2,924 -
Posts posted by Wrathchild
Shame it misses the r/w line as an UNO cart equivalent could be done for it.
You're welcome.
For the majority of keys, the A8 is interrupted to say 'this key is pressed'.
So if keys are held simultaneously or another is subsequently pressed whilst another is down then the A8 cannot know this.
So the obvious exceptions for that are the Shift and Control keys whose statuses are additional bits supplied with the key-code, plus the Console keys.
The break key also can be configured to generate an interrupt.
So in Elite where you would want to use diagonal directions in flight then this wouldn't be possible, you would toggle quickly between the X and Y direction keys to do this but not ideal.
Similarly if you wanted to fire you'd need to release the direction key (although this could be moved to Shift from 'A' for example). None of this is ideal in a fire fight!
So the default setup will be to use the joystick as that is what most people would be doing anyway I think.
One for @phaeron but with the options 'Display' and 'Debugger' I'd summize their use would depend on which window had focus (display / non-display) and so 'Global' meaning both.
If you're using the debugger or not then Global seems a sensible choice either way based on your use-case.
Have been able to revisit some of my Works-In-Progress 5200 ports... with @playsoft as an essential second pair of eyes to spot moments of madness in my coding
First release candidate of "Stealth" ready so fingers crossed a binary should be available soon (32K image)
@Albert Mr Do! on the list to tackle
14 minutes ago, rensoup said:...or you mean save states for reproducing the bug ?
No, was in-game saving of progress, but if anyone can just start on any level then it does seem to eliminate the need.
I'm not sure the 2600+H is a necessary dependency, certainly with the STM32F ARM micro in the UNO cart you could easily have a board with no SD socket and provide a title self contained within the firmware and so house in a normal case looking like a normal game. I should think the same applies with an AVG cart and so would imagine that board, components and case cost is not prohibitive (€20-25 ?).
Save states?
The 1050-2-PC cable used with the Pro-System was different to the SIO2PC cable, though I think later cables came as a 2-in-1 solution?
Maybe get a moderator to change the title of the thread for you as you've chosen to include new parts within the thread rather than start new ones for each part?
You couldn't do diagonals, e.g. up/right, at the same time. Similar issue with something like Elite from the keyboard, OK on other 8-bit micros as key-scanning breaks keyboard into small sections but A8 is PITA due to the 'one-only' (aside from Shift and Console keys).
6 hours ago, solo/ng said:Technically you cuold have a cartridge for a8/xl/xe with snapdragon 965, 8 cores, 2.4Ghz
Compute all you need/want on it (for example in C) and just stream results to screen/machine (via various methods).
The A8 series already has this in the form of the UNO Cart.
26 minutes ago, StickJock said:Spyhunter would also be a good candidate for conversion. I, also, haven't played it in ages, but IIRC, you needed to use the button on a second joystick to release the oil slick & smoke shield.
From post #57, it's already on the GIT server
30 minutes ago, Yaron Nir said:you can just copy and paste . this is the default publishd with CC65 library.
33 minutes ago, Yaron Nir said:-C atari.cfg
You shouldn't need to do this as the linker should find the config file within the CC65 installation's "cfg" folder.
You can override the default by specifying any of the below, e.g. "-C atari-xex.cfg" depending on your requirements.
Or, of course, to specify your own rolled config file, e.g. when making a cartridge.
But for a newbie I would recommend they don't need to get involved with config's right away and so adding "-C atari.cfg" is not necessary
On 11/30/2019 at 4:45 PM, Savetz said:Dennis Zander: Artworx, Hazard Run, Strip Poker
Nice interview, thanks!
51 minutes ago, rensoup said:Well you got me 🤣
Well if team Hoaxers don't snap you up with a Premier League player's salary then somethings not right with the world
Also, I can attest to using multi-dimensional arrays in C using CC65 and whilst it is good while developing you get to a point where the overheads needed to calc the data access are too much and so you end up refactoring to using a single-dimension array instead, so the grass isn't always greener.
From what I recall, as PotGo is used to discharge the capacitors its basically the time needed for these to settle again.
That could be established by using a few fixed value from the paddles, set the Critical flag so that stage 2 routines aren't used and use a Pokey timer routine to set the shadow values and then write to PotGo.
Start short and if the values in the shadow registers don't match the expected values then lengthen the timer.
Equally you could probably achieve this equally as well with a loop to monitor VCount or use DLIs.
27 minutes ago, CharlieChaplin said:Why does the single ATR image use a non-standard 384k size instead of standard 360k
It's just padded to a nice round $60000 bytes and doesn't utilise compression. It was merely a quick throw-together as I'd done a fair amount of investigation toward making an Atarimax cart version.
51 minutes ago, ebiguy said:If you are talking about RespeQt that supports ATX, then the answer is yes.
Not an ATX, Thom was stating that the ATR uploaded loads under RespeQt.
The issue would appear to be down to this section:
So the VCOUNT check determines which code path is taken etc.
In Altirra I used the trace: bt $b49f "$%02x $%02X" db($14) db($d40b)
With PAL accurate timing this gives outputs of:
$0b $2C
$0b $26
$0b $21
$0b $1C
$0b $17
$0b $11
$0b $0C
$0b $07
$0b $02
$0b $99
$0b $93
$0b $8E
$0b $89
$0b $84
$0b $7F
$0a $79
$0a $74and this stops there and the load continues.
Whereas with accurate timing off it returns:
$04 $25
$04 $32
$04 $3A
$04 $24
$04 $1A
$04 $26
$04 $23
$04 $17
$04 $1B
$04 $01
$04 $26
$04 $44
$04 $70
$04 $90
$04 $13
$04 $2F
$04 $44
$04 $5A
$04 $5E...
and so the load is screwing up
So as both crash in Altirra if 'Use accurate timing' isn't checked, then I suspect it's going to be down to not all protection being removed, which would indicate that RespeQt is honouring the timings?
Unicorns season: Prince of Persia for the A8!
No, that's not really correct.
Many of the popular carts are able to run many different formats of cartridge binary images.
So whilst you can blow the image to an AtariMax cartridge, you can play the binary from an Ultimate Cart, The!Cart, AVG Cart etc
So just continue on as you were and it looks like others with prep the cart version for you
