2,924 -
Posts posted by Wrathchild
Ah, one of the pages I often visited, I liked the IPµ8930 but a bit beyond the hobyist's budget! How much is the W3100A or IIM7010?
Here you go...
The 'characters.c' file was used to generate the A8 data statements for inclusion within an assembler file. You could rewrite it to output the bytes directly to another file if you like and use 'incbin', or some equivalent command, in your project to include the data.
Note that I included the raw data within the original C file, I think this was because the hex editor I was using let me copy to the clipboard as data statements.
This could be better achieved by opening a file, moving to a specific offset and then reading a given length of data (plus closing the file). These details could be passed as arguments on the command line.The 'chars.s' assembler file gives an example of this kind of output being used. In this case, letting the user see the graphics by selecting one of 4 screens using the joystick.
Note: this was built using the CC65 tools (CA65 to assemble and LD65 to link) and the linker was passed the 'generic.cfg' file to override the default Atari memory map.
If anyone fancies animating these little guys it shouldn't be too tricky.
The images in the original ROM provided 4 states per character. These are: down (1), up (1), left (1) and left(2). As the animation of walking in a direction only has two states, the missing images achieved in the NES via hardware flipping. So: down (2) = down (1) flipped horizontally, up (2) = up (1) flipped horizontally and right (1) and right (2) are flips of left (1&2). To perform the flipping on the A8, use the 256 byte lookup table provided in 'flip_table.s'.
Enjoy,
Mark
I wrote a small conversion routine to extract NES graphics in an A8 usable format (see my avatar for an example). I'll dig it out tonight and upload it. That may make it slightly easier getting graphics from NES roms. However, as pointed out before, the 8*8 tiles used on the Nintendo require 2 (4*
characters on the Atari. -
Is a problem here that you effectively have to write you're own FAT handler in order to manage the filesystem? Or do these devices sometimes contain their own micros that do that work for you?We are working on it. But it might take a year or more to finish a driver for USB Stroage.Similarly, some of the networking devices such as http://www.zonetusa.com/DispProduct.asp?ProductID=130 could be used, but again, how much work is the device going to do for you?
Studying linux device driver code could help in some instances, as trying to get help from the manufacturers isn't always fruitful.
Regards,
Mark
I was doing something like this with Combat, however
I would say that a direct port of say a games kernel
(primarily the screen drawing part) is not always feasible
and you better off mapping the ideas of a game to the
A8 specific ways of doing something.
Examples of problems are:
2600 supports playfield reflection, this can be done
in the vertical though custom Dlists, but in the
horizontal this means you need to write this in software
to compensate. Not always used though in 2600 games.
2600 sprites can be flipped and also 'cloned' (e.g. the planes
in combat) by hardware. Although the expansion of a sprite
is similar, this means you need to use some of the other A8
players and missiles to provide this... more overhead.
Therefore you end up doing the sprite graphic prepartion work
when screen drawing is outside of the display areas (e.g. VBI)
rather than on-the-fly as a 2600 game typically does.
2600 sound - slightly different random generators used for
the noise, but doesn't look too tricky to translate this.
Just looking on the MicroUSB site
http://www.strotmann.de/twiki/bin/view/Mic.../ProjUSBAtariST
When you follow the link to http://www.janthomas.f2s.com/index.html
this only states that its for the Falcon? Is the project ST compatible?
I'll try harder to get my ports done next time around, unfortunately paid work keeps getting in the wayNext year, we need more ATARI 800 games in the competition.
Certainly does
Dave Murray is one of the main reasons why I still strive
to play the guitar (after about 20 years now)!
As for tutorials, not really, but I help out where I can
From what I can remember of my early experiences
of learning 6502, the main thing was to keep experimenting
and work through the crashes! Set yourself small targets
and then build from there.
Later I found that disassembling or working out how a
game does something that you like helped see how other
programmers did things diferently, i.e. their 'style'.
An example of that was 'Elite', which showed me for the
first time the use of the 'BIT' command to effectively ignore
a the next two bytes of code, here's an example:
loc_0_9019:
CMP #$3B
BEQ loc_0_902B
CMP #$3A
BEQ loc_0_9028
CMP #$3D
BNE loc_0_9030
LDX #3
.BYTE $2C
loc_0_9028:
LDX #2
.BYTE $2C
loc_0_902B:
LDX #1
JMP ChangeView
Good luck in your projects!
Software sprite routines that I'd like to understand one day
would be the Zeppelin Games' Draconus, and also the
games 'Basil - Mouse Detective' and 'Black Lamp' appear
to have good routines too.
also I don't understand,for 'of' read 'to make'
could you clarify for a NOOB?
No problem,
"effectively an AND of the lower half of the address"
should have read:
"effectively an AND to make the lower half of the address"
Say I want to set the Display List to point to (hex) address $7F20
The AND makes the lower half of the address by masking only the
lower 8 bits of this address, i.e. $20
as 256 is 2^8, dividing this address by 256 gives us the value $7F
So we can poke address $230 with the (lo) value $20
and address $231 with the (hi) value $7F, e.g.
SDLSTL=$230
SDLSTH=$231
my_dlist = $7F20
LDA #my_dlist*255
LDX #my_dlist/256
STA SDLSTL
STX SDLSTH
Alternatively many assemblers let you use '<' for lo and '>' for hi:
LDA #
LDX #>my_dlist
STA SDLSTL
STX SDLSTH
Hope that helps :wink:
For 'of' read 'to make'
255 should follow the & symbol, effectively an AND of the lower half of the address.
Shameless plug
Get a Flash Cart from Steve @ atarimax.com
Images for most of the development carts are available
from the forums on his site, e.g. Mac/65 & Action!
If you're using Windows then having Cygwin installed is a good idea,
though you can get away with just using a win32 version of 'gnumake'.
I did disassembly the whole game for them using IDAPro and offered to help but not much came from that... but requests to help with the disassembly and porting of the games logic code from the C64 (I assume) didn't gain any significant response
From my experiences (Elite/Bard's Tale/World Class Leaderboard and others) there are some games that lend themselves nicely to porting and others that don't. The A8 can manage a similar bitmapped type screen layout (i.e. Antic 4) but at a slightly higher mem usage and with not such a great control over the colour palette. A game with heavy sprite usage typically needs that portion completely rewritten and again you often lose out due to colour (having to use software rather than hardware sprites) or resolution (e.g. Mission Impossible bloke)
If you want a recommendation from me... go for Rock'n'Bolt.
Simple graphics and nice gameplay, topped with a basic tune.
Regards,
Mark
There was another type-in but I can't recall its name?I think you had a Shamus like guy who had to get keys to unlock gold
(or doors to get to the gold) on a fixed screen map. The striking thing
was the colorful graphics of which it used an animated charset to rotate
the walls/flash jewels etc.
I've recalled that the game may have been called 'Swag'
but I'm not 100% certain... it didn't show up on XL-Search.
Does it ring any bells with somebody?
Thanks,
Mark
typically, programmers get sidetracked all to easily
A few downloads... is anyone having a crack at implementing these?
Eh? You've changed its functionlity?We can improve that routine by getting rid of the Y registerThat routine was a bit pair swapper, yours is for single bits.
The Combat code was:
CreateFlipTable: LDX #0 @1: TXA LDY #7 @2: ASL A ROR $80 DEY BPL @2 LDA $80 STA $600,X INX BNE @1 RTS
So yes, you do save on that
I did think to change the bit pair version to not use the zero page temp register.
CreateFlipTable: LDX #1 @1: TXA LDY #3 @2: ASL A PHP ASL A ROR FlipTable PLP ROR FlipTable DEY BPL @2 LDA FlipTable STA FlipTable,X INX BNE @1 STX FlipTable RTS
Many appologies to all, I did just send the demo and not the
code because I thought I should finish it first before doing so
Here's the Kernel based code anyway... I had decided that
this wasn't going to quite work because of the extra cycles
wasted to A8 things, so I have recoded it here with a more
VBI based approach. As happens, everything is now broken
and work stopped as my daytime and evening work has been
taking up too much of my time.
Still - my MyIDE board is now built and so next Monday it gets
fitted and I should be trying it out next week. How long does
a 12gig drive take to format
Regards,
Mark
BTW, there was a similar routine to create a flip table in the
Barbarian demo I did. You'd use this for 4 colour bit patterns.
CreateFlipTable: LDX #0 @1: TXA LDY #3 @2: ASL A PHP ASL A ROR byte_0_A8 PLP ROR byte_0_A8 DEY BPL @2 LDA byte_0_A8 STA FlipTable,X INX BNE @1 RTS
Here's a starting place for anyone who wants to take this up.
I've knocked up a decoder based on the C64 SID file.
Good luck!
PS. the excel sheet shows that not all the notes used map
nicely to actual note frequencies, but they are there or
there abouts.
Have a look at the Combat code I posted up recently, there's a small routine in that which creates the lookup table.
Quedex on a mobile phone...
Atarimax/ABBUC USB Cartridge Now Available!
Maybethe UDS-10 be interfaced simply to the SIO bus via something like a PIC micro? Using the uIP library on the A8 (or even in the PIC) to handle things?
