alekmaul
    276
Posts posted by alekmaul
  1. Hi,
    I have a strange behavior with your compressor Daniel.
    i tried to integrate it in my tool (thanks for sharing source code), it works fine, but compression ratio is lower than a pletter compressor :o !
    Dan1 :
    const byte TILtitle3DAN1[] = { // tile size dan1 compressed 965 bytes (52%)
    const byte COLtitle3DAN1[] = { // color size dan1 compressed 793 bytes (60%)
    const byte MAPtitle3DAN1[] = { // map size dan1 compressed 385 bytes (49%)
    Pletter :
    const byte TILtitle3PLE[] = { // tile size pletter compressed 957 bytes (52%)
    const byte COLtitle3PLE[] = { // color size pletter compressed 787 bytes (61%)
    const byte MAPtitle3PLE[] = { // map size pletter compressed 385 bytes (49%)
    I tried (only the TIL part on my image) with your exe compressor, and it gave same size, 965 bytes.
    Do you think it is a normal behavior for Dan1 compression ?
    I added the c source file of the pletter compressor i used (entry point is int pletterCompress(byte *src,byte *dst,int n)
    Of course, for some pictures, your compressor is sometime better, but not all the time. It is just to inform you and to share information about compression :)
    i used this image for test
    plet.txt
  2. I'm currently thinking bout best options for C source file compilation with SDCC V3.5.
    Currently, i'm using : --std-c99 -mz80 --opt-code-size --fverbose-asm --max-allocs-per-node 10000 --vc
    I also saw that a --opt-code-speed option exists, it is used to optimize more for speed instead of size. is it useful to use it with SDCC V3.5 ?
    Also, can we use --opt-code-size and --opt-code-speed both for compilation ?
  3. ok, thanks for your tests. Will check more deeper in my code to find the issue :/
    regarding ram, it seems ok :
    Area Addr Size Decimal Bytes (Attributes)
    _DATA 00007000 0000037C = 892. bytes (REL,CON)
  4. Are you doing a lot of tile scrolling? I find the player works fine. I have current problem when I try to play music in the planes section which has 32x18 area of screen scrolling that it won't play at all unless I crash the plane or fly straight up so the scrolling stops.
    No, it is a screen with no scrolling, and the player is the only thing running when the sound locks :(
  5. Also.... if you are using it without the rest of my lib, that might be a factor. I've never tested it standalone since the earliest days. :)
    I'm only using the player, not all the lib.
    And yes, it is not the same, I saw the optimizations you did but I have no sound with this version, will check again if it is my code that is not good with this one.
