freehabitat
    112
Posts posted by freehabitat
  1. Hello Michael, ....
    i did no programming in the last weeks because i was more into hardware research. here is a link to the interface i built.
    http://www.fullframefestival.net/sm/atari.mpg
    (not a stream you need to download the 50Mb - right click and download)
    now i have my sound based controller unit.
    i also made lot of tests with my programmed grafics and noticed that i need to work very minimal. (we did projections with video projector in a closed room filled with fog out of a fog machine)
    i will try to programm to big squares who can move in all directions. is it possible to built playersprites with 11x11 pixel? that is very important. can i also change the size of the playersprite during the game?
    (maybe from 2x2 to 11x11 or 11x4, ... ... should be very flexible). so far i think i need to work with kernel hacks maybe.
    also i am often thinking about the classic game QUIX, this is about producing simple coloured geometric figures.
    my researc is going on and the concept for the game is closer in my mind,.. till now it is al testing phase and learning basics.
    have a nice weekend..
    Tom
  2. Hello Folks,
    can someone give me a manual how to built a simple rom burner? i need to test my roms on real 2600 hardware.
    it looks like the only way to burn roms on my own because i cant find a supercharger or anything like this.
    best,
    f.
  3. it seems like very hard work. I'm not that patient.
    dont worry,.. i never did any coding befor and i realy did a little game by now (one ball, on player ... very simple). also in this forum are some people who help with problems.
    ciao Tom
  4. I rearranged a few lines (just because it made more sense, even though it didn't have any impact on your problem), and I added a few lines to fix the problem. Now it should work like you wanted.
    Michael
    Hello Michael
    thanx for the tip,... now i have a simular problem with "using no_blank_lines". at 2 frames the pf-lines look less but are´nt in the code.
    please explain me why?
    greets,
    Tom
    pf_painter.bas
  5. But as I said, you can't do that in bB-- you'll need to write a custom kernel in assembly language.
    Ok... so i might use a player instead of the ball,... i think kernel hacks will be for future projects. First i want be fit in basic´s of bB.
    tom
  6. you are right, i would not give up and there are other things in live who scares me,... so i´ll going forwart with the capture "collisions" now,... let´s see waht that
    brins to me.
    so i made some steps forward. this file is my present state. i have a bug with player0 controller (up-down-left-right). when you hold the button i have black screen. only if i trigger the button the playfield changes.
    bye
    Tom
    wave_171007.bas
  7. ... i tried som more time to get the right code and i am not so happy.
    i think i´ll do my program more simple now and use the 4k ram only. So it´would be to complecated for me to have fun with programming.
    In my future projects i am shure to raise my knowledge about the system of coding.
    i´ll be back later !
    tom
  8. I rearranged some of your code, and changed a few lines. Is this what you were trying to do?
    Michael
    Exactly ,... now i tried to put more different frames into the program that it looks like the wave_111007.bas, only with moving pfhigh.
    but it´s not so easy for me. I added the program with only 3 frames, can you have a look? i am shure it´s about the counter in line 46 - 51.
    How do i need to set it that it works right?
    for example, in the wave_111007.bas its done with that code:
     if joy0right then q=q+1 : gosub check_q : goto main
     if joy0left  then q=q-1 : gosub check_q : goto main
    check_q
      if q=255 then q=30
      if q>30 then q=0
      if q<=r then goto frame1   rem:=> 10
      if q<=s then goto frame2   rem:=> 20
      if q<=t then goto frame3   rem:=> 30
    return
    and in the last correction (example with 2 frames) like that:
       if joy0right then q=q+1 : if q>20 then q=0
      if joy0left  then q=q-1 : if q=255 then q=20
      if q<=r then gosub frame1 else gosub frame2
    is it different because its enoug for 2 frames to work with gosub and else?
    and about the pfhigh and pfcolor at the kernal setting, can i also create this for each frame like i did in wave_101107.bas?
    and if i want to change the hue of my colors in combination with that moving pfhigh? :)
    so i includet 2 (not) possible solutions.
    i know this are a lot of questions i am asking you.
    some features i planed for future:
    next step is that player 2 can move the sprite and fire. maybe i built a random moving sprite as a target. if the player shot the target the complete
    playfield(the design) should change. Like a player get into next level.
    do you think it`s complicated? i think it´s almost the same code, only pixel of PF is changing, the random target should be programmed, collisions includet and some little features.
    anyway,.. it grows fine and i am very happy with the results.
    about hardware, this solution means i need to burn the program file on a 8k or 16k rom, isn´t it? you write somewhere it´s no problem for the hardware until rom´s are available. How rare are they and who in this community can burn them for me?
    okay,.. so far enough questions.
    thanx a lot,..
    Tom
    framestest_3frames.bas
    framestest_3framesv1.bas
  9. HI,..
    i found the link to your tread about using Superchip little time ago but it was to complicated. Now i understand little more about banks and what the .inc and.asm files are going to do.
    I decidet to use your posted code to connect wit my test-programm of the different frames controlled by cursor but it looks not so easy. Somewhere i missunderstand something.
    i guess i need to put some sequenzes in loops to run all together... if i try to use command "main" and "goto main" in the structure of your posted code it do not like it,...
    anyway.. i continue trying out how it work and will post my results in the next days, maybe you can have a look on it again.
    bye
    Tom
  10. You had the right idea, you just needed to rearrange things a little bit. :)
    Michael
    Jep, thats it,.. i on that way i can realy learn best,... doing and correction and so on.
    some little questions beside:
    i did pfcolors for each frame now, i use PAL format, so i am not shure with the color code,.. is it as well 0-255 or how do i set
    the colors. there is a link in the bB manual to a colortable but i am not shure about te coding of colors.
    so i write "set tv pal" in first row in my script and set stellar in pal.. but most colors are grey... if i switch in NTSC its so colorfull.
    can i use random colors for different horizontal lines with the pfcolour? or is it static? now i set one color for each frame but i would like that color change with random but little slower (every second another color or simular).
    when i controll my playfields with cursor (left,right,up,down) the fire button do not make anything, i want:
    COLOURB=e (any variable)
    pressfire=e+1 (cant remeber the correct command)
    that should mean with every firebutton hit the color changes, do i do wright?
    its also a problem of prioritys i think, so as long i am on a cursorbutton the changed BFCOLOR do not get projected.
    i hope my explaination it´s not to much complicated.
    bye tom
  11. You had the right idea, you just needed to rearrange things a little bit. :)
    Michael
    bye tom
  12. wow,... thanks Michael,...
    i am going to read the code now and will try to use this in other examples to learn how tu use this "check" and the subroutines with "gosub" "return",...
    hopefully i can bother you in the next day´s with my new questions and problems.
    al the best,
    Tom
  13. :ponder: anybody there who can help ???
    Sorry, I missed your post the other night. I'll try it tonight and see.
    Michael
    thanks,.. no worry,..
    it´s the point, i am going to do a art-installation in april 2008. for that i want to use the Atari and a burned rom with a kind of visualizer, it´s the program i am working on. i will also built a interface for the controller-port to controll the visuals with other sensors :) this port will also be releast as a open source, for shure.
    i can solder, have good idears but a big deficit with programming :)
    ciao
    Tom
  14. Hello,...
    i did some exercises today, resulting i have some new problems.
    On this point i want to explain that this code wouldn´t become a game in common way, it´s more like playing with colours and shapes, but it is not a demo becaus eyou will controlle some things. So don´t wonder about it if it dont look like what someone expect.
    here is the code:
    h=10 : i=20 : j=30 do i need to set this variables for the frame 4-6 or is it enough to do it with var - r, s, t & u for all frames?
    r=10 : s=20 : t=30 : u=40
    x=50 : y=50
    main
    set kernel_options pfcolors
    scorecolor=e
    COLUBK=e
    COLUPF=10
    COLUP0=40
    COLUP1=80
    rem colour of colums
    pfcolors:
    u
    h
    u
    g
    u
    c
    u
    i
    u
    r
    u
    end
    rem flickering circles since i did the left and right controll my flickering pixels disapeared
    createPf
    pfpixel 4 7 flip : pfpixel 5 7 flip : pfpixel 6 7 flip : pfpixel 7 7 flip : pfpixel 8 7 flip : pfpixel 9 7 flip : pfpixel 10 7 flip
    pfpixel 4 6 flip : pfpixel 5 6 flip : pfpixel 9 6 flip : pfpixel 10 6 flip
    pfpixel 4 5 flip : pfpixel 5 5 flip : pfpixel 9 5 flip : pfpixel 10 5 flip
    pfpixel 4 4 flip : pfpixel 5 4 flip : pfpixel 9 4 flip : pfpixel 10 4 flip
    pfpixel 4 3 flip : pfpixel 5 3 flip : pfpixel 6 3 flip : pfpixel 7 3 flip : pfpixel 8 3 flip : pfpixel 9 3 flip : pfpixel 10 3 flip
    pfpixel 21 7 flip : pfpixel 22 7 flip : pfpixel 23 7 flip : pfpixel 24 7 flip : pfpixel 25 7 flip : pfpixel 26 7 flip : pfpixel 27 7 flip
    pfpixel 21 6 flip : pfpixel 22 6 flip : pfpixel 26 6 flip : pfpixel 27 6 flip
    pfpixel 21 5 flip : pfpixel 22 5 flip : pfpixel 26 5 flip : pfpixel 27 5 flip
    pfpixel 21 4 flip : pfpixel 22 4 flip : pfpixel 26 4 flip : pfpixel 27 4 flip
    pfpixel 21 3 flip : pfpixel 22 3 flip : pfpixel 23 3 flip : pfpixel 24 3 flip : pfpixel 25 3 flip : pfpixel 26 3 flip : pfpixel 27 3 flip
    rem moving the PF
    if q=255 then q=40 last time i had only the column moving left and right, now i includet one from the middle to top and bottom
    if q>40 then q=0 ... the frame 1-4 are stronger than 5-6(vertical columns), i mean the verticals do not appear on the screen, if i delet frame 1-4 they are working
    if k=255 then k=30
    if k>30 then k=0
    if q<=u then goto frame4 rem:=> 40
    if k<=h then goto frame5 rem:=> 10
    if k<=i then goto frame6 rem:=> 20
    if k<=j then goto frame7 rem:=> 30
    framereturn
    drawscreen
    if joy0right then q=q+1 : goto main
    if joy0left then q=q-1 : goto main
    if joy0up then k=k-1 : goto main
    if joy0down then k=k+1 : goto main
    if joy0fire then e=e-1
    goto main
    frame1
    playfield:
    X..X........................X..X
    end
    goto framereturn
    frame2
    i deletet frame 2 - 7 cause its to much text for the posting => testtest.bas
    goto framereturn
    so far this are my questions for now,... some more will come :) for shure...
    by the way,... my respect to everyone who spend his time helping others to solve their problems...
    Tom
    testtest.bas
    testtest.bin
