5,644 -
28
Posts posted by PacManPlus
Sorry to necrobump, but I just saw a video in my YouTube feed that they are now emulating Ms. Pac-Man Twin successfully in MAME.
So, that means I can finally finish the 7800 version. I've already noticed a lot of differences between mine and the arcade...
I need to finish Galaxian first, though...
...Ms. Pac-Man seems to have had some collagen implants for this version.
16
Yes, that was a mistake on my part. I've fixed a lot of things since that build.
I've shifted gears, though. I'm currently reading through the arcade commented disassembly (and somewhat learning Z80 in the process) and translating it to the 7800 version. So (hopefully) if things work we should have a VERY arcade accurate port.
I'll revisit the audio once I have the enemy stuff done.
@-^CrossBow^- - BTW, you were exactly correct on the reason for the 'black bars' that periodically show up on the attacking aliens. Sprite overlap. It's only when they are on the same zone as the 'flock', and usually when there is more than one dive bombing.
Cool! Thank you!
Just keep in mind: I recently gutted the enemy handling (aside from the flock itself) and am in the middle of completely re-writing it.
On 2/8/2021 at 2:52 PM, Synthpopalooza said:Cool ...
Out of curiosity: Are there any home ports of Galaxian that use 320 mode, apart from this? And I don't count Apple II because that uses artifacting and essentially halves the resolution.
Not that I know of...
Oh, yes - like two or three years ago.
Ok, I'll ping him for his address... Thank you
I have 2 concertos that I need to get the firmware updated on... Got them quite a while ago...
Things like this make me want to continue working on the 3D model of the shell that Curt gave me (so they can be 3D printed). I had started to tweak it (it wasn't an exact fit as it was) but then lost interest...
Nobody should have that bad of a case
Thank you
It was a complete surprise to me when I got the e-mail... Like I said in the other thread, I was absolutely sure that Millie & Molly had won.
I have to say, I was *sure* that Millie & Molly was going to win. Couldn't believe it when I got the e-mail saying I had won. Thank you for those kind words.
Done!
(Someday, I need to put those in alphabetical order...)
All updated!
13 minutes ago, BydoEmpire said:Stupid question: can we pick any unused 2 byte value, or is there some range we need to fit into? Seems like the former in the 7800basic docs.
Only one bit that I know of means something... Referenced here
Guys, just a head's up; I plan on changing how the Yamaha is detected, using some ideas that RevEng suggested here.
Hey!
I actually put them aside for a moment while I retrofit the code to work more like the arcade version. I'm absolutely sure you r suggestions will help though.
Thanks,
Bob
Thank you!!!
CONGRATS!!!!
Ok, Time for a little update:
This is not going to be the quickest game completed, as I've been looking through the commented disassembly of the arcade version of Galaxian. I'm starting to understand a little Z80 in the process, and I'm seeing how they do things which I like better than how I did it. For instance:
As we already know, there are 8 sprites available for the Galaxian hardware. What I *didn't* know, was that the sprite 'slots' are predetermined:
0 - For miscellaneous use, i.e. an enemy explosion while still in the 'flock' (because it's a tile, and needs to be converted to a sprite to show the explosion). I'm also using it for the player(s), being they will never be in the same zone as the 'flock' itself.
1 - reserved for the flagship
2 - reserved for the 'escorts' to the flagship
3 - reserved for the 'escorts' to the flagship
4 - solo alien attacker
5 - solo alien attacker
6 - solo alien attacker
7 - solo alien attacker
So there are never more than 4 solo + 1 flagship + 2 escorts attacking at one time.
Originally, I was using the first two sprite slots for each player (because of the 2 player simultaneous option). I've reduced that down to 1 to match the arcade, and for the simultaneous option I flicker the players, and their shots. It's not that noticeable. Also, did you know that the arcade version flickers the enemy shots? There are only 7 available shots, and Galaxian can have up to 14 enemy shots at a time. I was actually a little surprised by this one. I will do the same, although I only have 6 available to me (up to 12 at one time).
There are two of the arcade routines that I cannot follow, so if someone knows Z80 well, I could use some decyphering...
Thanks guys!
Bob
P.S. - My nickname at work is now 'Blob' as I mistyped my name on an e-mail as I've done here once or twice (the 'l' and 'o' are adjacent and sometimes I fat-finger them) 😕
On 1/30/2021 at 4:18 PM, PacManPlus said:There's only one thing that bugs me about that label (other than the dirty case, which I did try to clean, BTW): too much empty space in the middle of the picture while the text is over the objects themselves.
@Atariboy2600 - Where are you?
5 hours ago, Bencowboy said:I'm also subscribed to Arcade USA and saw the video, I'm interested in a physical cartridge release, so please lmk?
Hopefully it will be in the store soon... I just finished the label art, need to do the manual first.
Thank you!
18 hours ago, ZylonBane said:I wonder if any of these improved sounds could be hacked in to the 2600 version of Galaxian.
ZB! Haven't seen you in a while! Hope all is well and you are staying safe.
Yep
Though at least we didn't have to worry about being in-line with TIA sounds in that one.
2 hours ago, Synthpopalooza said:Thanks for the update.
Hopefully my explanation will solve your POKEY issues. 🤞 Those AUDCTL settings can be difficult to grasp.
Ok, cool, so let me see if I get this:
I've updated the table so that both sound drivers can share it...
New common index table and priority (for both TIA and Pokey) :
$00 - Player Shot Priority $08 $01 - Drone 6 (Super Fastest) Priority $06 $02 - Player Explosion Priority $0F $03 - Drone 1 (Slowest) Priority $06 $04 - Drone 2 Priority $06 $05 - Drone 3 Priority $06 $06 - Drone 4 Priority $06 $07 - Drone 5 (Fastest) Priority $06 $08 - Enemy Death Priority $08 $09 - Flagship Death Priority $09 $0A - Beginning Enemy Swoop Priority $07 $0B - Final Enemy Swoop Loop Priority $06 $0C - Bonus Life Priority $0F $0D - Coin Insert (Pokey Only) Priority $0F $0E - Intro Music, Channel 0 Priority $0F $0F - Intro Music, Channel 1 Priority $0F
Note that sounds with the same priority and channel will cancel the prior one and start the new sound, regardless of the order played.
For TIA, the player shot and player explosion is in channel 0, and the enemy swoop (both parts), enemy death (both types) and drones are in channel 1. Bonus life overrides channel 0. Non in-game music doesn't matter.
So for Pokey, The Channel table should look like this:
.BYTE $03,$01,$03,$01,$01,$01,$01,$01
.BYTE $02,$02,$00,$00,$02,$00,$00,$01
...and also for Pokey, the CTLVOLTBL should look like this:
.BYTE $8X,$AX,$0X,$AX,$AX,$AX,$AX,$AX
.BYTE $CX,$CX,$CX,$CX,$CX,$CX,$CX,$CX
Finally, when calling the Coin or Title Tune sounds, set AUDCTL to $50. Everything else gets $60.
Does all of this sound correct? Sorry about the questions, but I want to make sure everything plays nice.
Thank you!
Hi guys...
Just checking in...
I have the following done:
- If a Flagship attacks the player alone (no escorts) and makes it past the player off the bottom of the screen, it has 'escaped' the level and shows up on the next one.
- I nixed modifying the sound driver. I made 5 different speed background drones. The number of enemies left dictate which one is played.
@Synthpopalooza - thank you for the above post. I'll check that out soon... I'm almost done with the TIA sounds, although I'm not happy with my current enemy swoop sound. Need to work on that. That's the only one that might have to be different and start lower in pitch as I don't have all of the higher-pitched sounds.
Also, just so you have it, here is the finalized sound index:
$00 - Player Shot
$01 - Used to quiet the channel for TIA (not used for Pokey)
$04 - Drone 2
$05 - Drone 3
$06 - Drone 4
$08 - Enemy Death
$0A - Not Used (I had something here but removed it)
$0B - Not Used (I had something here but removed it)
$0C - Final Enemy Swoop Loop
$0D - Not Used (I had something here but removed it)
$0E - Beginning Enemy Swoop
$0F - Not Used (I had something here but removed it)
$10 - Bonus Life
$11 - Coin Insert (Pokey Only)
$12 - Intro Music, Channel 0
$13 - Intro Music, Channel 1
Then, it's just making some kind of level indicator, and modifying the shot frequency, dive frequency, and difficulty ramping. Getting there!
PAC-MAN Arcade Controller...the quest for PAC-fection!
in ColecoVision / Adam
Thank you so much for the shout out. I do appreciate the kind words!
That joystick looks incredible, so I have to ask...
Is that a one-off project, or would you be willing to make a 7800 version (the only two differences are no keypad buttons in the front and two fire buttons on either side of the joystick)... and if so, how much?
Thank you, and excellent work!
