PacManPlus
    5,644
    28
Blog Comments posted by PacManPlus
  1. Thanks, Eric, GroovyBee - and everyone else for the compliments :)Actually, I found the source code to the arcade game on line. So, I'm trying to see how much of it (if any) I can apply to the 7800 version. The only problem is, there are many things about z80 code I don't follow.Below is the 'IQ' module, which is the module for wall detection. Knowing that the 7800 does things *very* differently than the screen buffer of the arcade, I'm still trying to see if I can apply anything to this port:
    .title	"WALL DETECTER AND AVOIDANCE CONTROL".sbttl	"FRENZY".ident IQ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~;	Intelligence;_______________________________.insert EQUS; DURL refered to thru out this program stands for; Down,Up,Right,Left bits in directions and wall encoding.DOWN	==	3UP	==	2RIGHT	==	1LEFT	==	0;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~;  Check walls and avoid them;_______________________________;a=new DURL, c=old DURL, ix->vector, iy->mansIQ::	push	b		;save tracker	push	d	mov	l,D.P.L(x)	;get height thru	mov	h,D.P.H(x)	;pattern pointer	mov	e,m	inx	h	mov	d,m	xchg	mov	d,a		;save DURL		inx	h		;skip x bytes	mov	a,m		;y lines (height)	mov	c,a		;for down test	srlr	a		;h/2	adi	1		;(h/2)+2	mov	e,a		;number of lines to test	mov	h,P.Y(x)	;get current position	mov	l,P.X(x); Regs: HL=YXpos, E=height, c=DURL to test; Down tests	bit	DOWN,d	jz	..TU	push	h	mov	a,c		;height of pattern	adi	3		;margin of error	add	h		;offset to look	mov	h,a		;at for wall color	push	d	mvi	e,5	call	testx		;check for white below	pop	d	pop	h	jz	..TR		;if ok check right,left	res	DOWN,d		;else forget that direction	jmp	..TR;up tests..TU:	bit	UP,d	jz	..TR	push	h	mvi	a,-3	add	h	mov	h,a	push	d	mvi	e,5	call	testx	pop	d	pop	h	jz	..TR	res	UP,d;	jmp	..TR;right tests..TR:	bit	RIGHT,d	jz	..TL	push	h	mvi	a,11	add	l	mov	l,a	push	d	call	testy	pop	d	pop	h	jz	..done	res	RIGHT,d	jmp	..done;left tests..TL:	bit	LEFT,d	jz	..done	push	h	mvi	a,-3	add	l	mov	l,a	push	d	call	testy	pop	d	pop	h	jz	..done	res	LEFT,d;	jmp	..done..done:	mov	a,d		;final result DURL	pop	d	pop	b	ret;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~;	Test in X direction;_______________________________; input: h=Y, l=X, c=DURL; output: Z if robot color in that boxTestx:	dcr	l		;test -1 line	inr	e..x:	call	CheckBox	rnz	exaf			;save test results	mov	a,l		;get x	adi	2		;add 2	mov	l,a	exaf			;now return test results	dcr	e		;number of times to look	jnz	..x	ret			;returns Z;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~;	Test in Y direction;_______________________________; input: h=Y, l=X, c=DURL; output: Z if robot color in that boxTesty:	dcr	h	inr	e..y:	call	CheckBox	rnz	exaf			;save test results	mov	a,h		;get Y	adi	2		;add 2	mov	h,a	exaf			;now return test results	dcr	e		;number of times to look	jnz	..y	ret			;returns Z;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~; Check pixel for use;_______________________________CheckBox:	push	h		;save YX	call	RtoAx#		;in hl out hl,a	ani	0fh		;save shift&flop	bit	Flop,a	jz	..fl	xri	0Fh		;flip flop and shift..fl:	xri	07h		;reverse shift	di			;using magic	out	MAGIC	res	5,h		;convert magic->normal addr	mov	a,m		;get normal screen	sta	TEMP+(1<13)	;magic scratch	ei	lda	TEMP		;normal scratch	ani	1		;check it	pop	h		;restore YX	ret;---------------+; get durl bits |;---------------+; input: h=x l=y; output: a=durl bits for room xy is in; used by man,robot to check for others in squareWallIndex::	mov	a,l		;get y position	sui	8		;edge of first room	mvi	e,0	cpi	48		;1st row	jrc	..sk	mvi	e,6		;2nd row	cpi	48*2	jrc	..sk	mvi	e,6*2		;3rd row	cpi	48*3	jrc	..sk	mvi	e,6*3		;4th row..sk:	mov	a,h		;x pos	sui	8		;edge of first room	dcr	e..xlp:	sui	40		;room x width	inr	e	jrnc	..xlp	xchg	lxi	b,WALLS		;->walls array	mvi	H,0		;add index	dad	b	mov	a,m		;get durl for room	xchg	ret	.end
    For instance, the 'WallIndex' function - WTF is 'sui'? I get 'push' and 'pop' have to so with the stack (like PHA and PLA in 6802) 'mov' I also get, but some of it (lxi?) is really confusing me. I'll have to check some on-line resources of Z80 assembler. In the meantime, can anyone give me a nutshell version of what this is doing? The comments help, but they stop just short of aiding me in understanding what is going on.
  2. @EricBall - Thanks for the info, but remember there are other things to consider (like if the *middle* of the sprite runs into a horizontal maze wall (or one with two 'bubbles' horizontally)... things like that.
    @SpiceWare & Moycon - Thanks!... but I'm not even close to having something playable yet :thumbsup:
    @GroovyBee - I actually *have* special ordering of the indirect characters already (it took me a while to get this order) ;) You will see - moving from $80-$87 you have vertical, horizontal, vertical, horizontal, followed by 4 'L' shaped characters. The pattern then repeats, until $C0 where all of the extraneous maze pieces are. This way I can AND the character with $0F (after checking for a negative number so I know I hit a maze) and just check for $00/$02, $01/$03, and $04 or greater. The $C0 chars and above are special cases. Although I see that if I put the two vertical pieces as $00 and $01, and the two horizontal pieces as $02 and $03, I can AND the character with $0E and just check for $00, $02, and $04 (BPL).
    I was thinking of tables for the shots, depending on where they are hit, which character replaces the one that the shot collides with. Not sure how tables would help with this type of collision, though.
    BTW, I am doing this in 320A mode, with 16 High (max) sprites.
    Thanks,
    Bob
  3. Cool ;)
    I find I am similar to you, except my low end is 10:00.
    Prince has two long songs that I actually listen to (every once in a while) completely through: America (12" version) 21:53 and Cloreen Baconskin 15:30. Good for long drives. ;)
    He also has a really funky B-side song "La, La, La, He, He, He" 10:43 which is on the flip side of the 12" for Sign-O-The Times.
    KISS' 100,000 years (live version from Alive!) is 11:03
    I occasionally listen to Donna Summer's Love to Love You Baby (16:53) and Try Me, I Know We Can Make It (17:55)
    'Love to Love You' moreso because I love the breakdown of instruments down to the bass guitar only. They then bring the others back in one at a time. Those session musicians are very underrated and should have had more acknowledgement.
    Led Zeppelin's live version of 'Dazed and Confused' lasting almost 27 minutes is a cool listen (if you like Jimmy Page's guitar) :D
    I also make my own extended versions of songs (been doing that since I'm little) so if I don't like a remix or if one isn't available, I make my own.
  4. Thanks for the kind words :)FWIW, I actually tried to get the tethering on Space Duel. The game suffers from slowdown when there are many 'rocks' on the screen, so trying to add the table lookup for tethering would have made it that much worse. So I dropped it.Actually, at the time I was programming this, I was in contact with Owen Rubin, who was giving me a few pointers from when he programmed the arcade game. He was trying to find the source code to handle the tethering, but he couldn't. He eventually ended up giving me a small list of things that weren't exactly like the arcade, once I sent him a 7800 and a Space Duel cart for helping me. :)BTW, thanks for the props on Asteroids Deluxe as well. The Killer Satellite was a pain to program! BTW, I didn't include the thrust in the original Asteroids 'hidden' game because I ran out of sprites. :)
  5. There's the song "I" by KISS, it's on "Music From The Elder" (1981)
    Madhouse, another Prince offshoot, had their album's titles reflect the number (i.e. Track 1 was called '1', Track 2 was '2' and so on). Not sure if that counts, only because they tended to spell out the titles ("One" instead of '1') From 1986.
  6. Hey Jeff:
    Looks cool :)
    I apologize for not getting you the information sooner. Not only am I making carts for Jr., but I'm making Super & SI for GoodDealGames. Plus I have to learn Java to program the Blackberry (real fast). :ponder:
    BTW, Super Pac-Man does graphics the same way as Jr. ;)
    The graphics for PMC, however does them the same way as the original 7800 Ms. Pac-Man. As far as I know this is the only game that GCC stored the graphics this way. (It was a real pain figuring that out in the very beginning). It's done that way because the actual used graphics are held in RAM and are just copied from the ROM to save space.
    I will get you the decode information for 320B (320A is the same as the way Jr. & Super Pac is set up, just with 1 'bit-per-pixel' instead of 2.)
    160x4 is (as you may have guessed) 4 bits-per-pixel and 320B is just an *insane* way of holding graphic data. It's something like every odd bit is adjacent graphic data... and even is the other half... I'll try and look at it when I get home and get you an example.
    Thanks - and great work!
    Bob
  7. Looks Great, Jeff ;)
    I didn't have time to see about changing Ms. Pac-Man to allow for vertical tunnels. Trying to get all of these carts made for Jr. :ponder:
    I beg to differ about the sprite hacking tools - there aren't *any* that will allow for all modes: 160x2, 160x4, 320A, and 320B. I personally use Tile Molester and hacked it a little to get it to work with 160x2 and 320A.
    If you were to create functional Sprite Editor that can handle all four modes (there actually are more, but these are the most used) and put out source .byte data, I would be forever grateful. :) I've been meaning to do that for 2 years. Never could get around to it. ;)
    Bob
  8. Hey Jeff:
    Excellent work! I wish I had this when I was making the mazes :ponder: it would have went a lot faster.
    BTW, the Pac-Man Collection and Ms. Pac-Man store the mazes in the exact same way, just in half the size. Super Pac-Man is *completely* different, due to the odd layout of the maze itself.
    Can't wait to see this in action!
    Bob
  9. Hey Walter:
    I'll see if I can find some screen shots and take a look at it. :) I'm adding as many options from the 2600 version as possible, so hopefully it won't get dull quick. :D
    I kind of wanted to keep this one at 16K, but I'll what I've got once I'm finished (I know it's a 32K bin at the moment, but I'm going to reduce it).
    BTW, I am now about 3/4 done with what I set out to do, so I am now moving this to the 'Homebrew' forum and starting a thread there.
  10. Thanks, Bob, and thank you Supercat
    Ok - my beginning of working with sound for this game led me to a discovery: the invader's "march" sound isn't in time with the movement! Only the first few invader hits keep the same time, then they start to separate. This gap increases as more invaders are cleared from the screen. I always thought they were exactly the same. :-/
    It's not that noticable in the arcade because of the 'delay' (the arcade actually moves one invader per frame). It is noticable here, but I think it's ok.
    Update in first post.
    (still, so far so good with the CPU cycles) :)
    Bob
  11. Ok, some good news now. I enabled 'Dual Player Mode' and the screen didn't jump with both players on the screen (shooting), both invader shots, the invaders, and the ufo!
    I wish there was some way to tell how many cycles I have left before I start getting screen jumps / slowdowns.
    Now I start to work on sound. Then 'attract mode'. Then player options.
    Bob
  12. Thanks Supercat - I guess I misread the code then.
    Please don't be annoyed with me, but I just don't understand the DLI code that you wrote there. :)
    This is the part that actually scares me; when I don't understand something I think I should, I truly feel like I'm becoming more stupid as I get older. *Especially since I am a programmer by trade* (although we use C, C++ and C#)
    If I'm struggling with a simple game like Space Invaders, I can forget about doing anything more complicated :-/
  13. Thanks again Walter :)
    WE HAVE COLLISION DETECTION FOR INVADERS SHOTS! :)
    This game is now actually playable :D Supercat, I have not implemented your code yet (although I think I will have to, I can't have much CPU time left per frame). There might be one issue with it - If you recall, I am only using 8 pages of RAM for the Shield. There are 16 lines for the shield, therefore I started the first 8 rows in <$shields>, and added the last 8 rows in <$shields+$20> (being that each RAM line is only $20 long). Does the code you wrote assume all 16 rows of RAM are each contiguous page?
  14. Thank you Supercat :)
    Thanks Walter!!! :D
    Ok - next step
    Things Added:
    1) UFO point table based on player's shot (but for now it doesn't match the arcade yet)
    2) Slowed UFO down to more closely match arcade speed
    3) Added Invader shots (no collision detection yet)
    I need to work on the frequency of the invader shots.
    In the arcade, they don't seem to *constantly* shoot at you. There seems to be a variable delay between them. Also, most of the invader shots seem to be in the player's general area, with one or two not so close. Need to try and replicate that.
    Updated bin and screenshot in first post.
  15. Sounds cool Allan :)
    Ok, I've updated the following things:
    1) Shots are not auto-fire (like the arcade) and delay when hitting something.
    2) Invaders now start at the correct row for each level (had to do a little adjusting for the difference in the size of the screen)
    3) YOU CAN NOW SHOOT BETWEEN INVADERS! did some closer collision detection, It may appear for a shot to go through the very edge of an invader but it seems to work ok. :) Let me know if I should adjust anything. But, please remember, even though the bitmap for the invaders is based on 16 pixels (two bytes in 320A mode), everything is accessed as 8 pixels (two bytes in 160 mode). That caught me quite a few times while doing this.
    See first post for attachment.
    Supercat: Can you elaborate on this line: "hit: ; Assume Y indicates where we are within the shot" Is this the y position of the shot within the 16-pixel shield area?
    Also, is there a way I can use the interrupt to check if a console switch was hit and store the value in a variable?
    ...I'm saving the sound for last. :D
  16. @Allan: Ok, I fixed the 'invaders marching' / 'points for shield' bug, attachment in first post. If there are some tiny areas that happen to be left that can't be hit, I don't think that's a big deal. I wouldn't think anyone wastes their time shooting away all of the shields. Even if the invaders aren't shooting, they get to drop a few levels by the time all of the shields are gone.
    @Supercat: I'm sorry, I didn't mean to make you repeat yourself, I just didn't follow that completely the first time around. Did you actually compress that entire routine I posted into those few lines above? :) ... I *need* to understand this routine if that's the case. I will be studying it :D
    Thank you!!!!! :D BTW, I plan on having the shields move in one of the options (like the 2600 version). Does that change anything?
    Ok, I'm pretty close to an actual game here... two big things left: 1) make the invaders shoot and 2) control the ufo. I can then work on the options, and two player dual mode :D Oh crap... I just realized that for two players alternating, I have to copy the remaining invaders and shield to a temporary area... :)
    BTW, does anyone know the timing on when the UFO comes out?
