PacManPlus
    5,653
    28
Posts posted by PacManPlus
  1. I have fixed two small bugs - one of which happens when you reach 1,000,000 points...  It drew the '1' over the monster pen, allowing the player and monsters to get in and out.  While I did roll it over (like the arcade does), I keep the zeros there so you know the score rolled over.
    There is another small 'blink and you'll miss it' bug I fixed as well.  This one is going to @Albert whenever he is ready to put the game in the store (if he wants to)... and when @Nathan Strum is able to do the artwork.  @Marc Oberhäuser, do you still do boxes?
    • Like 13
  2. Thank you, @stephena.  Please note, that I know that Stella running slow was because of the RPiZero.
    So, I need to go searching for the version of Stella you patched for the Retron77?  I'll go try and find it in a bit.
    I'm going to see how to fit the RPi3 in the FBX (I may end up removing the Network port and one of the USB receptacles) and then design a bracket to hold it in.  I don't know if it will make it (the RPiZero fit nicely, but it won't play nice with the GPIO pins).
    I really want to get this going, as like I mentioned I have a FB1 and I want to make a 7800 Flashback for that.
    Anyway, thank you again for jumping in this thread.
    Also, thank you @fdr4prez - Hopefully between all of us, we will get this going.
  3. Hi
    The idea here was to use the RPi Zero inside the Flashback X case:
    I even 3D printed the bracket to mount the Zero in the case.
    BTW, I tried the PiZero image that you had on the 'Ultimate Atari Joystick' page you linked to... (the one that was tailored to the Pi Zero)  Froze at the multi-color image at the very beginning.  Tried two RPi Zeros, and Two different 8G cards. :(
    Is it possible that I have *two* bad Rpi Zeros?
    I was connecting everything (both joysticks, console switches) to the GPIO ports, and run the USB port to the 'cartridge' port on the FBX (for things like paddles, etc).
    The Zero is the only thing that will fit in the FBX case though. :(
    ...and yes, I did want to use Stella alone.  I only went with retropie/emulationstation because the Stella on that ran at a normal speed.
    EDIT: I also have a Flashback 1 (the one that looks like the 7800) and I had planned on using the other RPi Zero for that one.  (A 7800 Flashback)
  4. 18 minutes ago, fdr4prez said:
    Did you try this, from its github page
    https://github.com/adafruit/Adafruit-Retrogame
    RetroPie 2.0+ Compatibility
    Note that by default retrogame won't work with SDL2 applications that depend on evdev for input events. Specifically this means applications like the latest version of RetroPie and EmulationStation won't be able to see key events generated by retrogame. However you can fix this issue by adding a small custom udev rule to make retrogame keyboard events visible to SDL2.
    Connect to your Raspberry Pi in a terminal/SSH session and execute the following command to create and edit the file /etc/udev/rules.d/10-retrogame.rules:
    sudo nano /etc/udev/rules.d/10-retrogame.rules
    Once the nano text editor loads, copy this single line into the file:
    SUBSYSTEM=="input", ATTRS{name}=="retrogame", ENV{ID_INPUT_KEYBOARD}="1"
    Save the file by pressing Ctrl-O and enter, then press Ctrl-x to exit. Restart your Raspberry Pi and run retrogame again, now button presses should register in SDL2 applications like the EmulationStation frontend to RetroPie
    That was the first thing I did :( :
    14 hours ago, PacManPlus said:
    Not to de-rail this thread too much but...  Is there anything special about the RPi Zero and the GPIO pins?  I'm Already running retropie on a RPi2 with 'retrogame' to take input from the GPIO pins and it's fine... But on the Pi Zero I get *NOTHING*.  I've tried two different RPi Zeros, re-configuring the '/boot/retropie.cfg' file, tried EVERY BCM pin, and nothing.
    I know I have it connected correctly, as I've done these before (on different Pis) and they worked.
    I've made sure '/etc/udev/rules.d' has a file called '10-retrogame.rules' with the line 'SUBSYSTEM=="input", ATTRS{name}=="retrogame", ENV{ID_INPUT_KEYBOARD}="1"' in it.
    I've made sure '/etc/modules' has 'uinput' in it.
    This is very frustrating.
    Any ideas? :(
    Thanks,
    Bob
  5. 13 hours ago, haightc said:
    how much height could you save by permanently mating the XM, is there ever a reason you could want to remove it?
    That's what the case (at the top of this page) is for that I am designing.  No, there is no need to remove it once you have it.
    I also was going to design a smaller 7800 case for the people who may have cracked theirs (or just want a new one) starting with the original 7800 design, but since Curt gave out the .STL files for the 7800 case I won't bother.
  6.
    6 hours ago, RevEng said:
    I don't really have specific knowledge here, but I do know the gpio layout for RPi2 is different than zero. Have you adjusted for the new layout?
    Thank you - I tried every pin, different ground wires...  I can't get *anything* out of any of these pins.  I don't get it.
  7. Guys, you are all so incredible.  Thank you so much...  ...and no Vinnie, you definitely did NOT sound like an a$$hole.  You were very cool.  Again, thank you for even thinking of me to do this.
    I didn't think that part at the end was going to get published, when I started talking about the NES and SMB - I thought he stopped recording. 🤯
    Thank you - you guys are part of what keeps me doing this.  I'd like to hit at least 30 games (I'm at 22 now) icon_grouphug.gif
    • Like 12
  8. Not to de-rail this thread too much but...  Is there anything special about the RPi Zero and the GPIO pins?  I'm Already running retropie on a RPi2 with 'retrogame' to take input from the GPIO pins and it's fine... But on the Pi Zero I get *NOTHING*.  I've tried two different RPi Zeros, re-configuring the '/boot/retropie.cfg' file, tried EVERY BCM pin, and nothing.
    Any ideas? :(
    Thanks,
    Bob
  9. 13 hours ago, Jinks said:
    Cool will be excited to see more.  As I can not think of any other vertical shooters besides Plutos and Xevious.
    Moon Cresta, Space Invaders, Meteor Shower, Astro Blaster, Astro Fighter...  :ponder:
    Ok, you meant *moving* vertical shooters.
    @SlidellMan Graphics look interesting!  It will be nice to see them in context! :) *subscribes to thread
    • Thanks 1
  10. Thanks, Curt
    I used some bits and pieces from the case files you sent, but I will those more for the 'plain' 7800 case redesign.
    I do want to streamline the 7800/XM case as it's too bulky...
  11. Hi guys.
    So I relented and went back to the retropie image for the RPi Zero.  I changed the splash screen and made emulationstation boot right into the Atari2600.  I didn't want to use RetroPie / Emulationstation, and wanted to boot directly into Stella, but apparently that's not going to work.  It looks like the version of Stella inside of retropie is from 2014 :(
    Anyway, it runs much better now, so I may just stick with this.  Still waiting for USB adapter parts to come in, so it will be a bit.
    I hope this version of Stella recognizes the Paddle -> Stelladapter -> USB port connection.
