably allowed. I'll fix that.
Maybe spaces should be also allowed, I'll have to check if Atari DOSes use space as a delimiter, especially for the rename command. If not, H: will work with spaces, too.
in Asskicker the wall must be exactly one cell distance from another wall??? The corridor is certainly more than one cell long.
The Maze isn't RayCasting at all, it use real 3d calculation and tricky texture fillerSo why doesn't it show distant walls?
Colors
TV displays colors in RGB, naturally.
The problem is that colors differ between:
