playsoft
Posts
656 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by playsoft
I was happy with my multiplexer in AtariBlast and being an original game I was able to minimise the amount of flicker by designing the sprite paths around it, but even then there were complaints! Some of the paths in the challenging stages of Galaga have all 8 sprites in the same vertical space for a fair amount of time during which you'd only be able to display a single sprite once in every four frames if using multicolour sprites; once every other frame if single colour. I really don't think it would be greeted with much joy...
- 3
Also I think there is a difference between what is acceptable on the two systems. There would be significant savings in both memory and CPU time if you went the sprite multiplexer route instead of character sprites, but I don't think the flicker would be well received on the 5200/A8; the VCS has always had flickering sprites, so it's more acceptable there (although I remember when my Uncle brought VCS Pac-Man we thought we'd got a dud cart!).
It looks absolutely stunning ?
- 1
- 1
Looks great, opens the door to using the 822 in games! (print maps etc...).
Strange, my 822 seems to need the $4C in my test program; with Aux1 set to $00 there's no printer output at all, just farting noises; with it set to $4E I get normal text output, not bitmap.
Paul
- 1
I don't know if this will help but I disassembled the code from the owner's manual to see what it was doing.
Basically if you send a SIO Put with Aux1 set to $4C ('L' for Line perhaps) then instead of printing the 40 bytes as characters it prints a single line of 240 pixels (the last 10 bytes are not used - although you do seem to have to send them).
The attached test.s continually prints lines of random data out on the 822:
The code in the owner's manual prints the screen out sideways; I attach the disassembly for that which I've commented but haven't done anything else with.
Paul
- 1
2 hours ago, Synthpopalooza said:
I for one would love seeing Galaga on 5200 or 8-bit. If 2600 can do it, why not us?
Thoughts on sound ... WSG by Namco has 3 sound channels. I'd do this:
1 16 bit channel: Alien death sounds.
8-bit channel ... ship firing, ship destroyed
8-bit channel ... aliens swooping, tractor beam sounds
$Cx in 16 bit will exactly nail some of those alien death sounds. ?
Look forward to hearing them!
2 hours ago, rensoup said:
Since you have the luxury of having 2 musicians, you could release 2 roms, each with its own set of tunes ?
(...if you resume work on it ?)
Yes I've set the build up to generate two versions. I am working on something else at the minute, so will see if I get back to it after that.
- 1
11 hours ago, Synthpopalooza said:
OK, this is all for tonight ...
To step thru fx, hit start.
Tractor beam 1, Tractor beam 2, Tractor beam 3, Insert coin fx
The last one isn't quite to the arcade specs yet tho ...
galaga-soundfx.asm 12.43 kB · 3 downloads galaga-soundfx.s 11.18 kB · 1 download galaga-soundfx.xex 1002 B · 5 downloads
They are really good. Obviously it might be quite a while before they are used, but I've pulled them into the player alongside the start tune. I'll keep it organised with anything you post.
So the main glitch I'm hearing is 2-3sec in. After listening to the 60 version, it seems that the glitch is also there but not as loud (although it can be sometimes). Maybe that's something that can be fixed in the tune ?
It seems that the same executable (no matter which) can sound slightly differently every time you start it. So the glitch will be louder from time to time.
I have very little knowledge of Pokey but maybe it's due to the chip itself ? I recently tried messing with SFX in RMT. I had a very short tune which just played the same SFX over and over again and it would sound different from time to time.
I can't say resending the same data makes a difference ?
I'm not sure 30 sounds very different from 60... so this could be pretty good news! Have you tried with the other tunes ?
Not sure if you modified the LZSS compressor to skip half the data but you could just call the RMT player twice per frame(so at 120hz) because Altirra only records the SAP data once per frame anyway
(I'm using headphones and I don't have super ears either...)
I've not tried the other ones at 30Hz yet. I took the 60Hz SAP files and created new 30Hz ones from them by leaving out every other set of register values. They all sound much of a muchness to me and I didn't notice any difference resending the data again.
I don't think I hear that glitch but it might be more noticeable with headphones - I don't have any but I will connect my A8 up to my hifi tomorrow and see if I can hear anything.
43 minutes ago, Synthpopalooza said:
Update on mine ... fixed the bum notes and the tempo. Sounds a lot better.
galaga-intro.asm 11.9 kB · 2 downloads galaga-intro.s 11.23 kB · 2 downloads galaga-intro.xex 930 B · 2 downloads
Yes that sounds great.
- 1
52 minutes ago, rensoup said:
Yes there seems to be a click... just curious, have you tried resending the last data to pokey instead of skipping playback altogether ? (I'm guessing it will sound worse but you never know)
I suppose lzs16 is out of question.... @dmsc once mentioned that if you have a lot of compressed tunes it might be possible to compress them together using a fixed dictionary if the instruments are similar.
I've not tried resending the last data, will give it a go.
What was going to be my final experiment was to take the 60Hz SAP, remove half the samples for 30Hz playback and spread the decoding effort over 2 frames (half the channels on the odd frames, the rest on the even). The start tune LZSS went from 751 bytes to 461. I'm probably not the best to compare how they sound as my hearing hasn't improved with age...
Edit: both of these now repeat the last data when the registers aren't updated.
14 hours ago, Synthpopalooza said:
Try recompiling mine, but without the first and third channels. See if it sounds better.
I think I removed the right ones! It's now playing on just the 64K channels.
To convert from RMT to SAP-R I export the RMT to a XEX and then record the SAP-R in Altirra. When doing this it makes a difference whether Altirra is configured for PAL or NTSC; in PAL it records the audio registers 50 times a second but in NTSC it's 60 times resulting in a bigger file.
I did this for all of Jaden's RMT files, making PAL and NTSC versions of the SAP-R files and then compressing them with LZSS -8:
RMT FILES LZSS PAL FILES LZSS NTSC FILES 205 Galaga - Challenging Stage.rmt 96 challenging_pal.lzss 102 challenging_ntsc.lzss 144 Galaga - Extra Life.rmt 74 extra_life_pal.lzss 87 extra_life_ntsc.lzss 292 Galaga - High Score.rmt 291 high_score_pal.lzss 372 high_score_ntsc.lzss 147 Galaga - Insert Coin.rmt 37 insert_coin_pal.lzss 42 insert_coin_ntsc.lzss 670 Galaga - Perfect!.rmt 319 perfect_pal.lzss 570 perfect_ntsc.lzss 309 Galaga - Results.rmt 283 results_pal.lzss 356 results_ntsc.lzss 366 Galaga - Start.rmt 598 start_pal.lzss 751 start_ntsc.lzss 2,133 bytes 1,698 bytes 2,280 bytes
I generated 2 versions of the build with the start tune - the 60 version uses the NTSC data, the 50 version uses the PAL data but skips the playback routine 1 frame in every 6 to correct the speed for NTSC.
The advantage of the 50 version is that the data is smaller but I think you can hear a slight difference between the two.
? I will rebuild the demo tomorrow with the updated file.
- 1
27 minutes ago, Jaden (JRH) said:
I've tried out the demos you sent over Playsoft, and I can't help but notice how harsh my music sounds on them. Is that because of the compression or is it something that I could fix? Because I'm not sure why they sound like that. Synth's version sounds perfectly fine. However, there are definitely some notes near the end that need fixed and I'm not the biggest fan of the waveforms used.
Haha I thought you intended that distortion! If you play your file in RMT there's no distortion but if you export it as an Atari executable you get the distortion (you can try it, just select "file -> export as" and choose XEX).
I think the distortion is caused by having the volume too high in the instrument envelope. I changed it from FEDC to 7654, exported it to a XEX and it sounded fine.
- 1
I generated builds using the two tunes. There's not really much in it, Synthpopalooza's is slightly smaller and requires less cpu cycles although it is not as consistent.
I did try the sap/lzss process on Synthpopalooza's but it did not compress as well as Jaden's, presumably because of the 16-bit values.
- 1
12 hours ago, Synthpopalooza said:
Here's mine ... what do you think?
galaga-intro.asm 11.9 kB · 2 downloads galaga-intro.s 19.01 kB · 2 downloads galaga-intro.xex 1.69 kB · 6 downloads
Yes interesting, a sort of harpsichord vibe to it.
9 hours ago, Synthpopalooza said:Also, mine is about 272 bytes plus the code for the music player.
I think the 4 duration tables are the same, so more like 170!
- 1
13 hours ago, Jaden (JRH) said:
The midi one sounds pretty good and the CPU cost and size are right in the middle of the other ones. So, if you good sounding music that doesn't take up much space or CPU time, midi might be the way to go
I much prefer your RMT one over the midi (plus that was the only midi file I could find, so the other tunes would be missing) and with the LZSS compression it's much more viable to include them.
I really don't know if the remaining functionality will fit in a 32K cart anyway - and if I do target a bigger cart I can turn the other sprite drawing optimisations on.
- 1
41 minutes ago, rensoup said:
I'd never heard of games dynamically blanking parts of the screen before.
I used to think that blanking was for the top and bottom part of the screen and if you started messing with it dynamically, the screen would lose its sync or something.
(Now that I'm thinking about it, Antic blanking may be different from screen blanking ? otherwise the sprites would vanish ?)
Ah yes, blanking with DMACTL would be daring, I just put the blank scanline codes in the display list ($00..$70).
On 3/28/2020 at 12:29 AM, rensoup said:
You're dealing with some pretty severe constraints but you could use LZSS with a 256 bytes buffer and bad compression
LZSS is compressed raw Pokey data so any player can be used... Out of curiosity I tried compressing one of @Jaden (JRH)'s tunes:
Galaga - Perfect!.rmt (670 bytes)
Galaga - Perfect!.lzs8 (345 bytes)
Galaga - Perfect!.lzs12 (298 bytes)
Galaga - Perfect!.lzs16 (264 bytes)Even at the worst setting it's half the size, so all those tunes would probably take just 1KB of ROM.
galaga_perfectLZS.obx requires less than 300 bytes of RAM (ZP is optional and speed dif is minimal) and the player takes around 128 bytes of ROM.
I've included the test files, now compare the CPU usage for LZS and RMT and laugh all the way to the bank...if you ever decide to pick that project up again of course ?
Thanks, that's fantastic, it certainly makes a difference to the cpu and memory overhead.
As a comparison I tried 3 different versions of the start tune; the 7800 one, a midi file conversion and Jaden's RMT using LZSS (I used the 12 bit one for this).
In terms of what they sound like, Jaden's is obviously by far the best.
In terms of cpu cost, the 7800 is cheapest, then midi, then LZSS - appears to be a little over double the 7800 cost.
In terms of song size, the 7800 is 100 bytes, midi is 180 bytes, LZSS is 344 bytes.
In terms of player size, LZSS is the smallest although the 7800 does have other things in there for sound effects which are not used by this tune.
I can't say there would be the resources available for it in a 32K cart but it definitely makes it more viable.
- 2
Oh, you're variably blanking in the middle of the screen?... a daring move ?. The screen seems pretty full at times though... Plus a whole bunch of DLis for repositioning the PMG stars... ouch!
It's pretty rare that mode4 is useful but this is a good showcase for it !
No nothing daring - both the screen map and the display list are double buffered, so with the off-screen buffer erase the old sprites, draw the new ones and create the display list so that it only has ANTIC 4 rows for those on which sprites were drawn.
You are right, there are single line incoming waves where there may only be a couple of ANTIC 4 rows empty but I think that's enough to cover the overhead of doing this. I roughly estimate there are 100 cpu cycles available on a blank scanline and 50 available (averaged) on a scanline that is part of an ANTIC 4 row. So each one omitted claws back around 400 cycles (minus the overhead).
In this case where the sprites are spread out vertically the other optimisation kicks in; because of that spread they tend not to overlap much, so the blank character optimisation gets used a lot.
The opposite scenario is when they are all grouped together moving to their formation positions. Here the blank character optimisation isn't used much but removing the ANTIC 4 rows is.
The two optimisations work so well together I could probably convince people it was all planned out like this in advance... ?
- 2
11 hours ago, rensoup said:
Very nice demo, seems like a lot of pixels are pushed around!
Have you considered dmsc' LZSS player ? It's basically compressed SAPR. Most of the time the files are usually the same size or smaller. The player is tiny but the buffers can be expensive, up to 9*256 bytes (depends if you want good or average compression on the tune ).
Speed is where it really smokes the RMT player, about 8-10 scanlines.
I don't know if you need to play sfx and music at the same time, which might be a problem?
Thanks, being a space game I was able to make a couple of good optimisations with the sprites; (a) when drawing over a blank character just write the new data straight out, (b) replace any ANTIC 4 display list entries with blanks if nothing is drawn on those rows.
I haven't picked this back up yet and I'm not sure I will (a bit too much pressure for me). I was aiming for a 32K cart - and there is about 8K ROM free and about 4K RAM free. There are times when it can't maintain 60Hz so I flicker one of the sprites. It's barely noticeable as it's 1 sprite in 10 and doesn't happen very often or for very long. I can speed up the sprite drawing but that costs another 5K ROM.
I don't know if the remaining 8K ROM/4K RAM would be enough for everything else. It probably is a bit tight, so if it did need a bigger cart that might be the time to consider a more sophisticated music player, although to my non-musician ears I'm not sure the music in Galaga needs it - like Synthpopalooza says above, it might be more a case of mimicking the Namco sound chip.
- 1
On 2/23/2020 at 4:56 AM, -^CrossBow^- said:
I was playing this in Altirra a bit ago and it is really cool! I was able to get 2 crystals so far and then did a save state on the world 3 password screen! I like how it is a wonderful mix of robotron, shamus, and berzerk. Is this an original game you created on the 8-bit series and ported over or your take on another game?
Plus there are platform and puzzle elements too... I loved the snake puzzle.
- 1
On 2/25/2020 at 1:34 AM, AverageSoftware said:
If it gets one, I need to know what voodoo was used to produce that 64KB cartridge. The things I could do with another 32KB...
The bank switching scheme is described here:
Another Galaga thread
in Atari 5200
Yes Konstantinos that's correct. If you want to play around with anything then extract the build folder and run build from the command line. The software sprites are in the .bmp file, the formation graphics in the .a4 and the PM graphics are all .apl. When drawing the software sprite frames I tried to use as many pixels as possible to make them look bigger on-screen than they really are!
build.zip
